Mobious5 Posted March 31, 2009 Share Posted March 31, 2009 hey guys i need some help. basicly somewhere down the line i got the crazy idea to shave an n47 intake and slap it on my p79 head with no cold start, i dle control, pcv, nothing leading in or out the top side of the throttle body. the results... drum roll please...... the car wont start.... or it will, only after holding the gass down and after getting it to start continously tapping the gas to keep it going.... here are some pics of my setup.. looks ok, but isnt blocked egr block off plates on the intake and throttle body, blocked off hose coming from the coolent housing kept the breather from the block and left the inlet under the throttle body open (should probly go the something) like i said nothing hooked up on top of the tbody nothing hooked up to the cold start. blocked off egr on the exhaust manifold left this metal pipe open, i dont no if i should block it off or hook it up to something. my gay welder and paintin stuff here are some vids, check em out sooo basicly i need help with this hole thing because spring break is coming up in one week and the ladies love 280's.! thanks guys Quote Link to comment Share on other sites More sharing options...
S130Z Posted April 1, 2009 Share Posted April 1, 2009 1st off, in the second pic to the right of the yellow tape, that ground is for your fuel injectors. It closes the loop, if it's not hooked up, your injectors will stay wide open. Next, you need to check all of your open piping off the TB for vacuum leaks. Then disconnect and remove the AAC valve ( the silver thing next to where the cold start injector was). It is OK to leave the AAC and cold start unplugged. If I think of anything else, I'll let you know. Quote Link to comment Share on other sites More sharing options...
S130Z Posted April 1, 2009 Share Posted April 1, 2009 I just watched your video, the popping is most likely from the injectors being wide open and running a rich Air/Fuel mixture. Also, don't double up on your grounds. Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted April 1, 2009 Administrators Share Posted April 1, 2009 Good grief... Where to start... This hose outlined in "MAGENTA" is going to cause a VERY high Idle speed once it does get running. Either cap it at the manifold and boot or plumb the Air Flow Regulator into it. .... Uh... well... I have to run now... yeah.. go pick up Melanie from school.. BRAAP... OUT! Quote Link to comment Share on other sites More sharing options...
S130Z Posted April 1, 2009 Share Posted April 1, 2009 BRAAP said: Good grief... Where to start... This hose outlined in "MAGENTA" is going to cause a VERY high Idle speed once it does get running. Either cap it at the manifold and boot or plumb the Air Flow Regulator into it. .... Uh... well... I have to run now... yeah.. go pick up Melanie from school.. BRAAP... OUT! Good catch! Missed that one! I'm still trying to find some more things that are wrong with this! Quote Link to comment Share on other sites More sharing options...
Challenger Posted April 1, 2009 Share Posted April 1, 2009 I guess Ill ask here since I asked in your other thread and it went to the tool shed... What is wrinkling on the manifold? Did you just use normal paint rather then high temp paint? Or is it something else? Quote Link to comment Share on other sites More sharing options...
dhp123166 Posted April 1, 2009 Share Posted April 1, 2009 Oh man I feel for you. I have dug myself into some holes but you got yourself a lulu. I was under the impression that the magenta hose goes from the manifold to the carbon cannister. I am pretty sure a PCV valve is necessary for operation but I could be wrong. Your air hose schematic just looks...wrong. Maybe drop $50.00 on a service manual specific to your vehicles year and start from scratch. Good luck... Quote Link to comment Share on other sites More sharing options...
