Cable Posted December 5, 2009 Share Posted December 5, 2009 Pretty cool dude. Quote Link to comment Share on other sites More sharing options...
Gcontrol Posted December 10, 2009 Share Posted December 10, 2009 Looks great. How far back does the down pipe go? Quote Link to comment Share on other sites More sharing options...
yessir Posted December 11, 2009 Author Share Posted December 11, 2009 as of now its only about a foot and a half long and dumps in front of the crossmember. Plans are to run it between the crossmember and motormount and run it to the rear of the car Quote Link to comment Share on other sites More sharing options...
ColtGT4g63 Posted December 11, 2009 Share Posted December 11, 2009 yessir said: Plans are to run it between the crossmember and motormount and run it to the rear of the car How big of diameter do you plan on making the down pipe? Do you have the standard JCI style motor mounts? If I'm thinking about the same place you're talking about running the down pipe, you are limited to pretty much only running a 3" diameter pipe through that little hole. I'm on a mission to figure out a way to run at least a 3.5" down pipe to the back of the car. I think that 3" is just a little too small. Heres the area that I run mine through.... Same place you're talking about? Quote Link to comment Share on other sites More sharing options...
yessir Posted December 12, 2009 Author Share Posted December 12, 2009 Thats what i had in mind, im assuming that is a 3 inch dp pictured. Anything special needed to make it fit or any tips would be greatly appreciated. thanks Quote Link to comment Share on other sites More sharing options...
ColtGT4g63 Posted December 12, 2009 Share Posted December 12, 2009 Its a 3" pipe in the pic, absolutely no way you can fit anything bigger. You just have to be precise with your welding and take your time, nothing special. Quote Link to comment Share on other sites More sharing options...
Gcontrol Posted December 20, 2009 Share Posted December 20, 2009 ColtGT4g63 said: How big of diameter do you plan on making the down pipe? Do you have the standard JCI style motor mounts? If I'm thinking about the same place you're talking about running the down pipe, you are limited to pretty much only running a 3" diameter pipe through that little hole. I'm on a mission to figure out a way to run at least a 3.5" down pipe to the back of the car. I think that 3" is just a little too small. Heres the area that I run mine through.... Same place you're talking about? Thats a tight fit! Quote Link to comment Share on other sites More sharing options...
Gcontrol Posted December 20, 2009 Share Posted December 20, 2009 ColtGT4g63 said: Its a 3" pipe in the pic, absolutely no way you can fit anything bigger. You just have to be precise with your welding and take your time, nothing special. Would it be possible to fab something for the rack and pinion and lower it a bit?? If so, how much extra room would you gain? Quote Link to comment Share on other sites More sharing options...
ColtGT4g63 Posted December 20, 2009 Share Posted December 20, 2009 Gcontrol said: Would it be possible to fab something for the rack and pinion and lower it a bit?? If so, how much extra room would you gain? I'm sure where there is a will, there is a way. But how much extra room would you gain? I'm going to guess not too much, if I recall the lack of room was side / side, not up / down. So if you could fab the "mount piece that pops up off the stock X member" to be closer to the passenger side, then I think you would be onto something. If that makes any sense.... Quote Link to comment Share on other sites More sharing options...
brysonzpassu Posted December 24, 2009 Share Posted December 24, 2009 the jtr kit uses a spacer that sits in between the frame and the rack it drops the rack down Quote Link to comment Share on other sites More sharing options...
Cable Posted December 25, 2009 Share Posted December 25, 2009 brysonzpassu said: the jtr kit uses a spacer that sits in between the frame and the rack it drops the rack down The LSx kit that JCI sells does the same thing, except its already built into the mounts. Quote Link to comment Share on other sites More sharing options...
sq_creations Posted January 8, 2010 Share Posted January 8, 2010 How is it coming Yessir? Quote Link to comment Share on other sites More sharing options...
yessir Posted January 8, 2010 Author Share Posted January 8, 2010 well..... i got the car to start and it was leaking fuel from the fuel rail, oil from the adapter above the oil filter and coolant from the thermostat housing . Also seems that the spark plug on cyclinder 1 doesnt seal properly:fmad:. I'm hoping i dont need to pull the head to fix it. Other than the above mentioned its going well, i figure about 3 weeks until i get the radiator, cooling fans and surge tank sorted. then hopefully off to the dyno:) Quote Link to comment Share on other sites More sharing options...
yessir Posted September 19, 2010 Author Share Posted September 19, 2010 80-180 roll, viper has boltons+200 shot. Z is on 9 psiI lost but i was still impressed with the cars performance Quote Link to comment Share on other sites More sharing options...
yessir Posted December 31, 2010 Author Share Posted December 31, 2010 z at 11psi losing by 1 and a half cars. 60 to 160 vs a 2j swapped 9.5 second 240sx Quote Link to comment Share on other sites More sharing options...
Slammed68 Posted January 2, 2011 Share Posted January 2, 2011 Holy stuff! Glad to see this car came together. Looks like it runs pretty hard! Quote Link to comment Share on other sites More sharing options...
yessir Posted January 10, 2011 Author Share Posted January 10, 2011 I didnt really like the outcome of the race. The car spins clean thru third gear and the bottom of fourth, sooo some 255/50-16 mickey thompson radial are in my future. Also going to an 80mm turbo along with a cam in an attempt to wake up the motor in upper rpms. btw the chase car/ camera car in the vid is a 450 or so wheel hp s2000 Quote Link to comment Share on other sites More sharing options...
Cable Posted January 10, 2011 Share Posted January 10, 2011 What did it dyno at the wheels? Quote Link to comment Share on other sites More sharing options...
yessir Posted January 12, 2011 Author Share Posted January 12, 2011 416 at 9 lbs. Pretty sure its inacurate though because at low boost (5 lbs) i run away from by friends 3.4 liter blower built c5 vette which makes 525 to the wheels with his low boost pulley on (10 lbs). Going by my super accurate butt dyno id guess somewhere in the relm of 560-580 or so at 11 lbs Quote Link to comment Share on other sites More sharing options...
yessir Posted January 12, 2011 Author Share Posted January 12, 2011 the viper in the first vid dyno's 640 to the wheels on the bottle and in that race i was running 9 psi Quote Link to comment Share on other sites More sharing options...
