dig280z Posted March 23, 2008 Share Posted March 23, 2008 nice nice !!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted March 23, 2008 Share Posted March 23, 2008 are these numbers after tuning and a few pulls?! or street tune and dyno numbers?! by the way... VIDEO?!?!? Quote Link to comment Share on other sites More sharing options...
big-phil Posted March 23, 2008 Author Share Posted March 23, 2008 dude, if you seriously cant find another intake mani. just shoot me a PM and i can get you one pretty dam cheap...aftermarket? I can get a truck bed full of stock ones. Quote Link to comment Share on other sites More sharing options...
big-phil Posted March 23, 2008 Author Share Posted March 23, 2008 thats all street tune, then dyno pulls. Here is the video Quote Link to comment Share on other sites More sharing options...
big-phil Posted March 23, 2008 Author Share Posted March 23, 2008 here is the dyno sheet Quote Link to comment Share on other sites More sharing options...
big-phil Posted March 23, 2008 Author Share Posted March 23, 2008 see at about 4500rpm I'm still on the gas but everything just starts falling off? Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted March 23, 2008 Share Posted March 23, 2008 If you look at your afr's they are starting to get richer and richer and richer at 4500 and hence your power is decreasing. so you might want to do some more tunning and it looks like you need to back your fuel off some. but then again i guess that could be your meth. kicking in. and im not sure how your supposed to have it tuned for when that kicks in.l Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted March 23, 2008 Share Posted March 23, 2008 Oh and please tell me you where data logging during those runs! Quote Link to comment Share on other sites More sharing options...
hoov100 Posted March 23, 2008 Share Posted March 23, 2008 aftermarket? I can get a truck bed full of stock ones. ahh ok, i thought you just couldnt get a hold of a stock one Quote Link to comment Share on other sites More sharing options...
ktm Posted March 23, 2008 Share Posted March 23, 2008 jeffer949, you tune for 10.8 to 11. As I stated before, his AFR at 10.1 to 10.3 is too rich. Phil, like BRAAP and others have said, your stock manifold is what is causing your power to drop off after 4500 RPM. Nearly everyone running the same stock manifold experiences the same curve. My curves look just like yours. Quote Link to comment Share on other sites More sharing options...
jgkurz Posted March 23, 2008 Share Posted March 23, 2008 John,Are your intake runners ported or as cast? For some reason I always thought your runners were extensively ported which helped boost your HP numbers a bit compared to your torque. My N42 intake has the throttle body mount extensively ported and the runners are port-matched slightly and blended. The runners don't have much done. My cylinder head has the runners port-matched and my valves are back-cut. That's it really. I honestly think Phil can make big improvements without going through the trouble of going to a custom intake. The stock intake, ported or not, is done at about 5500rpm not 4500rpm. I've seen this over and over on dyno sheets and in different cars. This is just my opinion, but I'd look somewhere besides the intake manifold. Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted March 23, 2008 Share Posted March 23, 2008 Thanks KTM. I tune my motor for 11.5:1 to 11.8:1 under high boost. I just havent done my research as far as meth goes yet. I need to since im going to be putting a HY35W on this week. Quote Link to comment Share on other sites More sharing options...
jgkurz Posted March 23, 2008 Share Posted March 23, 2008 Phil, Here's an example of a car that made 400rwhp with far less mods than you or I have. Remember Morgan Fruchtnicht's budget build in the Fall 2002 issue of Sport Z magazine? It's the same issue that featured JeffP's car. http://z31.com/~morgan/oldz/ My point is that you should have all the right parts to get to your goal.... You just need a few more tweaks. I know how frustrating it is to be so close to your goal. Let me know how I can help. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted March 23, 2008 Share Posted March 23, 2008 Install that cam of yours... and a lonewolf intake =) or somethin like that.. Those numbers might explain why the transmission hasn't blown up yet lol Quote Link to comment Share on other sites More sharing options...
big-phil Posted March 23, 2008 Author Share Posted March 23, 2008 Oh and please tell me you where data logging during those runs! yes I was Quote Link to comment Share on other sites More sharing options...
big-phil Posted March 23, 2008 Author Share Posted March 23, 2008 Thanks guys. I'll try to lean it out a little up top/ I also need to find out what size meth nozzle I have and what I need to have. That big cam I have really kills the low end. Yes my stock cam is timed right. Quote Link to comment Share on other sites More sharing options...
OlderThanMe Posted March 23, 2008 Share Posted March 23, 2008 Phil, At what RPMs does your meth come on? You said 14PSI but where do you hit 14PSI at in the RPM band? Quote Link to comment Share on other sites More sharing options...
big-phil Posted March 23, 2008 Author Share Posted March 23, 2008 Phil,At what RPMs does your meth come on? You said 14PSI but where do you hit 14PSI at in the RPM band? I'll have to look at my data logs Quote Link to comment Share on other sites More sharing options...
Thumper Posted March 25, 2008 Share Posted March 25, 2008 Phil, You should be able to get an extra 10hp from leaning out the gas on the big-end but at the same time get the lean spot 11.8:1 taken car of as well. Its right at your torque peak so that makes since. Then you will be able to add timing. Remeber the main thing extra fuel does is slow the combustion down alittle so its just like you retarded timing. It also cools off the combustion alittle bit but its returns are reduced at a certain point. So get the a/f's line steady and you should be able to pick up a good 10hp. Also don't know if you know this but you can add timing after torque peak to pick up top-end power as well. Too give you an idea at DNI getting Gabes a/f's from lows 11's to high 11's and adding 4 degrees of timing he picked up 3-4?mph in his traps. Which is about 15hp. Quote Link to comment Share on other sites More sharing options...
Sideways Posted March 25, 2008 Share Posted March 25, 2008 Hey bigphil if you have access to the file would you show the dyno sheet with boost at the bottom? Quote Link to comment Share on other sites More sharing options...
