VIDEO Chris and I race!!!!!
big-phil
If you don't no, Chris's car made 402whp at 17psi. here is his dyno pull
My car made 342 whp at 25psi. here is my dyno pull
We are both on our way to ALL Z in Ft. Worth to put my new ACT pressure plate in (
After him playing with me like a Gazel and Lion, I shot this video with my phone. Its a pull in third, from about 60mph. 25psi for me, and 17 psi for Chris. I changed my methanol L.E.D. from green to white, you can see the white light showing the meth spraying!!!!
Nice. There's no shame losing to Chris car :-D. How's the tune on your car Phil? We're you able to clean up the top end at all?
I cleaned it up a bit, and have new plugs as of last week. its still rich up top, but not AS bad.
when i upgraded from my R180 that had a 3.36 i went with a 3.7 r200 lsd. loved the lsd but HATED the gearing and so did the turbo motor. I had a 3.54 r200 out of my parts car so i swapped the lsd carrier over to the 3.54. It is so much better. you dont have to shift as much as with 3.7. its worth the effort but i still will buy a 3.36 if i ever come across one and have the cash.
Hey Phil..
is the primary reason why Chris produces more power at a lower PSI due to head work and a cam upgrade?!
yeah. hes got a lot of head work, bigger vales, aftermarket intake, ported exhaust. I'm all stock there.
hell he makes 300 whp at 9 pounds of boost!!!!!!!!!! Think about that, 9lbs
Its funny that Ryan brought up the headwork and cam...This is really where these old non-cross flow L engines need some help, the port, valve and polish work that was done on my head yielded just over 40additional hp on an engine dyno over a bone stock head, both heads had stock cams, this is on a P90 (non-hydraulic).
Both your cars are very very quick machines, no secret there and the video is a small sample of that proof! Chris' car is insane!
Once again thanks for sharing buddy!
Regards - Yasin
Also Chris has power to 7100 rpm. But the head work is key. I need to port out my other head, get an aftermarket intake, and try my big cam again?
Sorry for the phone video, its all I had. we must of been doing 130mph when we shut it down?
