Hall Effect Speedometer Sender???
Chemicalblue
  • 3 weeks later...
Do you need your speedometer? The speed sensor from the 240SX (91 is where I got mine from) fits in the early transmissions, and is driven by the speedo drive gear. The most you might have to do to make it mesh properly is cut the retainer groove 180 degrees from where it currently is, to accomodate the earlier transmission orientation. They fit directly in the 83 five speed I have in mine for driving an electric speedo without cable. I've put cables into SX trannies doing the opposite as well.
Good Luck....though thinking about it, you can always drill the trans case and stick a standard MPU to read the gear teeth on the output shaft if is comes to the absolutely worst case scenario.
