Banshee_240Z Posted March 25, 2016 Share Posted March 25, 2016 The wiper seal gland nut? It's chamfered on the inside and maybe about halfway down the chamfer its ID matches the threaded gland nut's OD so you can just tap it down a little mallet. It's not structural so you don't need to go too crazy. I sectioned them quite a bit but I don't remember the exact measurements. I had a 2.5" spacer underneath the Bilsteins and the gland nut is almost touching the strut when fully tightened. Quote Link to comment Share on other sites More sharing options...
Gareth. J. Posted May 6, 2016 Share Posted May 6, 2016 Does anyone know the valving specs for these Bilstein 34-050224 shown above? I'm also keen to hear people's thoughts on these adjustable ones from Kameari... Quote Link to comment Share on other sites More sharing options...
Floorless240z Posted May 22, 2017 Share Posted May 22, 2017 Looking to order some coilovers for my 73 240z. I spoke with Jay at Ground Control, told him this would be a fair weather car with a couple track days per year (Watkins Glen and Toronto Motorsport Park are nearby). I have flares and plan to run 245's in back, perhaps more if they'll fit. At first he said he would recommend softer spring rates and Koni Sports and would e-mail me a spec sheet. I didn't receive anything, called a few times throughout the week and received this after calling again 4 days later. It looks like he's suggesting 340f/380r. Do those spring rates seem high? I don't have a cage, though I would like to add a roll bar at some point. Also aren't those spring rates much higher than the Tokicos can handle? After reading it seems they can only tolerate spring rates of 250 or so, no? Quote Link to comment Share on other sites More sharing options...
burninator Posted June 7, 2017 Share Posted June 7, 2017 On 5/22/2017 at 7:57 PM, Floorless240z said: It looks like he's suggesting 340f/380r. Do those spring rates seem high? I don't have a cage, though I would like to add a roll bar at some point. Also aren't those spring rates much higher than the Tokicos can handle? After reading it seems they can only tolerate spring rates of 250 or so, no? If you haven't got an answer yet on this... The spring rates might be a bit high, but it depends on your tolerance for ride quality. They are probably too high for Tokico dampers, the Konis he suggested originally could handle them though. I don't know what other people run for a setup like yours, but for comparison, my autocross only race car ran 350's in the front and 300's in the rear with Koni 8610 dampers and it feels stiff on the street. I don't know why some people run stiffer springs in the rear, it never made sense to me, but with your staggered tire setup it might work out. Quote Link to comment Share on other sites More sharing options...
Chickenman Posted August 13, 2017 Share Posted August 13, 2017 Just got these built up ( finally ) for my 280z. TT3 DIY coil over kit with Eibach 250 lb/in springs. Koni Sport MR2 dampers. And some other bits and bobs in boxes etc: Quote Link to comment Share on other sites More sharing options...
88dangerdan Posted August 13, 2017 Share Posted August 13, 2017 Chickenman, any chance I could get the height measurement just the way they are in your picture. Not including the box...lol...would appreciate it. Thanks Quote Link to comment Share on other sites More sharing options...
Chickenman Posted August 15, 2017 Share Posted August 15, 2017 ^ Sorry been a bit hectic the last couple of Daze. I'll get them measured for you by to morrow morning. Quote Link to comment Share on other sites More sharing options...
88dangerdan Posted August 15, 2017 Share Posted August 15, 2017 No problem. I appreciate you taking the time to do it. Thanks Daniel Quote Link to comment Share on other sites More sharing options...
Chickenman Posted August 15, 2017 Share Posted August 15, 2017 Measured from the very bottom of the strut, where the steering arm bolts on. These are 280Z front struts. Strut overall length is 14 5/8" after cutting ( not including gland nut ) . Spring perch is 8 1/2" from the very bottom of strut. Shocks are KONI Sport 8641-1142 . Toyota MR2 rears Quote Link to comment Share on other sites More sharing options...
88dangerdan Posted August 15, 2017 Share Posted August 15, 2017 Thank you sir. Again, I appreciate you taking the time. Daniel Quote Link to comment Share on other sites More sharing options...
The Infidel Posted March 15, 2018 Share Posted March 15, 2018 Where are you guys getting the 280z Koni gland nuts? Part number 73.25.00.025.1 Quote Link to comment Share on other sites More sharing options...
