zbigtim Posted December 1, 2008 Share Posted December 1, 2008 I just completed the porting of my intake for the 240sx 60mm TB. Thought I would share some pictures. I'm not sure where I found this web site, but it has a good write up on how to go about the porting. http://www.graytechsoftware.com/garage/tbs_inst_port.asp I used a rotary file Used the 240SX TB Gasket to mark the area Here I'm about half way Comparison of before and after I still need to work on the throttle linkage. Need to shorten and re-thread the throttle shaft. Thanks for looking... Tim. Quote Link to comment Share on other sites More sharing options...
skib Posted December 1, 2008 Share Posted December 1, 2008 Thanks for sharing pics Im working on the same thing right now, that same site has a nice write up on putting your stock linkage on the the 60mm TB to. http://www.graytechsoftware.com/garage/tbs_linkage.asp Quote Link to comment Share on other sites More sharing options...
zbigtim Posted December 1, 2008 Author Share Posted December 1, 2008 Yes, I was going to ask about the linkage, until I was putting together this post. I stumbled across the answer on that site. Tim. Quote Link to comment Share on other sites More sharing options...
skib Posted December 1, 2008 Share Posted December 1, 2008 Its pretty easy once you know everything that needs to be done, this thread should be helpful to anyone whos not quite sure what has to be done to make it work yet. Quote Link to comment Share on other sites More sharing options...
zbigtim Posted December 1, 2008 Author Share Posted December 1, 2008 Has anyone ever used something like this to replace those ugly, yellowed, plastic ball joints? 15734 - JEGS Carburetor Linkage Bushings and Swivels Quote Link to comment Share on other sites More sharing options...
skib Posted December 1, 2008 Share Posted December 1, 2008 Has anyone ever used something like this to replace those ugly, yellowed, plastic ball joints? 15734 - JEGS Carburetor Linkage Bushings and Swivels interesting, thos would look nice idk if anyones done it yet Quote Link to comment Share on other sites More sharing options...
S130Z Posted December 1, 2008 Share Posted December 1, 2008 The glory of power tools. I wish I had a rotoy file when I did mine. I used a hand file and it took me about 4 hours to get it done. Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted December 1, 2008 Share Posted December 1, 2008 I haven't ported mine yet, just bolted on the sx throttle body. I think the harsh flow is causing a surge at low speed light throttle. Quote Link to comment Share on other sites More sharing options...
S130Z Posted December 1, 2008 Share Posted December 1, 2008 All I have to say is mine whistles like a MOFO! Which I think sounds pretty bad ass. Any one else getting this effect? Quote Link to comment Share on other sites More sharing options...
Rustyfriend Posted December 1, 2008 Share Posted December 1, 2008 I haven't ported mine yet, just bolted on the sx throttle body. I think the harsh flow is causing a surge at low speed light throttle. I believe I am having the same surge that you are having. While under a load at low speed you will get a really lopey idle or something like that? I have just thrown on the tb without porting. I am holding off on it until I do my motor swap with my other intake manifold. Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted December 1, 2008 Share Posted December 1, 2008 Mine actually causes the car to buck pretty bad until you give it a little more gas, let off completely, or press the clutch. But yes, light load low speed low throttle. Quote Link to comment Share on other sites More sharing options...
skib Posted December 1, 2008 Share Posted December 1, 2008 seems to me that having the 60mm TB on a 50mm opening kind of defeats having a 60mm TB. Quote Link to comment Share on other sites More sharing options...
Rustyfriend Posted December 1, 2008 Share Posted December 1, 2008 That is true, I just haven't had the time recently and even if there is a rough opening, I have still noticed increased throttle response. My stock 50mm was in pretty rough shape. Quote Link to comment Share on other sites More sharing options...
TrumpetRhapsody Posted December 1, 2008 Share Posted December 1, 2008 Only reason I'm using the 60mm is b/c it had a TPS on it, and was easy to set up with a throttle cable. I didn't port it b/c I was in a hurry to get it running. Soon as I get a few free hours it's getting ripped off and ported. Quote Link to comment Share on other sites More sharing options...
Challenger Posted December 1, 2008 Share Posted December 1, 2008 That is true, I just haven't had the time recently and even if there is a rough opening, I have still noticed increased throttle response. My stock 50mm was in pretty rough shape. Thats probably cause 1/4 throttle now is like 1/2 throttle before... not exactly those numbers but you get the point. Quote Link to comment Share on other sites More sharing options...
Rustyfriend Posted December 1, 2008 Share Posted December 1, 2008 Not just that, but the round plate inside of the opening would become stuck to the tb on occasion. The stocker was cursed. Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted December 2, 2008 Share Posted December 2, 2008 Extra points for the plywood TB spacer! Quote Link to comment Share on other sites More sharing options...
Warren Posted December 2, 2008 Share Posted December 2, 2008 No need to rethread the linkage rod, or replace the yellowed ball swivel, other than looks. Use that rotary rasp to remove that corner protruding out into it's path on the manifold itself...it serves no purpose. Quote Link to comment Share on other sites More sharing options...
zbigtim Posted December 2, 2008 Author Share Posted December 2, 2008 Extra points for the plywood TB spacer! Thanks cygnusx1, I can appreciate the jab! I think if I were to shorten and rethread the throttle shaft, the linkage would be in better mechanical alignment. And yes I want to replace the ball joints because of looks. Quote Link to comment Share on other sites More sharing options...
bco6 Posted December 2, 2008 Share Posted December 2, 2008 Great pics! Does anyone know if I could run a 60mm TB in stock Turbo intake system, or do i need modifications? Also is it safe to have a stock 83 zxt motor run at 15 psi? Quote Link to comment Share on other sites More sharing options...
