timbo1jz Posted February 5, 2008 Share Posted February 5, 2008 well not quite that easy. The later style round supra mounts will work on the 2jzgte install kit, but the stud on the bottom of the mount uses a 17mm nut while the 2jz mount uses a 19mm nut, so the stud is a little smaller. You can use the 89+ mounts fine ,just use a big washer at the bottom to accompany the smaller stud. If you want to use 2jz mounts on a 1jz or 7mgte like I did, you will have to grind off the little offset locking pin on the motor mount so it will allow it to bolt up. Quote Link to comment Share on other sites More sharing options...
Guest allight Posted February 5, 2008 Share Posted February 5, 2008 ^^Will the later style mounts mount up to an older engine? I got a little confused with this post as well, I think he is talkin rubber mounts, I cant see how a 7m is going to drop in and line up/ motorsports infermation says will only fit like 1year 2j , so just on a 2j you need brackets from that year soupra. import ones not the same need local. anyone gonna do some mulifits? the guy in ozzie isnot intrested. Quote Link to comment Share on other sites More sharing options...
timbo1jz Posted February 5, 2008 Share Posted February 5, 2008 I got a little confused with this post as well, I think he is talkin rubber mounts, I cant see how a 7m is going to drop in and line up/motorsports infermation says will only fit like 1year 2j , so just on a 2j you need brackets from that year soupra. import ones not the same need local. anyone gonna do some mulifits? the guy in ozzie isnot intrested. huh??? Quote Link to comment Share on other sites More sharing options...
theianmonster Posted February 6, 2008 Share Posted February 6, 2008 The cross member is alright. The tubes should be gusseted to the L-plate, but whatever. I hope this swap doesn't become that popular. Its kind of nice only having a few of us running around. Quote Link to comment Share on other sites More sharing options...
Guest TeamNissan Posted February 6, 2008 Share Posted February 6, 2008 The cross member is alright. The tubes should be gusseted to the L-plate, but whatever. I hope this swap doesn't become that popular. Its kind of nice only having a few of us running around. Thats not a nice attitude to have, greedy. Quote Link to comment Share on other sites More sharing options...
RUSSJZ-ZED Posted February 6, 2008 Share Posted February 6, 2008 huh??? I think what he is trying to say is that unless you have the brackets from the USA edition Supra(the Lexus/ Aristo, and all the 1Js are different)It probably won't lineup. I have explained to him several times I am not interested in making him a set for a 1J, (need to set up for LHD rack for starters,simple, but I have better things to do) Allight, a badly trained monkey can make these in a day.......your time starts .....Now! Quote Link to comment Share on other sites More sharing options...
badjuju Posted February 6, 2008 Share Posted February 6, 2008 The cross member is alright. The tubes should be gusseted to the L-plate, but whatever. I hope this swap doesn't become that popular. Its kind of nice only having a few of us running around. You know... Seeing that you're in Redmond, and you've got this swap done, I'd really like to be your friend... lol Can we meet up sometime so I can pick your brain a little? Quote Link to comment Share on other sites More sharing options...
Gritz Posted February 13, 2008 Share Posted February 13, 2008 Im torn...1jz in a s13 or 1jz in a 240z???.....I just hard to find a 240z thats not rusted to hell under a grand...im too cheap i guess...lol Quote Link to comment Share on other sites More sharing options...
badjuju Posted February 19, 2008 Share Posted February 19, 2008 s30. preference on looks. I think it's more of a muscle-looking car Quote Link to comment Share on other sites More sharing options...
Gritz Posted February 19, 2008 Share Posted February 19, 2008 A 240z sure would be faster the hp caculator has the 240 running 11.2 in the 1/4 with only 350hp...wow!! I know where a 73 is right now that runs good for only $500 obo..... Quote Link to comment Share on other sites More sharing options...
badjuju Posted February 19, 2008 Share Posted February 19, 2008 if you're looking to put 350hp to it, don't pay attention to how well it runs, it won't be running that motor setup when you hit your goal. If you're looking to run 350 hp through the chassis, pay attention to the body. jab at the floorboards with a screw driver and see what happens. look for rust on the subframe. $500 for a "well running car" means the rest of the car is probably shot. Quote Link to comment Share on other sites More sharing options...
Gritz Posted February 23, 2008 Share Posted February 23, 2008 if you're looking to put 350hp to it, don't pay attention to how well it runs, it won't be running that motor setup when you hit your goal. If you're looking to run 350 hp through the chassis, pay attention to the body. jab at the floorboards with a screw driver and see what happens. look for rust on the subframe. $500 for a "well running car" means the rest of the car is probably shot. I see your point..but if find one that runs, then i could sell the motor, and pick up a couple of hundred right there....either way i want one real bad but i don't have the time for a swap and major resterestion....Which is the reason im considering a s13/s14 because thats really the only other "light" RWD car i like...theres the Fc rx-7 turbo II which i like, but my brother has that....Anyway sorry to thread jack.... For the guys that did the swap..is there a way to mod the stock s30 mounts to work..is it feasible? Quote Link to comment Share on other sites More sharing options...
Z-Noob Posted February 27, 2008 Share Posted February 27, 2008 When's the tranny mount coming? Quote Link to comment Share on other sites More sharing options...
johnc Posted February 27, 2008 Share Posted February 27, 2008 When's the tranny mount coming? Which tranny (6 speed, 5 speed, Turbo 400, 4L80E)? Which model year 240/260/280Z? I'll sell you some flat plate, some square tube, and an industrial mahcine mount and you can build it yourself... Quote Link to comment Share on other sites More sharing options...
Z-Noob Posted March 4, 2008 Share Posted March 4, 2008 Which tranny (6 speed, 5 speed, Turbo 400, 4L80E)? Which model year 240/260/280Z? I'll sell you some flat plate, some square tube, and an industrial mahcine mount and you can build it yourself... 5 speed in a 240. You have 2 weeks..Thanks:D Quote Link to comment Share on other sites More sharing options...
badjuju Posted March 5, 2008 Share Posted March 5, 2008 I see your point..but if find one that runs, then i could sell the motor, and pick up a couple of hundred right there....either way i want one real bad but i don't have the time for a swap and major resterestion....Which is the reason im considering a s13/s14 because thats really the only other "light" RWD car i like...theres the Fc rx-7 turbo II which i like, but my brother has that....Anyway sorry to thread jack.... For the guys that did the swap..is there a way to mod the stock s30 mounts to work..is it feasible? That couple of hundred won't pay for the frame repairfloorboards you'll need. The way clifton is suggesting uses the stock mounts. Find a good body'd car (is that a word?) for a grand, and start from there. Quote Link to comment Share on other sites More sharing options...
jeeper42 Posted April 11, 2008 Share Posted April 11, 2008 Anyone have some 2JZ mounts that I can use to put my 7M on this crossmember?? Quote Link to comment Share on other sites More sharing options...
john turner Posted May 19, 2008 Share Posted May 19, 2008 am thinking of installing a 2jzge engine in my 72z. curious as to whether john c's motor mount is low enough to mount na engine without hood interferance problem???? love my z....have great engine.....don't want turbo......really like the idea of more calm power. comments.....thanks, john t.. Quote Link to comment Share on other sites More sharing options...
