dapiper Posted August 6, 2008 Share Posted August 6, 2008 Building up N42 head as replacement and need these parts. Need head ready to go without having to swap parts. Aluminum retainers originally from Tilton designed for 42.5 mm outer spring height. Need 6. Spring cups fit stock outer spring OD but using Isky 7005 spring set. Braap? Quote Link to comment Share on other sites More sharing options...
woldson Posted August 6, 2008 Share Posted August 6, 2008 Just as a passing curiosity, why not a pm? Quote Link to comment Share on other sites More sharing options...
1 fast z Posted August 6, 2008 Share Posted August 6, 2008 I am a bit confused by your post. SO your looking for a specific alluminum retainer? Hopefully this isnt a street car, but rather a race motor that will get tore down often to check for the keepers being pulled through the retainers. Quote Link to comment Share on other sites More sharing options...
jeffp Posted August 6, 2008 Share Posted August 6, 2008 I agree with Brian, you don't want to use aluminum spring reatiners or stem inserts. I have run them and to date have lost two valves with the PERFORMANCE valve train components. You want a good part, speak to Dell engineering for Titanium retainers and cups, these are light weight and will last forever. Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted August 6, 2008 Administrators Share Posted August 6, 2008 I agree with Brian, you don't want to use aluminum spring reatiners or stem inserts. I have run them and to date have lost two valves with the PERFORMANCE valve train components. You want a good part, speak to Dell engineering for Titanium retainers and cups, these are light weight and will last forever. Instead of just parroting what Brian and Jeff already said, I'll just say ditto.. Quote Link to comment Share on other sites More sharing options...
1 fast z Posted August 7, 2008 Share Posted August 7, 2008 A rule of thumb. Titanium is half the mass of steel Alluminum is 1/3 the mass of steel The benifit to a lighter retainer is you can run a weaker spring, which in turn=more HP. Quote Link to comment Share on other sites More sharing options...
inline6 Posted May 16, 2012 Share Posted May 16, 2012 Ancient thread... but I'm trying to track down titanium retainers for an L series. Can't find anything online about Dell Engineering... Are they defunct? Quote Link to comment Share on other sites More sharing options...
ctc Posted May 16, 2012 Share Posted May 16, 2012 You might try wolfcreek racing. I thought they had some on their website awhile back. Quote Link to comment Share on other sites More sharing options...
TimZ Posted May 17, 2012 Share Posted May 17, 2012 Here ya go... http://iskycams.com/cart/index.php?main_page=product_info&products_id=409&cPath=18 Quote Link to comment Share on other sites More sharing options...