Chickenman Posted March 16, 2018 Share Posted March 16, 2018 (edited) I used some spare Tokico gland nuts. There is a thick washer that is welded to the inside of the gland nut. This locates the Top of the shock. The Koni shock is a bit larger diameter at the Top. But 5 minutes on the Lathe and Badda Bing.... Tokico gland nuts that fit Koni's. Edited March 16, 2018 by Chickenman Quote Link to comment Share on other sites More sharing options...
The Infidel Posted March 26, 2018 Share Posted March 26, 2018 I just ordered them directly from Koni in Kentucky. $18.50 a piece. Quote Link to comment Share on other sites More sharing options...
TimZ Posted March 30, 2018 Share Posted March 30, 2018 (edited) On 3/16/2018 at 3:04 AM, Chickenman said: I used some spare Tokico gland nuts. There is a thick washer that is welded to the inside of the gland nut. This locates the Top of the shock. The Koni shock is a bit larger diameter at the Top. But 5 minutes on the Lathe and Badda Bing.... Tokico gland nuts that fit Koni's. Expand Maybe a dumb question, but are you running the same shocks in the rear, and do you have any idea how these shocks compare to the 8610 RACE shocks? I'd like to switch to Konis and my fronts are sectioned, but my spring rates are too low for the 8610/8611s. Edited March 30, 2018 by TimZ Quote Link to comment Share on other sites More sharing options...
Chickenman Posted March 30, 2018 Share Posted March 30, 2018 No. I'm not running the same shocks in the rear... at this point. Fronts coil overs are using 1988 MR2 rears Koni sport. 250 lb/in front springs. Rears I like having a bit softer for touring comfort. So rears will be the Eibach Pro springs ( whatever rate they are ) with KYB's in the back. I'll use the front spring isolators on the rear to lower it another 1". Next season I may look at going with Coil Overs with Koni' Sports or Bilsteins in the back. Probably go 225 lb/in at the rear. I quite like the combo of Koni's up front and Bilsteins in the rear. I use that setup on my Audi and it works nicely. The Bilsteins seem to be more compliant than Koni sports, so you don't get a jiggly ride over Freeway expansion joints. I like the front a bit stiffer on Z cars than the rear for the street. Getting old I guess...... Quote Link to comment Share on other sites More sharing options...
TimZ Posted April 3, 2018 Share Posted April 3, 2018 On 3/15/2018 at 11:00 PM, The Infidel said: Where are you guys getting the 280z Koni gland nuts? Part number 73.25.00.025.1 Expand First - thanks Chickenman - your input was very helpful. Second - just ordered four of these from Koni - they had none in stock in the US and had to get them from their warehouse in Holland. Sounds like I should get them some time in May.. Quote Link to comment Share on other sites More sharing options...
Chickenman Posted April 6, 2018 Share Posted April 6, 2018 If I was planning on using this car for Track days or even Autocross, I would likely go with Koni's on all four corners. But for now the KYB's in the rear will suffice. The rear has good grip and compinace for Canyon Carving. I like a suspension that will soak up bumps. A slightly softer suspension is also more forgiving in the rain. We seem to get more than our fair share in the PNW... Sigh. Quote Link to comment Share on other sites More sharing options...
socorob Posted April 9, 2018 Share Posted April 9, 2018 I have 250# springs in the rear with konis, and I think they're too soft, with as much preload as I can put on them, they still almost bottom out from the weight of the car, so I end up with very little rear travel. I think 300 would be a good minimum for the rear of a full street Z in my opinion. I have 300 in the front, and they give a decent ride. Quote Link to comment Share on other sites More sharing options...
TimZ Posted April 10, 2018 Share Posted April 10, 2018 On 4/9/2018 at 8:42 PM, socorob said: I have 250# springs in the rear with konis, and I think they're too soft, with as much preload as I can put on them, they still almost bottom out from the weight of the car, so I end up with very little rear travel. I think 300 would be a good minimum for the rear of a full street Z in my opinion. I have 300 in the front, and they give a decent ride. Expand They're likely not too soft - just too short. A 250 lb/in spring should compress a bit less than 3" on any corner of a typical Z. Properly sized lengthwise, such a spring should have no issue whatsoever supporting your z at any ride height that the strut will allow. Quote Link to comment Share on other sites More sharing options...
socorob Posted April 10, 2018 Share Posted April 10, 2018 Mine probably compresses more than that. How would the length of the spring change how much it compresses? Quote Link to comment Share on other sites More sharing options...
