80LS1T Posted December 18, 2007 Share Posted December 18, 2007 I've done a few things to mine....LOL Guy Quote Link to comment Share on other sites More sharing options...
frank280zx Posted December 18, 2007 Author Share Posted December 18, 2007 I've got a pallnet fuel rail, cold air, tokico HP springs and struts and poly bushings with a autopower roll bar going in soon. Also where do you guys get these coilovers from, I know modern motor sports has real coilovers but what about the front. also stainless steel hydraulic lines You make em yourself.. like said elswhere in this topic .. fabrication is your friend .. im still not 100% with my set up but it is an test set up as is with room for improvement over the coming years.. an yes sory 80lt1 i know you are out there and jeff.. MAck naturally i know you are out there!! so will you be at MSA 08 ? i can bring a dash for you in 09 BTW Quote Link to comment Share on other sites More sharing options...
roninjiro Posted December 18, 2007 Share Posted December 18, 2007 dont forget about meh!! im working on a ka24det with my s130 with upgraded suspension and semi/interior. i couldnt sell or get rid of my car for the life of me, not even for a s30.....lol. the 280zx is just tooo sexy imo... hint the name "marlene" for mine. and marlene is in for a treat when i get back from iraq Quote Link to comment Share on other sites More sharing options...
badjuju Posted December 18, 2007 Share Posted December 18, 2007 It's got such a badass motor, and it really was (imo, der) one of the nicest sports cars of the 80s, the only ones I like from that era are datsun and porsche (delorean?), I bought mine because of how tremendously badass they look, and it had a turbo and t tops to start with. I fell in love all over again with the s30, though, so now I'm banging my first car's older sister, I'm sure she's upset about it. Quote Link to comment Share on other sites More sharing options...
Mack Posted December 18, 2007 Share Posted December 18, 2007 yeah, I forgot to mention my current mods. MS&S_E running fuel and spark Maxima N47 head on flat top F54 block, slight port & polish, 260Z cam 1980 non EGR manifold port matched 60MM TB custom 2.5" cat back mandrel bent exhaust '87 clsd in a 90 M30 pumpkin with 3.9 gears 240sx 5spd trans 130mph speedo (not really a mod, but looks cool!) as far as coilovers, the rears for a 240SX are bolt on as long as you re-drill the top mount for 3 bolts instead of 2. Fronts will be tricky. basically, what I will be doing is modifying a 280ZX lower control arm to put 240SX spindles on it, then I can use the SX front coilovers as well. Problem is, they are 4" shorter than ZX units, so Ill have to make a 4" extender for it up top. then I can also retain the camber plates. With the 240SX front hubs, I can use 300ZXTT rotors redrilled for 4 lug and 300ZXTT 4 piston aluminum calipers. For the rear suspension, I will be removing the rear crossmember and slotting the trailing arm bolts to allow for toe and camber adjustment. then I will be using infiniti M30 rear arms and CV axels. The M30 rear arms because they already have the bigger bolt holes to use 300ZX eccentrics. The infiniti also has much larger rear brakes. fabrication and slight modification of other nissan parts. Ive learned all of this knowledge from a few years of kicking around u pull it type of junk yards and just looking and measuring ♥♥♥♥. plus, Ive owned 240SXs, 200SX's and a lot of other nissan cars that share similar parts and set-ups. How do you think I had the epiphany about the KA heads an L-seris block? Quote Link to comment Share on other sites More sharing options...
260DET Posted December 20, 2007 Share Posted December 20, 2007 Front struts and brakes are on, brakes are a Stoptech S14 big brake kit, struts are custom MCA Proflex three way adjustables. EDIT: this S130 has S14 suspension all round. Quote Link to comment Share on other sites More sharing options...
Spraguepsycho1 Posted December 20, 2007 Share Posted December 20, 2007 Just out of curiosity, how much does a set of custom struts and springs like that run, and did you get a set for all 4 corners or just the front? Seems nearly impossible to find much for the rears on the ZX as far as off the shelf stuff goes. I wanted to go adjustable all the way around on my '82 but can't find nuttin. Quote Link to comment Share on other sites More sharing options...
nbesheer Posted December 20, 2007 Share Posted December 20, 2007 http://www.modern-motorsports.com/catalog/product_info.php?products_id=66&PHPSESSID=144c5049ae1aee8e55a52ff31a459510 Quote Link to comment Share on other sites More sharing options...
