timbo1jz Posted November 27, 2008 Author Share Posted November 27, 2008 Quote Link to comment Share on other sites More sharing options...
The love of JDM Posted November 27, 2008 Share Posted November 27, 2008 Nice project! Quote Link to comment Share on other sites More sharing options...
timbo1jz Posted November 27, 2008 Author Share Posted November 27, 2008 Its nice too have a day off for thanksgiving, so I got a little done on the Z today. Decided that I wanted to recirculate my wastegate so I can hear the lovely sound of the 1jz. I modifyed my downpipe for the wastegate recirculation and a toyota 1jz 02 sensor. Also have the Zeitronix wideband installed. It was interesting welding on stainless steel with a shielded wire feed welder, but it came out very nice. Got it all painted and heat wrapped too. Here are some pics. Quote Link to comment Share on other sites More sharing options...
jtmny1999 Posted December 3, 2008 Share Posted December 3, 2008 What Fuel cell did you end up using? The 16 gallon or 12 gallon? Nice work BTW. Quote Link to comment Share on other sites More sharing options...
timbo1jz Posted December 3, 2008 Author Share Posted December 3, 2008 It is a 16 gallon. I forgot it was a 16 and thought I ended up with a 12, but it is a 16 gallon. Summit racing cell, with foam, sump and a 0-90ohm sending unit so it works with autometer gauges. edit: If i did it all over again, I would have gone with the 12 gallon because it leaves more room to run the exhaust with 3" piping, but it can be done either way. Quote Link to comment Share on other sites More sharing options...
7MGFORCE Posted December 8, 2008 Share Posted December 8, 2008 isnt your wideband a little to close to the turbo? it would get need to be replace much sooner at that location right? Quote Link to comment Share on other sites More sharing options...
240hoke Posted December 8, 2008 Share Posted December 8, 2008 Yup hate to tell you but those Widebands are wayyyyy to close, your gonna fry 180 bucks worth of sensors in a few minutes of driving. I would mount them down near your transmission bell housing right at the base of your DP. Swap is looking goo though, should be a beast. Q45 rear end mounting stuff looks really good. Quote Link to comment Share on other sites More sharing options...
Gritz Posted December 8, 2008 Share Posted December 8, 2008 The sensors will be fine...trust me.. Quote Link to comment Share on other sites More sharing options...
timbo1jz Posted December 9, 2008 Author Share Posted December 9, 2008 One of my friends ran it that close on his car and never had a problem, so I not too woried. My down pipe has another o2 bund furthur down, so I can move it if it becomes a problem. The other sensor is a factory Toyota O2 sensor, and they are that close to the turbo from the factory, Quote Link to comment Share on other sites More sharing options...
7MGFORCE Posted December 15, 2008 Share Posted December 15, 2008 where did you buy your fuel lines? what size? Quote Link to comment Share on other sites More sharing options...
7MGFORCE Posted December 15, 2008 Share Posted December 15, 2008 The sensors will be fine...trust me.. well the 02 sensors will be since its mounted there stock. but all over supraforums and supramania people have mounted the wideband at the bottom. close to the test pipe. but iether way its up to the owner i personally run it that close but after reading that it would roast the sensor i decided to move it back. better safe than sorry. Quote Link to comment Share on other sites More sharing options...
timbo1jz Posted December 18, 2008 Author Share Posted December 18, 2008 where did you buy your fuel lines? what size? I am running all Jegs fittings on my fuel system. They are a great price, and assemble easy. I am running a -8an feed to a bosch 044 pump, and then running a -6an feed to the fuel rail from the pump. I am running a -6an fuel return line to the fuel cell. Quote Link to comment Share on other sites More sharing options...
timbo1jz Posted December 26, 2008 Author Share Posted December 26, 2008 Got some new updates. Replaced the ball joints, wheel bearings/races, and removed the stock spring perches off the strut tubes. Got my new gound control coilovers courtesy of Edan from Silvermine motors who was a great help with setting up my suspension. He is a great guy to deal with for big brakes and suspension. Here are a couple of pics. Quote Link to comment Share on other sites More sharing options...
timbo1jz Posted December 26, 2008 Author Share Posted December 26, 2008 All of the rain we are getting here in So Cal is killing me on my progress. Anyways I got my coilovers assembled in the garage out of the rain today. Had the strut assemblies painted and the new spring perches welded on. Can't wait to get them on the car. Here are a few pics. Quote Link to comment Share on other sites More sharing options...
timbo1jz Posted December 26, 2008 Author Share Posted December 26, 2008 Installed some new Falkons on my sportmax 513's. They look sweet and hopefully be on the car within a couple weeks. This is the last leg on my suspension to be finished, so after this, then I will have it running very soon. Its all downhill from here . A couple of pics- Quote Link to comment Share on other sites More sharing options...
Gritz Posted December 26, 2008 Share Posted December 26, 2008 Great job!!! making some crazy fast progress....Those are huge tires, will they fit stock fenders...how much do you plan on lowering the car? Quote Link to comment Share on other sites More sharing options...
timbo1jz Posted December 26, 2008 Author Share Posted December 26, 2008 They are 245/50/16's all around, and I have seen this size on another members Z and they look great. They fill up the fenders nice. Quote Link to comment Share on other sites More sharing options...
RUSSJZ-ZED Posted December 27, 2008 Share Posted December 27, 2008 quote; Its all downhill from here You will find pointing it uphill is even more fun! Quote Link to comment Share on other sites More sharing options...
datsun723 Posted December 27, 2008 Share Posted December 27, 2008 I hear ya on the rain. I got to find out the hard way that my weatherstripping is shot 2 hours to have a dry Z is not fun lol. and keep up the good work! should be sweet when you're done! Quote Link to comment Share on other sites More sharing options...
timbo1jz Posted December 28, 2008 Author Share Posted December 28, 2008 Well, had a bad day today. I got all my new coilover suspenion together and evrything was going great until I got to the right rear. Couldn't for the life of me get the rear strut to line up with the lower control arm to knock the new spindle pin in. Turns out the the strut is bent pretty badly. I didn't notice it when it was out of the car, but now I can clearly see. These were bought used and I never saw them installed. I have a backup that I can use, but I need to modify it for the coilover and swap the bearings and stuff all over again, and paint it all over again. Gonna set me back some time Quote Link to comment Share on other sites More sharing options...
