silver280zx Posted May 20, 2008 Share Posted May 20, 2008 I have a 79 model with suspension techniques springs and swaybars, illumina struts in front, and kyb gas adjust shocks in back. Does anyone have any good custum alignment settings? Quote Link to comment Share on other sites More sharing options...
hughdogz Posted May 20, 2008 Share Posted May 20, 2008 Only the front toe is adjustable on S130's. Quote Link to comment Share on other sites More sharing options...
Clifton Posted May 20, 2008 Share Posted May 20, 2008 What do you mean custom? Are you doing it yourself? Are you autoXing or tracking it? If it's a street car I would put a street car alignment on it and be happy. IMO, an alignment to get the extra 10% of handling out of it that you will never notice on the street as you can't push it 100% on the street will make the car 50% worse to drive the street. Wandering, wearing tires unevenly, ect. Quote Link to comment Share on other sites More sharing options...
m1ghtymaxXx Posted May 21, 2008 Share Posted May 21, 2008 I have a 79 model with suspension techniques springs and swaybars, illumina struts in front, and kyb gas adjust shocks in back. Does anyone have any good custum alignment settings? like hughdog mentioned, how do you plan to adjust everything but the front toe? Quote Link to comment Share on other sites More sharing options...
silver280zx Posted May 22, 2008 Author Share Posted May 22, 2008 I was just wondering about like camber settings and such. This is what i meant by "custum alignment". The car is an autox car, it is also driven on the street about half the time. Should i run -1 degree of camber all the way around? Im trying to get it to handle well and not wear on the outside as much when i corner, and yes I am running enough pressure in my tires when i autox, i run about 36psi. Quote Link to comment Share on other sites More sharing options...
Clifton Posted May 22, 2008 Share Posted May 22, 2008 If you have camber plates you can crack it in at the track, if not 1* for both would be good without too much wear. I would do a street toe setting, toeing out for autoX helps but unless you are a front runner don't bother. If you are only running 1* in the front I would run more front pressure, especially if it has softer springs and sway bar. If they are anything like S30 Z's I would start at 42 psi min front, rear you can get away with less. Quote Link to comment Share on other sites More sharing options...
silver280zx Posted May 23, 2008 Author Share Posted May 23, 2008 So can the camber not be adjusted on the stock setup, without the camberplates? I know miatas camber can be adjusted on stock suspension, can s130's not? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted May 23, 2008 Share Posted May 23, 2008 The only adjustment out of the box is front toe as was already stated. You can look into camber plates, custom TC rods, and slotting the crossmember for more adjustability. It's not bolt on stuff so be prepared to do some fabricating and cutting to get it done. Quote Link to comment Share on other sites More sharing options...
