jnjdragracing Posted October 4, 2008 Share Posted October 4, 2008 Well we went to the drag strip tonight and tried to make 4 passes. Did not tear up anything which is a good thing and nobody got hurt which means a good trip. We tried to make some complete passes but we had just too much power. I have posted the video footage of our passes at www.jnjdragracing.com please go to Zcar, then movies, then to the bottom ( Testing our new project ). You can read what we tried to do to cut back on the awsome power. but it did not help. Also here is a direct link. Please be sure to right click and save as, it is a 51meg video file. http://www.jnjdragracing.com/videos/New%20project%201-4%20test%20runs.mpg Until next time..... John and Jerry Quote Link to comment Share on other sites More sharing options...
Guest Zrocket Posted October 4, 2008 Share Posted October 4, 2008 Nice. Do you have a stock rear end. I have a 74 240z, with a 406 sbc, 144 mini blower, on alchol. We brake rear ujoints off the line. Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted October 4, 2008 Share Posted October 4, 2008 could you post a component parts list(engine and drivetrain specs) Im sure many guys would be very interested Quote Link to comment Share on other sites More sharing options...
Warren Posted October 4, 2008 Share Posted October 4, 2008 Time for wheelie bars!!! Quote Link to comment Share on other sites More sharing options...
deja Posted October 4, 2008 Share Posted October 4, 2008 Well you got the burnout part down!!!! Nice wheelies too, that's got to get Jerry's heart racing! Like Warren said do you think wheelie bars would help? Then again it got way loose on the first run without pulling air. We are all going to miss you if you decide DNI is pointless. Quote Link to comment Share on other sites More sharing options...
JustinOlson Posted October 4, 2008 Share Posted October 4, 2008 I'd say its time to tie down the front end to limit travel, along with some sort of timing retard box to help you get moving. Please guys make it work!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
woldson Posted October 4, 2008 Share Posted October 4, 2008 Man that thing sounds totally PISSED off!!!!!!!! DAMN SWEET!!! Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted October 4, 2008 Author Share Posted October 4, 2008 Here you go GrumpyVette... 280Z chassis / suspension specs: Front motor mount plates (tied to frame) Rear motor mount plate (tied to frame) Bad Dog Frame rails Modern Motor Sports stub axel conversion companion flanges to accept CV axles. Enables a bolt on swap of *300ZXT CV (4 bolt model) Half shafts into 1970-1978 Z cars with R200 differentials Stock R200 rear end Welded posi with 3.55 gear ratio Turbo CV axels Drive shaft (custom built) using U-Joint to pinion flange part number ( naacco / car quest # 2-2-899-1) Drive shaft safety loop (NHRA specs) 10 point roll cage NHRA certified to 8.5 ET ¼ mile Transmission: 2 Speed Power Glide w/1.82 first Transmission shield (NHRA specs) Flex plate shield (NHRA specs) Engine specs: Stock production 4 bolt main 350 block (high nickel content) Bored 30 over Callies Stealth crank std /std (crank and rods / pistons balanced Iron eagle rods 5.7 length H-beam TRW forged blower pistons reversed dome Used Arp main stud kit with mildon windage tray Arp head stud kit Mellings high volume oil pump Block o-ringed Head cut with receiver grooves for block .30 thousands copper SCE head gaskets Dart 230 Iron heads cut 49cc 2.08 intake 1.60 exhaust valves Comp cams vasco jet springs pre-loaded for cam specs Cloyes true roller double cnc timing chain set Stock 5 qt. oil pan Crank hub BDS grind number 4500-r roller cam 114 center line / specs are: valve lift intake and exhaust 630 w/1.5 rockers (we use 1.6 rockers) duration intake 318 / exhaust 322, at .50 it is 282 / 290. Comp Cams severe duty roller lifters Comp Cams magnum 1.6 roller rockers Comp Cams 7/16 stud girdle Bds blower intake Bds 6-71 blower (reworked by little filed and clearenced / Teflon / nitril stripped for alky) Enderle bird catcher hat with Enderle injectors .45, alky barrel valve .80 main bypass pill Enderle 80-A1 cam driven fuel pump 7.1gpm Blower is set up for 2 % over driven MSD pro billet dist. MSD 6AL ignition w/ MSD boost controller (not using at the moment) MSD 8mm plug wires Headers are hooker headers competition for Datsun 240 -280Z Spark plugs are autolite AR133 Starter: using stock OEM mini starter for a corvette You can go to www.jnjdragracing.com and follow our progress with setup and testing to find more specs. PS: if more info is needed please let us know. John and Jerry could you post a component parts list(engine and drivetrain specs) Im sure many guys would be very interested Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted October 4, 2008 Author Share Posted October 4, 2008 Now I never said DNI was pointless, if we can not get the Z to run down the track then there is no need in going. I will be hounding Jerry about it and at least we can attend to root everybody else on. Who knows I might be able to down size some power. I need to talk to enderle Monday and see how far I can retard the timing before it wants to sneeze, and also maybe under drive the pulleys. We will have to see...... John Well you got the burnout part down!!!! Nice wheelies too, that's got to get Jerry's heart racing! Like Warren said do you think wheelie bars would help? Then again it got way loose on the first run without pulling air. We are all going to miss you if you decide DNI is pointless. Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted October 4, 2008 Share Posted October 4, 2008 Here you go GrumpyVette... 280Z chassis / suspension specs: Front motor mount plates (tied to frame) Rear motor mount plate (tied to frame) Bad Dog Frame rails Modern Motor Sports stub axel conversion companion flanges to accept CV axles. Enables a bolt on swap of *300ZXT CV (4 bolt model) Half shafts into 1970-1978 Z cars with R200 differentials Stock R200 rear end Welded posi with 3.55 gear ratio Turbo CV axels Drive shaft (custom built) using U-Joint to pinion flange part number ( naacco / car quest # 2-2-899-1) Drive shaft safety loop (NHRA specs) 10 point roll cage NHRA certified to 8.5 ET ¼ mile Transmission: 2 Speed Power Glide w/1.82 first Transmission shield (NHRA specs) Flex plate shield (NHRA specs) Engine specs: Stock production 4 bolt main 350 block (high nickel content) Bored 30 over Callies Stealth crank std /std (crank and rods / pistons balanced Iron eagle rods 5.7 length H-beam TRW forged blower pistons reversed dome Used Arp main stud kit with mildon windage tray Arp head stud kit Mellings high volume oil pump Block o-ringed Head cut with receiver grooves for block .30 thousands copper SCE head gaskets Dart 230 Iron heads cut 49cc 2.08 intake 1.60 exhaust valves Comp cams vasco jet springs pre-loaded for cam specs Cloyes true roller double cnc timing chain set Stock 5 qt. oil pan Crank hub BDS grind number 4500-r roller cam 114 center line / specs are: valve lift intake and exhaust 630 w/1.5 rockers (we use 1.6 rockers) duration intake 318 / exhaust 322, at .50 it is 282 / 290. Comp Cams severe duty roller lifters Comp Cams magnum 1.6 roller rockers Comp Cams 7/16 stud girdle Bds blower intake Bds 6-71 blower (reworked by little filed and clearenced / Teflon / nitril stripped for alky) Enderle bird catcher hat with Enderle injectors .45, alky barrel valve .80 main bypass pill Enderle 80-A1 cam driven fuel pump 7.1gpm Blower is set up for 2 % over driven MSD pro billet dist. MSD 6AL ignition w/ MSD boost controller (not using at the moment) MSD 8mm plug wires Headers are hooker headers competition for Datsun 240 -280Z Spark plugs are autolite AR133 Starter: using stock OEM mini starter for a corvette You can go to www.jnjdragracing.com and follow our progress with setup and testing to find more specs. PS: if more info is needed please let us know. John and Jerry THANK YOU! ILL ADD THE INFO TO MY DATA BASE! Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted October 5, 2008 Share Posted October 5, 2008 I can't fathom what the R200 and half shafts are thinking. Amazing! Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted October 5, 2008 Author Share Posted October 5, 2008 THANK YOU! ILL ADD THE INFO TO MY DATA BASE! Grumpyvette,John left off that we are still using the stock stub axles that came in the car (1976 280Z)I know it is crazy but we have never had a failure yet.. A Big YET.We are using the 300ZXT CV converison from MM .Jerry Quote Link to comment Share on other sites More sharing options...
Guest Zrocket Posted October 5, 2008 Share Posted October 5, 2008 I just got a R230 for my Z. Next is the cv conv from MM. Then I shouldn't have any probles. Hope you dial it in looks fast. Quote Link to comment Share on other sites More sharing options...
DavyZ Posted October 5, 2008 Share Posted October 5, 2008 I wouldn't keep my foot into it that close to a concrete wall either Looked like fun, tough. Keep up the great work! Davy Quote Link to comment Share on other sites More sharing options...
zthis Posted October 5, 2008 Share Posted October 5, 2008 what size tires ? Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted October 5, 2008 Author Share Posted October 5, 2008 micky thompson 28x9x15 ET slicks. what size tires ? Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted October 6, 2008 Author Share Posted October 6, 2008 I forgot to list my rings, Rings are Total Seal rings, gappless 1st ring. THANK YOU! ILL ADD THE INFO TO MY DATA BASE! Quote Link to comment Share on other sites More sharing options...
G-rib-73-240z Posted October 8, 2008 Share Posted October 8, 2008 micky thompson 28x9x15 ET slicks. how wides the biggest you can run w.o widening the wheel well and flareing out the sides... i was wondering because i wanted to run some 10 inch mickey tompsons in the back on some 16inch rims... but now im thinking bout clearance.... not that my car will need them or anything but would be sweet to have lol or that my car has a motor or transmission lol Quote Link to comment Share on other sites More sharing options...
jnjdragracing Posted October 8, 2008 Author Share Posted October 8, 2008 We had to notch the fenders right behind the door and turn up the fender lips and clearencethe rear strut tower perches in order to run the 28x9x15. So if you plan on running 10 inch then be prepared to do some clearencing. John how wides the biggest you can run w.o widening the wheel well and flareing out the sides... i was wondering because i wanted to run some 10 inch mickey tompsons in the back on some 16inch rims... but now im thinking bout clearance.... not that my car will need them or anything but would be sweet to have lol or that my car has a motor or transmission lol Quote Link to comment Share on other sites More sharing options...
G-rib-73-240z Posted October 8, 2008 Share Posted October 8, 2008 darn, ok thanks for the reply. i was hopin i wouldnt have to do that but i guess ill look for some 8 inch ones. still ganna need custom rims lol Quote Link to comment Share on other sites More sharing options...
