stony Posted November 5, 2013 Author Share Posted November 5, 2013 Thinking about going 2jz.... what does everyone think a good price for a 750+hp rb would be? Would be complete turnkey minus intercooler, electronics, engine harness, and trans... but would include the ati power glide swap stuff (converter, and midplate.) Quote Link to comment Share on other sites More sharing options...
flatrate Posted November 7, 2013 Share Posted November 7, 2013 Why go 2JZ at this point? Quote Link to comment Share on other sites More sharing options...
stony Posted November 8, 2013 Author Share Posted November 8, 2013 Why not??? Got lots of support local for parts... at any rate I do not think anyone will even come close to what i think i should get for the setup anyways. Quote Link to comment Share on other sites More sharing options...
stony Posted November 8, 2013 Author Share Posted November 8, 2013 Not sure if you can call it progress but…. Removed the converter for one last attempt at a stall. Going balls to the wall with a 7+K stall and see if that helps with getting the turbo to spool. Have lots of wiring cleaning up to do here. Also removed ATI damper to get timing marks laser cut. Yea the old ones didn’t come with timing marks WTF??? Also redid the install on the NOS solenoids and nozzle and installed them under the manifold so I don’t have that huge mess on top. Its all underneath now!! Before After Also redid some wiring behind the dash so removing the dash doesn’t involve snipping wires. Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted November 8, 2013 Share Posted November 8, 2013 Stony, I have the same "race" version of the ATI Damper also, w/o timing marks. Who are you having add them to your's, and can I get mine done too? Quote Link to comment Share on other sites More sharing options...
stony Posted November 8, 2013 Author Share Posted November 8, 2013 ATI does it for 40 bux. Quote Link to comment Share on other sites More sharing options...
flatrate Posted November 8, 2013 Share Posted November 8, 2013 Why not??? Got lots of support local for parts... at any rate I do not think anyone will even come close to what i think i should get for the setup anyways. Seems like alot of work, for what? just want a better motor? What intake manifold are you running? Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted November 8, 2013 Share Posted November 8, 2013 ATI does it for 40 bux. Cool deal... Thanks! Please take some pics when you get it back. I'd like to see the results. Quote Link to comment Share on other sites More sharing options...
stony Posted November 8, 2013 Author Share Posted November 8, 2013 Manifold was made in japan. Custom. Its just a stock manifold that was cut off at the runners and a new single throttle body plenum welded on. Quote Link to comment Share on other sites More sharing options...
stony Posted November 28, 2013 Author Share Posted November 28, 2013 Talked with ATI on the phone today and they were able to get some more out of my converter. Its on its way back now. Cant wait to get it back together and see how it does. Quote Link to comment Share on other sites More sharing options...
340ZXTTAZ Posted November 30, 2013 Share Posted November 30, 2013 That motor has a lot more in it. It's currently @ 18 psi right? That turbo hasn't even hit its sweet spot yet, am I missing something here why do yo want to sell the motor before it's reached it full potential? Quote Link to comment Share on other sites More sharing options...
stony Posted November 30, 2013 Author Share Posted November 30, 2013 Not selling anymore ;> Had a wild hair about doing a 1uz. IM OVER IT NOW ;> At any rate Yea... 18 psi will be 30-35 timing is very VERY safe. we plan on getting aggressive now that we are running E85. will need to add another fuel pump and 2000cc injectors soon. Quote Link to comment Share on other sites More sharing options...
flatrate Posted November 30, 2013 Share Posted November 30, 2013 You should get rid of that old school greddy turbo and get a new billet 6768 or something of the like.. or a billet upgrade to what you already have Quote Link to comment Share on other sites More sharing options...
340ZXTTAZ Posted November 30, 2013 Share Posted November 30, 2013 Not selling anymore ;> Had a wild hair about doing a 1uz. IM OVER IT NOW ;> At any rate Yea... 18 psi will be 30-35 timing is very VERY safe. we plan on getting aggressive now that we are running E85. will need to add another fuel pump and 2000cc injectors soon. SO was that dyno on pump gas? If so that is very impressive, right choice going with the E85 fuel. You should get rid of that old school greddy turbo and get a new billet 6768 or something of the like.. or a billet upgrade to what you already have I second this ^^^^^^^ Turbo technology has come a long way, especially in the last 5 yrs take advantage of that and don't be afraid to go bigger there are tons of 4 cylinders running 72mm turbos. with your transmission you should have no problem keeping a turbo that size in it's sweet spot(In terms of engine rpm). if you plan on spraying it off the line anyway that should help spool it up on the bottom end plus an anti-lag system via your ecu. Quote Link to comment Share on other sites More sharing options...
stony Posted December 1, 2013 Author Share Posted December 1, 2013 NO it was on E85. it made 650ish on 110 at 30 psi several years ago. Sure thing flatrate send me the turbo and I will put it on ;> Quote Link to comment Share on other sites More sharing options...
stony Posted December 6, 2013 Author Share Posted December 6, 2013 Got everything back from ATI. converter restalled and rebuilt, damper has timing marks now.... Quote Link to comment Share on other sites More sharing options...
sq_creations Posted December 12, 2013 Share Posted December 12, 2013 Hope the new stall works for you. Going from a 3k stall to a 5500 stall dropped my ET 2 seconds. I feel your pain on trying to spool turbos. One of the reasons im always changing my setup. That an I think of a better way to do things and can't leave well enough alone. Quote Link to comment Share on other sites More sharing options...
stony Posted December 14, 2013 Author Share Posted December 14, 2013 Yea me to. Cant wait to get it up and running. Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted January 9, 2014 Share Posted January 9, 2014 Any updates? Quote Link to comment Share on other sites More sharing options...
stony Posted January 11, 2014 Author Share Posted January 11, 2014 Not really. Damper is installed and I dropped the tranny off to get freshened up and fix a leak. Hoping to have it back next week then its on like donkey konG!!!! Oh wait i did install the nitrous fogger in a different location with a bung and a new intake pipe vs the hokie fitting that came with the kit. Quote Link to comment Share on other sites More sharing options...
