WalterPeck Posted October 20, 2008 Share Posted October 20, 2008 Since I got my 77 280Z, I've always noticed that turning the steering wheel at low speed requires some serious torque. Now this isn't my first car without power steering, but the amount of force required seems unusual... is this likely to be an old worn bushing problem, something else, or is everything likely fine? Quote Link to comment Share on other sites More sharing options...
kiwi303 Posted October 20, 2008 Share Posted October 20, 2008 at tyres are you running on the front? when I re-tyred my old navara ute from 165 width hard light truck compound to 205 sticky mid performance car compound the steering went from passable to gorrila-shoulders at low speed, high speed was much better tho Quote Link to comment Share on other sites More sharing options...
Phantom Posted October 20, 2008 Share Posted October 20, 2008 I've driven two different 1977 280Z's for the past 32 years and they both were serious about keeping my shoulders and uper arms in tone. YOu just don't turn the wheel easily unless the tires are rolling. I doubt it's a steering problem. Confirm that your tires are properly inflated and then just know that is what you wil be dealing with. You'll note that several guys in this forum have solved that issue by adapting power steering systems from other cars. Quote Link to comment Share on other sites More sharing options...
Globerunner513 Posted October 20, 2008 Share Posted October 20, 2008 For my car, I also have a significantly smaller steering wheel than stock, and thus takes a little more work to turn it at low speeds. I just try to avoid parallel parking at all costs lol. Quote Link to comment Share on other sites More sharing options...
LeX Posted October 21, 2008 Share Posted October 21, 2008 i got a small grant wheel on my 240.. its a damn workout parallel parking and i have to do that! Quote Link to comment Share on other sites More sharing options...
MJLamberson Posted October 21, 2008 Share Posted October 21, 2008 If your car has the stock bumper up front take it, and all associated mounting hardware off... I was surprised at what a difference that made. Quote Link to comment Share on other sites More sharing options...
WalterPeck Posted October 21, 2008 Author Share Posted October 21, 2008 Thanks for the prompt replies. The tires are good and properly inflated, so I guess it's just the car! Oh well, I can deal with that. Would replacing the steering bushings even do anything? The ones I can see do look pretty old so I'd probably be replacing them anyway. Quote Link to comment Share on other sites More sharing options...
aviatorx Posted October 21, 2008 Share Posted October 21, 2008 Unfortunately, rack bushings are no longer available but can be manufactured by your favorite machinist - but that isn't the problem you described. Look at the diameter of the OEM steering wheel - it's huge! It's designed that way to help overcome the forces required to move the front wheels in an unassisted rack and pinion set up. The only way to truely get 'better' low speed steering is to upgrade to a power rack, and that has been done and documented here at HybridZ. Worn rack bushings would exhibit themselves as front end wobble at higher speeds, and even then you have a better chance of feeling worn outer / inner rod ends before a worn rack bushing. It is too bad that the rack & pinion rebuild kits are NLA, though ..... Quote Link to comment Share on other sites More sharing options...
EMWHYR0HEN Posted October 21, 2008 Share Posted October 21, 2008 You can always install one of those steering wheel knobs like this one: With pool ball grip! Quote Link to comment Share on other sites More sharing options...
srgunz Posted October 21, 2008 Share Posted October 21, 2008 On the Z cars, the ball joints on the front struts play an important role. This is where your lower strut pivots. If they are dry and worn you can figure on hard steering. I would look there. Quote Link to comment Share on other sites More sharing options...
tube80z Posted October 21, 2008 Share Posted October 21, 2008 On the Z cars, the ball joints on the front struts play an important role. This is where your lower strut pivots. If they are dry and worn you can figure on hard steering. I would look there. Also check the bearing on top. Quote Link to comment Share on other sites More sharing options...
Silver Mine Motors Posted October 21, 2008 Share Posted October 21, 2008 If your car is lowered you might want to get bump steer spacers, they make a bit of a difference. Quote Link to comment Share on other sites More sharing options...
AK-Z Posted October 22, 2008 Share Posted October 22, 2008 check your tire pressure. Quote Link to comment Share on other sites More sharing options...
Nismo280zEd Posted October 26, 2008 Share Posted October 26, 2008 I've driven two different 1977 280Z's for the past 32 years and they both were serious about keeping my shoulders and uper arms in tone. YOu just don't turn the wheel easily unless the tires are rolling. I doubt it's a steering problem. Confirm that your tires are properly inflated and then just know that is what you wil be dealing with. You'll note that several guys in this forum have solved that issue by adapting power steering systems from other cars. This is a general rule of driving my father taught me... don't turn your wheels till your rolling, it just scrubs down the tire and wears it out quicker. Once your rolling even a little, the Z is rather easy to turn. Sitting still not moving, yes it is a bear, but like I said... try not to do that, just unescessary wear. Quote Link to comment Share on other sites More sharing options...
WalterPeck Posted October 27, 2008 Author Share Posted October 27, 2008 Yeah, now that I've driven around a bit without the front "park bench", it does turn and handle noticeably better. I guess I was spoiled by my last RWD car with no power steering in that regard, a Datsun 210D. Quote Link to comment Share on other sites More sharing options...
