preith Posted August 9, 2007 Share Posted August 9, 2007 I thought I'd give everyone a heads up on a driveshaft I just purchased. I found a place in Texas who custom fabricated one basically identical to the MSA version, but 2†shorter in my case, and a bit cheaper at $425 total. They have a good list of Nissan models and other makes allowing for many trans/diff combinations. http://www.thrashdriveshaft.com/import2.htm#NISSAN Quote Link to comment Share on other sites More sharing options...
240hoke Posted August 9, 2007 Share Posted August 9, 2007 Cool link. I thought I would add too another place you can have a driveshaft made: powertrain industries They sell after market pieces to driveshaft companies so they have about any yoke/flange available and can also make driveshafts to your dimensions. I had my l28/z32 driveshaft made by them, they made it and shipped it out in less then 24hours. -Austin Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted August 9, 2007 Share Posted August 9, 2007 You could have saved some money dealing with this place http://www.pstds.com/ Quote Link to comment Share on other sites More sharing options...
Mayolives Posted August 9, 2007 Share Posted August 9, 2007 preith, Driveshaft Specialities also built my shaft. The part was first class and delivered to me within a few days of my order. No muss..No fuss. Quote Link to comment Share on other sites More sharing options...
preith Posted August 9, 2007 Author Share Posted August 9, 2007 Pop N Wood said: You could have saved some money dealing with this place http://www.pstds.com/ I did contact them first, they weren't very helpfull. I contacted several places which cater to the v8 crowd for the most part and did not get anywhere. Quote Link to comment Share on other sites More sharing options...
JMortensen Posted August 9, 2007 Share Posted August 9, 2007 Any idea how much weight aluminum saves vs steel? Quote Link to comment Share on other sites More sharing options...
seth Posted August 10, 2007 Share Posted August 10, 2007 I went to aluminum when installed the VG trans. I don't have an exact weight, but i tell you it wasn't much... Quote Link to comment Share on other sites More sharing options...
preith Posted August 10, 2007 Author Share Posted August 10, 2007 jmortensen said: Any idea how much weight aluminum saves vs steel? The weights are actually the same, 10lbs, but IMO that is a bonus because you're essentially getting a driveshaft which is heavier duty without a weight penalty. Driveshaft Specialities fabricated and shipped this one within a few days of ordering as well. My reason for buying this is I've had a hard time getting the stock ones to hold up on my road racer since day one. This includes Spicers but not the OEM ones, but as I understand they're not quite the same anymore. The geometry/angles are good. The other guys in my club with Z's haven't had issues, but none are putting down as much power either. I should elaborate on my previous post. PSTDS was willing to make one for me, but they weren't aware of anyone producing a slip yoke for the Nissan trans, or perhaps didn't want to take the time to research it. For anyone willing to go the extra mile, the yoke on my driveshaft is stamped as a Spicer part, #MDI 5 C2-3-2189-5. I cannot read the diff end as the numbers are stamped facing the u-joint, but I do recall seeing the Spicer part # posted online at several different places, maybe JTR... Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted August 10, 2007 Share Posted August 10, 2007 That's all good info. thanks for posting. Quote Link to comment Share on other sites More sharing options...
HB280ZT Posted November 21, 2007 Share Posted November 21, 2007 Hi All, I just had a custom drive shaft made for my 77 280Z turbo with 1982 Nissan 5-speed and here are the spicer part number that were used to put it together: Front yoke C2-3-2189-5 (3103-24) rear flange C-22459 (3102-39) The numbers in () are from my sales receipt and the others are off of the parts themselves. Hope this helps someone else down the road. The picture shows the old and new shafts. Now my only issue is getting bolts to fit the new rearend flange, anyone have any ideas?? HB280ZT Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted November 21, 2007 Share Posted November 21, 2007 HB280ZT said: Now my only issue is getting bolts to fit the new rearend flange, anyone have any ideas?? HB280ZT http://forums.hybridz.org/showthread.php?t=126197&highlight=jtr+bolts Quote Link to comment Share on other sites More sharing options...
Kash Posted November 21, 2007 Share Posted November 21, 2007 Hey Seth, Is that your car? Looks great, what color is that and do you have any additional Pic? Quote Link to comment Share on other sites More sharing options...
Mike C Posted November 25, 2007 Share Posted November 25, 2007 Wenco in Cali made mine. It's steel with the 1310 joint in the back on the NEAPCO adapter to my R200. In the front all they could find was the Nissan T5 yoke with the little joint. Do these T5's shafts have 1310 joints? One suggestion Wenco had was turning down I think a Chrysler 27 spline slip yoke OD to fit the Nissan spec seal. Anybody got u-joint size info on those shafts? Quote Link to comment Share on other sites More sharing options...
