Race Gas Dyno Numbers
Booztd 3
Guys
Got a chance to get back on the dyno last week (9-10-2007) before hitting up the drag strip (which led to the torture of an innocent output shaft.
I am happy with the results, car is still picking up 20rwhp per 1psi of boost.
Stock RB26 Block
ARP Headstuds
Tomei 1.2mm HG
Stock Head w/Tomei Type A poncams
Full-Race Twin Scroll Manifold
Garrett GT4202-74mm
Twin Tial 44mm Wastegates
Full 4" exhaust
3" IC piping
Duall Walbro Fuel pumps w/1000cc injectors
Torco 112 Fuel
Dyno Chart, 24psi, 1 Smoothing Factor
Video of the run
Pull was from 60mph to 140mph
http://www.booztd3.com/Videos/680rwhp_Booztd3.wmv
Probably will not push the car anymore this year, power-wise, as its still on stock block, and no need to ruin a good block before the build begins this winter. 1000HP or bust :D
Well cool those are good numbers. I made 610 at the wheels at 25 PSI on My motor. This was on a stock motor on a ♥♥♥♥ rom tune on pump gas (japan).... looking forward to making 700Plus on race gas at the same PSI!!!!
good job
Good luck buddy
I think the next step is an auto , before I build it up.....seriously
Good luck buddy
I would highly recommend it. My buddy up here is dynoing 620 with his vg and he has broken a turbo diff input shaft with teh triplle plate clutch. So swapping to a turbo diff wont be a reliable upgrade ;<
My car is an original TT :)
I have the R230 rear end and all that fancy 'beefy' stuff already :)
  • Administrators
I am hoping for mid to high 10's if all the drivetrain parts hold together :)
Thanks
Speaking of your busted drive train parts... I posted a question for you regarding your busted R-230 output shafts in this thread below as it has me just a little bit concerned..
Busted output shafts...
Thank you,
Paul
super sweet man. that vid made me all giddy like a school girl
makes me kinda wish i bought an RB26 instead of the RB25
I'm sure you can pull similar numbers from a slightly modded RB25. Go for it :-)
(prepping the RB25 with price of engine included would end up being same as RB26 in stock form at some engine outfitters)
