hughdogz Posted July 18, 2008 Share Posted July 18, 2008 Check this out: I wonder if it is better aerodynamically, because the type II airdam slopes up towards the front... Quote Link to comment Share on other sites More sharing options...
sticky280zx Posted July 18, 2008 Share Posted July 18, 2008 really it just looks like they made it a little lower/bigger opening for an intercooler...and added a fog light hole...too many lights if you filled those in so it get a thumbs down from me...why mess with something that was good to go in the beginning? Quote Link to comment Share on other sites More sharing options...
Challenger Posted July 18, 2008 Share Posted July 18, 2008 Wow, it looks exactly the same. MSA is really creative. Quote Link to comment Share on other sites More sharing options...
280Z Turbo Posted July 18, 2008 Share Posted July 18, 2008 I see they still have that big gap between the hood and air dam. Quote Link to comment Share on other sites More sharing options...
aziza z Posted July 18, 2008 Share Posted July 18, 2008 Notice the modified zg flairs in the bottom corner? Pretty neat I think. Quote Link to comment Share on other sites More sharing options...
Mauisnow13 Posted July 18, 2008 Share Posted July 18, 2008 I think I'll be getting some of those ZGs. I like them a lot. Quote Link to comment Share on other sites More sharing options...
slownrusty Posted July 18, 2008 Share Posted July 18, 2008 Hugh - So the only difference between the Type III and II is the round foglight or brake duct holes? Regards - Yasin Quote Link to comment Share on other sites More sharing options...
woldson Posted July 18, 2008 Share Posted July 18, 2008 Very nice! Appears that the original bumpers stay intack! Quote Link to comment Share on other sites More sharing options...
roye@hrewheels.com Posted July 18, 2008 Share Posted July 18, 2008 I see they still have that big gap between the hood and air dam. Is that gap needed for the articulation of the hood? RE Quote Link to comment Share on other sites More sharing options...
plexus Posted July 18, 2008 Share Posted July 18, 2008 thats a nice fined Quote Link to comment Share on other sites More sharing options...
hughdogz Posted July 18, 2008 Author Share Posted July 18, 2008 Hugh - So the only difference between the Type III and II is the round fog light or brake duct holes Regards - Yasin Yasin' date='[/color'] From what I can tell, there are a few differences. I think they basically took the below bumper portion from the S30 type III and the upper portion from the S130 type II. This means: Type III has foglight / brake duct holes. If this isn’t appealing or useful, they can be filled-in The opening is bigger than the type II, which may or may not be better (cooling versus aero) The lower lip protrudes forward more than the type II. I like this better since it is almost a splitter now The bottom doesn’t appear to “slope up†towards the front as much as a type II. You might even be able to run a real splitter, since it will be nearly horizontal I think they might have changed their vendor, since a buddie of mine recently installed a brand-new type II on his ZXR and said it wasn't quite symmetric as to how far the bumper sticks out below the headlight nacelle / bucket?? roye@hrewheels.com, the gap is there from the factory, but it doesn't look quite so big OEM. There is a piece of black rubber that is attached to the underside of the hood, that "closes" the gap. With these front fascias, there could be a slight issue with interference when the hood opens and closes. It works fine on mine, but it seems to not work so well on the newer type II's (I know two ZX's that have this problem). It is probably in how tight you install the airdam. You may have to trim the rubber piece down a bit. The pic is of the prototype, they probably still have some minor tweaking to do. Overall, I think it is great and MSA is showing some love for the ‘ol 280ZX’s. I think biggest factor is in the installation. I’ve seen examples where the fascia is not only glassed-in, but you can fasten it tight up against the headlight buckets, and mold it in so there is no gap (like Heat’s Mach5). Same goes for the rear valance / fascia…I think it looks much cleaner if you eliminate the gap(s). It’s way more work, but it looks so much cleaner… Quote Link to comment Share on other sites More sharing options...
VinhZXT Posted July 18, 2008 Share Posted July 18, 2008 it doesn't require that much work to eliminate the gap. Just ask Guy.. http://forums.hybridz.org/showthread.php?t=119802&highlight=Vinhzxt%27s+mod Yes I like this one better than the type II one Quote Link to comment Share on other sites More sharing options...
Mayolives Posted July 19, 2008 Share Posted July 19, 2008 I like it and my thanks to MSA for support of the sometime unloved zx. My 82 would look real good with that peice installed! Quote Link to comment Share on other sites More sharing options...
woldson Posted July 22, 2008 Share Posted July 22, 2008 articulation Nice word can be used for many instances related to MANY matters concerning mechanisms of the z's. I will have to use that in the future. Quote Link to comment Share on other sites More sharing options...
