73DatsunZ Posted January 11, 2008 Share Posted January 11, 2008 Lookin good. It almost looks like the front left fender flare is warped a little but, but maybe its the light... Any insight? Quote Link to comment Share on other sites More sharing options...
MPD47 Posted January 12, 2008 Author Share Posted January 12, 2008 No, the odd reflection is a combination of that part of the flare on the character line of the body and a light going over a pipe overhead. It's not warped. Not much for today, big thanks to Justin (gsx) for the help and for shooting a couple pics of me working.. I heavily photoshop'd one of them. (the profile shot). Got the passenger's side ZG flare mounted up and started working out the rears. Gonna work on them and/or the engine bay tomorrow. Pick up the KA at noon on Sunday Quote Link to comment Share on other sites More sharing options...
turboboost Posted January 12, 2008 Share Posted January 12, 2008 Very nice! Quote Link to comment Share on other sites More sharing options...
BobbyZ Posted January 12, 2008 Share Posted January 12, 2008 I Have those same wheel lock on my car... Havent tried anything to get them off yet. Quote Link to comment Share on other sites More sharing options...
MPD47 Posted January 13, 2008 Author Share Posted January 13, 2008 I cut them off today with my electric grinder (air wouldnt touch them). Went in and got a little bit of work done. Marked, and ready to cut Initial cutting done, I then cut the inner fender well back, and started to hammer it up in anticipation of tack welding it into place. I also put the nutserts into the proper holes but didnt have the tool to compress them, so hopefully I can get that taken care of Monday. One rear mounted up, fronts are done and trimmed. Hopefully I'll have this finished and the engine bay stripped and painted this week. Picking up the KA in the morning. Quote Link to comment Share on other sites More sharing options...
MPD47 Posted January 14, 2008 Author Share Posted January 14, 2008 Yes, it did, and I loved seeing it in the beat up, original, driving (assumed) condition. Just like I'll be driving my 240z around this year (exterior condition wise). This is about where I almost died when visibility got worse, as did road conditions, and there were no salt trucks or plows out, and a guy going 20mph less than me decided to pull out in front of me at the last minute. > * Oh yeah, and I picked up a '95 KA24DE with uncut harness, all accessories, ecu, maf, trans, etc, etc. Quote Link to comment Share on other sites More sharing options...
RedEvilrps13 Posted January 18, 2008 Share Posted January 18, 2008 awesome thread so far! i cant wait to see more pics.... what HP goal are you going to be shooting for? and what suspension setup will you be running? Quote Link to comment Share on other sites More sharing options...
MPD47 Posted January 19, 2008 Author Share Posted January 19, 2008 275whp+ The goal is to be right around 300whp, which is very doable with my engine selection. I've got other high HP cars and dont want to go crazy on this one (or I would've swapped an RB or LS1). It's going to be my backup track/drift car for when the 951 is down and I'm not borrowing other's cars to do drift events with. (Mostly a good friend's 350z). As for suspension, I'm in the process of acquiring front 300zx uprights to mod like stony did. And in the rear I'll do 5 lug as well. Plan is for sectioned 300zx uprights, Koni shocks, GC weld ons and Z33 brembos. (Because I have a set kicking around) Quote Link to comment Share on other sites More sharing options...
Guest proboost Posted January 27, 2008 Share Posted January 27, 2008 Nice project, looking forward to the transformation. Oh yeh is that a widebody Supra, I see in one of the pics? Quote Link to comment Share on other sites More sharing options...
