grumpyvette Posted September 10, 2009 Author Share Posted September 10, 2009 (edited) my current 383 has a custom EFI intake based on a highly modified HSR with extensively ported runners and a custom plenum and 36 lb injectors, but Ive built lots of similar power range 383 engines with 750-850 HOLLEY carb on EDELBROCK and WEIAND INTAKES in the past, keep in mind the wole engine is designed to maximize a 150hp-200hp shot of NITROUS not built for N/A hp Edited September 10, 2009 by grumpyvette Quote Link to comment Share on other sites More sharing options...
Vette Powered Posted September 11, 2009 Share Posted September 11, 2009 I guess it depends on the power. I've had both turbo and big block monsters. Right now I have a 1972 240Z with a 383 stroker and a T56 trans. I run drag radials and I think the car makes about 370 or so to the wheels. I also have a 730 HP Lexus SC300. Anything above 50 mph the SC is the car for me but around town the Z is way more fun. I really don't agree with the "to much power and you can't drive it around all day". My Lexus on pump gas and with the boost controler off still makes around 500 at the wheels and I can drive it all day any day. Quote Link to comment Share on other sites More sharing options...
rsicard Posted September 11, 2009 Share Posted September 11, 2009 Grumpy: What is a HSR? Which manifold are you using that is modified? I am building a 383 SBC stroker that may have an Edelbrock Pro Flow XT manifold and injectors but have a MAF, Drive By Wire throttle body, TAC module and 0411 PCM modified with Roadrunner EFI system. I have finally decided on solid roller lifters, associated camshaft and shaft rocker arms to make certain that there is ALWAYS good and reliable valve lift. The bottom end is all forged components so a shot of NITROUS should not be much of a problem. Want to start out with a carb and carb manifold. Trying to replicate a 500 HP and 500 Ft/Lb SBC listed on AFR's web site. Quote Link to comment Share on other sites More sharing options...
ktm Posted September 11, 2009 Share Posted September 11, 2009 When you start constantly breaking stuff, including the bank? Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted September 11, 2009 Share Posted September 11, 2009 I have gone 10.11 at 123 in the 1/4..that was lifting at 1000 ft. Car should see 9.80's at 135-140. I drive it to and from the track if I do not break it..LOL I do not know what is fast enough. I'll let you know when I get there. Quote Link to comment Share on other sites More sharing options...
amorfin Posted September 11, 2009 Share Posted September 11, 2009 When nobody else wants to race you anymore... That's fast enough......... ........Until somebody comes up and beats you... Then it starts again Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted September 12, 2009 Author Share Posted September 12, 2009 rsicard said: Grumpy: What is a HSR? Which manifold are you using that is modified? I am building a 383 SBC stroker that may have an Edelbrock Pro Flow XT manifold and injectors but have a MAF, Drive By Wire throttle body, TAC module and 0411 PCM modified with Roadrunner EFI system. I have finally decided on solid roller lifters, associated camshaft and shaft rocker arms to make certain that there is ALWAYS good and reliable valve lift. The bottom end is all forged components so a shot of NITROUS should not be much of a problem. Want to start out with a carb and carb manifold. Trying to replicate a 500 HP and 500 Ft/Lb SBC listed on AFR's web site. HSR =HOLLEY STEALTH RAM http://www.summitracing.com/parts/NOS-05151NOS/?image=large Quote Link to comment Share on other sites More sharing options...
jc052685 Posted September 12, 2009 Share Posted September 12, 2009 amorfin said: When nobody else wants to race you anymore... That's fast enough......... ........Until somebody comes up and beats you... Then it starts again Truth right here! Quote Link to comment Share on other sites More sharing options...
Vette Powered Posted September 12, 2009 Share Posted September 12, 2009 jc052685 said: Truth right here! Texas boys!!! That's what I like to see! Quote Link to comment Share on other sites More sharing options...
turbotalon1g Posted September 12, 2009 Share Posted September 12, 2009 I need to get to austin asap to meet you guys. Quote Link to comment Share on other sites More sharing options...
355Z Posted September 14, 2009 Share Posted September 14, 2009 I usually base my powerplant choice on the capability of the drivetrain and suspension/tires, along with the weight of the vehicle. Hence my choice of the 280Z. Light weight, 325 to the ground and a plate on top of that should give me a decent 1/4 mile time with a vehicle that can still handle. Quote Link to comment Share on other sites More sharing options...
Zfan1 Posted October 6, 2009 Share Posted October 6, 2009 Just ran a new best at the Texas Motorplex last friday night. went 9.94 at 137 with a 1.51 60 ft. Weather was perfect for racing, 72 degree's and dry air. I think leaving on the bottle earlier will get me into the .70-.80 range too. Right now I hit the sauce at the 60 ft. mark. Quote Link to comment Share on other sites More sharing options...
Kevin.pk Posted October 7, 2009 Share Posted October 7, 2009 Well done mike!! Congrats on finally getting that 9 second pass!! Quote Link to comment Share on other sites More sharing options...
John Scott Posted October 9, 2009 Share Posted October 9, 2009 Zfan1 said: Just ran a new best at the Texas Motorplex last friday night. went 9.94 at 137 with a 1.51 60 ft. Weather was perfect for racing, 72 degree's and dry air. I think leaving on the bottle earlier will get me into the .70-.80 range too. Right now I hit the sauce at the 60 ft. mark. Congrats Mike! Now where's the video? Quote Link to comment Share on other sites More sharing options...
Rat Fink Posted October 31, 2009 Share Posted October 31, 2009 I tell my wife I need to make it "too fast enough". (New stereo definitely got it too loud enough) Quote Link to comment Share on other sites More sharing options...
pcakes55 Posted November 11, 2009 Share Posted November 11, 2009 heyahh said: 1990 2+2, 383 Gen 1 SBC, Nissan 5 spd & Nissan R200 w/4.08:1 & carbonetics posi (still holding up!!)........600hp / 10.8 sec / 123 mph.......pics attached.....this was a fun project to build & more fun to drive Used to see you all the time in Hudson, sick car. Quote Link to comment Share on other sites More sharing options...
ZR8ED Posted November 11, 2009 Share Posted November 11, 2009 It's too fast or too modified, they day you cringe a bit about taking it out (see below list of possible reasons), and instead go and grab the DD. Fear of tickets/police hassles, fear of parking hassles, fear of theft, fear of rain/getting it dirty, fear of someone crashing into you, fear of breaking something, fear of not being able to afford to repair said "breaking of something" etc. There are a lot of us in or approaching that boat. Yep I said me too. Guilty of taking the DD instead of the risk/hassle of taking the Z. Quote Link to comment Share on other sites More sharing options...
240hoke Posted November 11, 2009 Share Posted November 11, 2009 You left out one, Its only truly fast enough if you avoid driving it due to fear of death. Quote Link to comment Share on other sites More sharing options...
Rat Fink Posted November 12, 2009 Share Posted November 12, 2009 Hahaha!! I think we have a winner! Quote Link to comment Share on other sites More sharing options...
Rat Fink Posted November 12, 2009 Share Posted November 12, 2009 Or, to put it another way: your car is fast enough when you're afraid of it! Quote Link to comment Share on other sites More sharing options...
