intercooler recommendations? 280zxt
azZdriver
what intercooler should i use for my 280zxt? is there anything decent that i might be able to score cheap at a junk yard? not interested in a $1k kit. i'm only aiming for around 260 hp for a nice cruising car at around 15 psi??
For junkyard intercoolers, theres always the starion one, but i'd recommend getting one off ebay. Some decent stuff for under $200. While your on ebay, order yourself some piping.
thanks dog...
Just messin' with ya! :wink:
This is probably already covered in the Turbo FAQ sticky but I'll give you my opinoin here.
Most of the IC's from the J-Y's are too small. For example I've heard the Volvo, Starion, etc. IC's are too small for the 2.8L. Once exception might be the Porsche 944 IC but still it is still pretty small.
If you can get a hold of an Isuzu NPR IC (either a large or small unit) you should be fine.
Also on Ebay, you can buy a decent Chinese knockoff for ~$150 so why even mess with a used IC unless it is from a big diesel engine?
Just my $0.02. good luck!