djz Posted December 20, 2007 Share Posted December 20, 2007 I haven't got any decent pics of my car, but its constantly a work in progress. Its a '78 Fairlady 280Z. I want to keep the body reasonably stock, except for the front kit. The rear wiper & washer have been removed, other mods are: '83 front crossmember & rack and pinion power steering '83 rear crossmember & CV half shafts, brakes, R31 Skyline R200 LSD R31 Skyline front struts, Z31 5 stud hubs, R32 Skyline 4 piston calipers New KYB front inserts, new KYB rear shocks w/lowered springs all round 17x8 & 17x9" wheels, 235/45/17 front & 255/40/17 rear Toyo Proxes Motor has been bored 3.5mm over LD28 crank, Z24 pistons, L20ET rods, N42 block & head 2mm metal head gasket Head has been port matched, cam has been ground, VG30ET valve springs Stock turbo exhaust manifold, HKS T3/T04 adaptor w/built in external wastegate TA51/T04 hybrid turbo, 0.70 a/r exhaust housing Pallnet fuel rail, Mitsubishi GSR injectors (370cc) R32 Skyline RB20DET fuel pressure regulator Mitsubishi VR4/Evo twin post coils R30 Skyline L20ET distributor, Z31 VG20ET chopper plate Link V5 computer Remote mount oil filter & cooler 450x300x76 intercooler (have a bigger one to go in, 130mm thick!) 2.5" intercooler piping 95 amp alternator, off a Maxima or something HKS blow off valve Exhaust is currently 2.5" but I'll be getting a 3" mandrel bent one made after Christmas. R31 RB30 flywheel & heavy duty clutch R32 GTSt Skyline gearbox (FS5W71C) Thats about all I can remember at the moment, theres probably other stuff. Heres a little video for your viewing pleasure, this is before the 5 stud conversion and with my old (tiny) T04B turbo, with this setup it was making 278hp @ the wheels on 12psi. http://www.youtube.com/watch?v=_ZGvQHMHrWU Quote Link to comment Share on other sites More sharing options...
hughdogz Posted December 20, 2007 Share Posted December 20, 2007 ^^^ that has to be one of the coolest S130's i've seen! Any more pics of the front body piece? Quote Link to comment Share on other sites More sharing options...
djz Posted December 20, 2007 Share Posted December 20, 2007 I've only got this really old picture taken a couple of months after I bought the car Quote Link to comment Share on other sites More sharing options...
hughdogz Posted December 20, 2007 Share Posted December 20, 2007 Right on..thanks! It looks like you might have done a shaved fender mirror mod too? Quote Link to comment Share on other sites More sharing options...
nbesheer Posted December 20, 2007 Share Posted December 20, 2007 Wow love that S130, love that starion, love those wheels (old ones) it's just amazing... also what happened to your fender mirrors. You should help a kid in need (me) with those left over mirrors Quote Link to comment Share on other sites More sharing options...
stprasinz Posted December 20, 2007 Share Posted December 20, 2007 where did you get that front bumper??? Thats the baddest one I've seen... Is it custom? If not where can I get one... Or is that stock JDM??? either way sweet. Quote Link to comment Share on other sites More sharing options...
260DET Posted December 21, 2007 Share Posted December 21, 2007 Where are the pics of mods, c'mon S130 dudes. Quote Link to comment Share on other sites More sharing options...
Mack Posted December 21, 2007 Share Posted December 21, 2007 HA! all my mods look like every other stock part, cept the trans is a little different and the megasquirt looks like a rats nest. If you dont mind me asking, 260DET, how did you put S14 front spindles on your 280ZX? custom lower control arm? the angle of the ball joing on the S130 and the angle for the ball joint on the S13/14 makes it very difficult to bolt on. Quote Link to comment Share on other sites More sharing options...
frank280zx Posted December 21, 2007 Author Share Posted December 21, 2007 HA! all my mods look like every other stock part, cept the trans is a little different and the megasquirt looks like a rats nest. If you dont mind me asking, 260DET, how did you put S14 front spindles on your 280ZX? custom lower control arm? the angle of the ball joing on the S130 and the angle for the ball joint on the S13/14 makes it very difficult to bolt on. Haha show me pictures BTW 260Det i have 380lb springs i see you have 400s? Quote Link to comment Share on other sites More sharing options...
slownrusty Posted December 22, 2007 Share Posted December 22, 2007 Here are some pics of my stock 150whp 280ZX...its *really* slow, handles horribly and has terrible brakes... Yasin Quote Link to comment Share on other sites More sharing options...
80LS1T Posted December 22, 2007 Share Posted December 22, 2007 Stock and slow my aZZ! LOL Is your car getting close to being back on the road, Yasin? I'm getting ready to rip my interior out to put a painless harness in! Oh boy what fun! After thats done I'm dropping out the rear subframe to slot it and put cam bolts in so I can get rid of the excessive negative camber in the rear. Once that's done I'm going to be installing a nitrous kit. Those are my projects for the next 4-5 months till the snow melts around here! http://www.datsun-280zx-lt1.com/Recent_pics.html Guy Quote Link to comment Share on other sites More sharing options...
roninjiro Posted December 22, 2007 Share Posted December 22, 2007 slownrusty coilover conversion Slightly modified crossmember for the KA Trial fitting fitting after paint mock fitting of almost everything and the updated interior a lot of the stuff ive done will be redone, because i didnt have much in funding at the time (charge piping,interior,suspension, etc.) Quote Link to comment Share on other sites More sharing options...