MPD47 Posted January 29, 2008 Author Share Posted January 29, 2008 Thanks. Yeah it is a widebody MKIV. Haven't worked on it much because "MPD is a bag". Got working on stripping the engine bay though. Ordered a clutch, floors, subframe connectors/frame rail reinforcements, and the front subframe for the KA. Starting to clean up, paint scraper and steel wool. I also discovered a small hole in the frame rail which you can see in the bottom right of that photo. It's about an inch and a half long, by maybe 1/3 of an inch wide. Wont be a hard repair at all. Progress coming along, I'd say I have the bay 60% stripped. I still have a lot of little holes that were drilled to fill and spot welds for old brackets to drill out. A significant amount of paint has been removed though. Currently my big debate is if I should remove the stock battery tray or not since the battery is being moved to one of the rear cubby holes. Quote Link to comment Share on other sites More sharing options...
PanzerAce Posted January 29, 2008 Share Posted January 29, 2008 Unless you plan on mouting something else there, I would say ditch the battery tray. IMHO, leaving it would make the bay 'unbalanced' from a visual standpoint. Or, since you are turboing it (I think I saw that you were), maybe mount a water/methanol tank there? Quote Link to comment Share on other sites More sharing options...
Jesse OBrien Posted January 30, 2008 Share Posted January 30, 2008 Unless you plan on mouting something else there, I would say ditch the battery tray. IMHO, leaving it would make the bay 'unbalanced' from a visual standpoint. Or, since you are turboing it (I think I saw that you were), maybe mount a water/methanol tank there? I second that motion. Keep it functional, keep it clean. By the way, I just joined hybridz because of your project, keep up the gorgeous work! Quote Link to comment Share on other sites More sharing options...
MPD47 Posted January 31, 2008 Author Share Posted January 31, 2008 Thanks guys. I removed the battery tray tonight, along with all of the brackets in the engine bay. Need to do some more chemical stripping and my roommate is going to help me weld up some small holes and what not in the engine bay, then it gets painted. Hopefully early next week. Quote Link to comment Share on other sites More sharing options...
MPD47 Posted February 2, 2008 Author Share Posted February 2, 2008 not much in terms of visual progress. Spent a ton of time drilling out every bracket on the firewall, frame rails, and remaining bits of the engine bay. Ground most of them down flat, removed the battery tray, finish chemically stripping the engine bay, etc. I now need to go back over the engine bay with a wire wheel to get the remaining crap. The rubber steering bushing is being sent out to have an aluminum version made, the old one was quite hard and brittle. Basically need to go back and weld up all the holes and divots from drilling the brackets off, and tack in the crossmember with the engine test fit. That's my scatterbrained order of things right now. Hopefully I'll have everything collected to be welded this week and I can get that tacked in with Christian's help and it can go over to PMP to have the finish work on the welds done. One photo for today with the engine bay mostly torn down. Quote Link to comment Share on other sites More sharing options...
rturbo 930 Posted October 27, 2008 Share Posted October 27, 2008 Any updates on this? Quote Link to comment Share on other sites More sharing options...
MPD47 Posted November 8, 2008 Author Share Posted November 8, 2008 Sadly, no. I got busy with work and going back to school and I dont tend to work on projects during the summer (to busy driving). I'm bringing it back to my house and I'm gonna start back in on it soon. I actually had it up for sale for awhile and didnt get any serious bites (just ridiculous low balls) which made me decide to keep it. Quote Link to comment Share on other sites More sharing options...
jdizzy204 Posted November 10, 2008 Share Posted November 10, 2008 u friends with a guy who is putting a rb26 in his e30 by chance? Quote Link to comment Share on other sites More sharing options...
MPD47 Posted November 10, 2008 Author Share Posted November 10, 2008 He used to be my roommate, so yes. Neither of us could stand living there though, so we both moved out. Quote Link to comment Share on other sites More sharing options...
g9m3c Posted November 10, 2008 Share Posted November 10, 2008 Man, I've really enjoyed looking through this thread. Don't sell it man! Haha, you're well on your way to making this an awesome car. Must........not.........stop! Quote Link to comment Share on other sites More sharing options...
md614 Posted November 10, 2008 Share Posted November 10, 2008 Hey looking at that front flare. From the picture i think it goes on the passengers side. Quote Link to comment Share on other sites More sharing options...
