What Drill Bits To Use For Fiberglass?
slownrusty
  • 4 weeks later...
When I need an exact size I will use masking tape and a good sharp HSS drill bit.
I sometimes drill a smaller hole and then file it to the size needed.
If I just need a close to proper size hole (for mounting or where a washer will be used), I'll use a unibit or similar hole making device. I find that the ones I biuy from Princess Auto under the Power Fist name work better than the Unibit name brand bit. Two flutes in the Power Fist version, and seems to stay sharp longer and cut better because of the two flutes.
Unibit and tape is very good info. Another process for thin fiberglass that tends to twist and tear even with a sharp bit; drill your hole way undersize and open it up to your scribed lines on the tape with your dremil or die grinder and carbide burr.
Chris
