Nismo280zEd Posted February 20, 2009 Share Posted February 20, 2009 Found this site tonight. http://www.importdrivetrain.com/store/customer/home.php?cat=526 Synchro kits for 60 bucks and bearings for 60 bucks for the 5spd 280z Having never rebuilt the Z transmission before... Is a homemechanic able to replace the bearings or are they all pressed on and have to be installed at a machine shop? -Ed Quote Link to comment Share on other sites More sharing options...
Nizzan Posted February 20, 2009 Share Posted February 20, 2009 I've rebuilt two 5speeds so far, one being the 240sx, the other 280zx. While they are pressed on pretty good, it's pretty easy to tap them on and off. A gear puller can help in this situation as well. I found with putting new bearings and syncro's in, that the hard part was remembering HOW it all went together, not actually doing the work. Quote Link to comment Share on other sites More sharing options...
Nismo280zEd Posted February 23, 2009 Author Share Posted February 23, 2009 Nizzan said: I've rebuilt two 5speeds so far, one being the 240sx, the other 280zx. While they are pressed on pretty good, it's pretty easy to tap them on and off. A gear puller can help in this situation as well.I found with putting new bearings and syncro's in, that the hard part was remembering HOW it all went together, not actually doing the work. This part scares me as well, lots of photos before complete disassembly I'm hoping will aid in the process. Thanks for the information. I need to rebuild my 240sx 5spd aswell, syncro's are about toast. -Ed Quote Link to comment Share on other sites More sharing options...
rejracer Posted February 25, 2009 Share Posted February 25, 2009 I rebuilt a 79 trans with the help of the FSM and the proper tools. It's not terribly difficult. Quote Link to comment Share on other sites More sharing options...
Lone_Star Posted March 10, 2009 Share Posted March 10, 2009 I went through this when rebuilding a 5spd about three months ago. I bought a rebuild kit from Autozone that had all the correct bearings (good quality Koyos), seals, and the gasket for the front cover. They also have repair instructions that I used and they were real close to correct for me. I own several pullers, and now a new shop press (another story that involves a transmission), but only used a cheap puller to do mine. Just take your time, stack the gears, spacers, bearings, etc in the order they come off, facing the direction they came off, or put scribe marks on them to keep them facing the correct direction. I dont remember having to use heat to get anything apart or together, but sometimes it helps. If there is a transmission shop near you, they can help with the pressing on/off of bearings if you cant do it yourself. Here is a link to the Autozone kit, and on the same page is a link to the detailed diagrams and repair instructions. Quote Link to comment Share on other sites More sharing options...
Daphur280 Posted March 10, 2009 Share Posted March 10, 2009 rejracer said: I rebuilt a 79 trans with the help of the FSM and the proper tools. It's not terribly difficult. FSM as in Saturn and 3000gt FSM?? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted March 10, 2009 Share Posted March 10, 2009 Factory Service Manual Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted March 10, 2009 Share Posted March 10, 2009 I have done this. Clear out a large area...I mean CLEAR. Take off the parts one by one and lay them down next to eachother in the order they come off. Replace the old worn parts on the bench layout. Assemble in reverse order. Quote Link to comment Share on other sites More sharing options...
Zerocell5688 Posted September 24, 2009 Share Posted September 24, 2009 Lone_Star said: Here is a link to the Autozone kit, and on the same page is a link to the detailed diagrams and repair instructions. is there an updated link to the rebuild kit on this or anyother site i couldn't find it. a Part # would be nice too guys:mrgreen: ~J Quote Link to comment Share on other sites More sharing options...
zcarnut Posted September 24, 2009 Share Posted September 24, 2009 Zerocell5688 said: ...is there an updated link to the rebuild kit on this or anyother site i couldn't find it... http://www.drivetrain.com/parts_catalog/manual_transmission_overhaul_kits/nissan_f5w71_overhaul_kit.html Quote Link to comment Share on other sites More sharing options...
Zerocell5688 Posted September 25, 2009 Share Posted September 25, 2009 Awesome Zcarnut! you F-n rock man! So if i have a 77 stock 5-speed trans its probably the FS5W71A according to this sites rebuild guide so my part numbers would be DTS-BK104==>$ 76.65 (w/o syncros) and than DTS-BK104AWS==>$144.84 that doesn't seem very bad priced does anyone have any background with the kit? they mention that Quote 5th synchro ring is a black fiber ring (crush style)' date=' not available with kit 5th synchro ring is a black fiber ring (crush style), not available with kit [/quote'] so i suppose the next step is to find that component everything is starting to work out and make a little more sense day by day Quote Link to comment Share on other sites More sharing options...
