240hoke Posted December 17, 2009 Share Posted December 17, 2009 Man those Scott wires are SEXY. Nothing like some cup motor parts on a L6 I just zipp tied them together on my setup, you can really get them streamlined and out of hte way: http://gallery.voodoo-people.com/albums/album915/verticle_IC_018.sized.jpg Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted December 17, 2009 Author Share Posted December 17, 2009 Yeah they are sexy, I need to get some others made up since my coil packs are mounted different from where you had them. The spacers are working, I just didn't want to bundle them together. Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted January 14, 2010 Author Share Posted January 14, 2010 ITB's are back in the mail and should be back home in a couple of days. Following Austin's suggestion I ordered some relay connectors, spare relays and other misc things to clean up the wiring some more from Wayteck Wire. Thanks bro Quote Link to comment Share on other sites More sharing options...
EvilC Posted January 14, 2010 Share Posted January 14, 2010 Looking forward to pics of the new setup. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted January 14, 2010 Share Posted January 14, 2010 Im excited for pics too! Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted January 17, 2010 Author Share Posted January 17, 2010 Fed Ex showed up around 6pm last night. Fresh out of the box. One problem with the fuel injectors I have they are #42 Ford Part# 0-280-150-558. Apparently they have the smaller o-rings installed on them which makes them loose when mounted. I have been searching for what size they are (black on bottom, blue on top). I guess I need to hit the parts store and get a few different ones to see what works. Quote Link to comment Share on other sites More sharing options...
notheredave Posted January 19, 2010 Share Posted January 19, 2010 notheredave said: Cool looking project I am looking to do ITD's on a L28T (have) or a 1uz and found this awsome 2.4L 20,000rpm :burnout:You tube: http://www.youtube.com/watch?v=AKyP19ky_W0&NR=1 Enjoy Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted January 27, 2010 Author Share Posted January 27, 2010 Re-painted, detailed the Mikuni manifold: ITB's with new linkage setup mounted, 15.2mm GM LS2 FI o-rings are tight no play on these injectors at all: One little snafu, the front throttle arm is hitting the thermostat housing: With some quick pictures sent to Kevin at Extrudabody yet again great customer support!! He suggested to adjust the heim joints and if they don't get the rail high enough he'll send me some spacers or trim the throttle arm. More to come.... Quote Link to comment Share on other sites More sharing options...
akuma-z Posted January 27, 2010 Share Posted January 27, 2010 I love this build. I just started sourcing parts for a similar project. I am glad to hear that extrdabody stands behind their products. Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted January 31, 2010 Author Share Posted January 31, 2010 With some guidance from Kevin, I tried to adjust the heighth. It clears with the heim joints all the way raised, no threads for the nut...damn. Needless to say yet again excellent customer support!! he is sending me 15mm spacers. I am not giving up, more to come... I started messing with the throttle cable. I'm going to attempt to attach it to the stock pedal vice using the Savage bracket and other route since the cable loops too funky... FYI the 240Z gas pedal is already slotted for a cable. I don't really like this, still messing with it: Quote Link to comment Share on other sites More sharing options...
EvilC Posted January 31, 2010 Share Posted January 31, 2010 Glad to hear you are getting excellent customer service. Quote Link to comment Share on other sites More sharing options...
Dtsnlvrs Posted February 11, 2010 Share Posted February 11, 2010 Well, I am assuming there are no new updates due to the MASIVE amounts of snow between the house and the garage...lol Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted February 13, 2010 Author Share Posted February 13, 2010 Dtsnlvrs said: Well, I am assuming there are no new updates due to the MASIVE amounts of snow between the house and the garage...lol Buck, I am officially done shoveling until the next freakin Snowpocalypse as of today. I received my parts from Kevin @ Extrudabody on Thursday: (3) 15mm spacers and longer socket (allen) bolts. I plan on getting back in the garage over this long weekend since my path is finally shoveled to it. Quote Link to comment Share on other sites More sharing options...
slownrusty Posted February 14, 2010 Share Posted February 14, 2010 Beautiful brother J! Those ITBs are so so sexxxy...! Love them! Sorry that the snow has been horrid this year. Yasin Quote Link to comment Share on other sites More sharing options...
FricFrac Posted February 14, 2010 Share Posted February 14, 2010 Dtsnlvrs said: The Power resistor mod IIRC is used to enable a 260-280 tach to work with a MSD. The 240 has a CURRENT triigered tach not a VOLTAGE triggered tach, no resistor mod will ever get it to work with a square wave signal...you MUST create a "false" coil draw for the tach to FEED in order for it to work. http://www.msdpowersports.com/pdf/frm22049_pn8920.pdf IMHO in a 240 the options are...buy the 60 buck part and wire it in as per MSD, or buy all new gauges..cause lets face it, having just the tach non stock is kinda tachy Oh and BTW, the adapter makes the stock tach VERY stable and VERY accurate. I've got the power resistor working in my '72 240Z. The resistor mod is for current triggered tachs - I'm not sure what the 260-280Z are. The 240Z tach is current triggered which is why you use the resistor to draw enough current to trigger the tach I mounted it all on a custom aluminum plate and painted it the same colour as the car so I can easily return it to stock if need be. Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted February 18, 2010 Author Share Posted February 18, 2010 Just purchased a Laminova Oil to Water Heat Exchanger A43-180 - Medium: 180mm. I also purchased another oil sandwich plate since I upgraded to -8 from -6 on the Earl's I currently have. I also purchased some nomex/kevlar braided line and light alloy swivel AN fittings. Shipping tomorrow http://www.batinc.net/mocal-central.htm middle one in picture. Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted February 18, 2010 Author Share Posted February 18, 2010 slownrusty said: Beautiful brother J! Those ITBs are so so sexxxy...! Love them! Sorry that the snow has been horrid this year. Yasin Thanks brutha, after 2 weeks the snow is still everywhere. More snow is coming next week grrr.... Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted February 24, 2010 Author Share Posted February 24, 2010 I worked on the ITB and throttle linkage and while waiting on the heat exchanger, and decide to use the stock firewall pivot arm. I purchased the Savage firewall mount and decided to go with it. Throttle Cable Linkage: First I drilled out the ball: Then I bolted this to it: Here it is mounted, greased ready to go: I bolted it to the Savage piece on the firewall: End result: ITB Linkage: I installed the 15mm spacers: Leveled the heim joints, it clears with plenty of space and threads poking out the bottom for the nuts on the bracket for the heim joints: Heat Exchanger should be delivered tomorrow. I have some more wiring to do and clean up work. Come on Spring I am tired of the snow!! Quote Link to comment Share on other sites More sharing options...
Dtsnlvrs Posted February 24, 2010 Share Posted February 24, 2010 Looking good Joe. At this rate, you may be able to drive it out and help me prep my car for the 2012 Auto-X Season... Quote Link to comment Share on other sites More sharing options...
S30TRBO Posted February 24, 2010 Author Share Posted February 24, 2010 On 2/24/2010 at 2:22 AM, Dtsnlvrs said: Looking good Joe. At this rate, you may be able to drive it out and help me prep my car for the 2012 Auto-X Season... Roger that, I might even be boosted by then who the hell knows. I hope to have it running for you to hear before you roll out. It's only a 20 hour drive (like driving to Florida and then some) when you get short lets start planning it I have over 120 hours of leave now. HA! Quote Link to comment Share on other sites More sharing options...