RUZN Posted April 1, 2009 Share Posted April 1, 2009 Yes Service manual. And looks like some grounds arent connected. Hosing dosent look right. hmmmm you didnt leave anythign in the intake right hehe just asking .. it happens. ummm Wires all right order? also Try adjusting the TPS or AFM check plugs what do they look like.. soiled? black? SO many things man... and that tube on bottom of manifold is open if I heared you correct if you have open airflow past the TB and the AFM then its gonna totally read the wrong airflow cause it will be sucking in air from any open holes and bringing to much air in thinking its running fine lol.. ooh wait I looked again I thinkg thats the Block tube.. not sure try to keep pics on same angle.. my neck hurts lol.. also is that hose coming from the fuel pressure regulator hooked up? looks to be just hanging down to no where... Quote Link to comment Share on other sites More sharing options...
woldson Posted April 1, 2009 Share Posted April 1, 2009 WOW! Ummmm, you have the no cold start injector, but you kept the cold air bypass, with only one bolt. My guess is you have WAY to much air from many sorces, and consiquently not enough fuel. Way that bug big??!! Quote Link to comment Share on other sites More sharing options...
Mobious5 Posted April 2, 2009 Author Share Posted April 2, 2009 Challenger said: I guess Ill ask here since I asked in your other thread and it went to the tool shed... What is wrinkling on the manifold? Did you just use normal paint rather then high temp paint? Or is it something else? The wrinkling paint came from alittle fuel that dripped down. after i bolted everything back up... i probly could of avioded that. i did although use high temp paint. Quote Link to comment Share on other sites More sharing options...
Mobious5 Posted April 2, 2009 Author Share Posted April 2, 2009 RUZN said: Yes Service manual. And looks like some grounds arent connected. Hosing dosent look right. hmmmm you didnt leave anythign in the intake right hehe just asking .. it happens. ummm Wires all right order? also Try adjusting the TPS or AFM check plugs what do they look like.. soiled? black? SO many things man... and that tube on bottom of manifold is open if I heared you correct if you have open airflow past the TB and the AFM then its gonna totally read the wrong airflow cause it will be sucking in air from any open holes and bringing to much air in thinking its running fine lol.. ooh wait I looked again I thinkg thats the Block tube.. not sure try to keep pics on same angle.. my neck hurts lol.. also is that hose coming from the fuel pressure regulator hooked up? looks to be just hanging down to no where... yea, ive dug myself a pretty deep one. I noticed that i didnt properly ground everthying. and im pretty sure your right, the hoseing is way off. to be honest i thought i could re route some of the lines back into the intake without caping off some of them. esp because i didnt hook up the idle controls. hopeing that the car would just idle normaly without all that other stuff. lol my fault about the angle, and the preasure regulator is hooked into the intake between the 3rd and 4th ports Quote Link to comment Share on other sites More sharing options...
Mobious5 Posted April 2, 2009 Author Share Posted April 2, 2009 S130Z said: 1st off, in the second pic to the right of the yellow tape, that ground is for your fuel injectors. It closes the loop, if it's not hooked up, your injectors will stay wide open. Next, you need to check all of your open piping off the TB for vacuum leaks. Then disconnect and remove the AAC valve ( the silver thing next to where the cold start injector was). It is OK to leave the AAC and cold start unplugged. If I think of anything else, I'll let you know. your right i forgot about those grounds, so its ok to not even have the AAC valve? nothing running through it and unplugged? Quote Link to comment Share on other sites More sharing options...
FlatBlack Posted April 2, 2009 Share Posted April 2, 2009 Hello Mobious. When you run a shaved manifold and do not use an Idle Air Control, the car will not idle or idle really really low at colder temperatures. I ran a shaved manifold for a while in Baton Rouge but didn't realise it affected startup until I moved up here to Arkansas and experienced really cold weather. Everything else held constant, and you don't have any other issues [grounds and other things listed above] than you can do a couple of things. You can adjust your throttle body plate stop so more air will get through, but this will make your car idle really high when it warms up [i prefer a 700-800 RPM idle when warm]. I have come up with a really ghetto solution for this but do not want to post my shame here on hybrid. I have told someone else what I did through PMs if you care to know. It involves vacuum lines, not a big deal. Good luck, enjoy your Spring Break! *EDIT* Alright, honestly I didn't see all the pictures before I posted. You have the IAC sitting on top of your shaved manifold, not hooked up to anything but the EV connector. Whats the point of a shaved manifold, brotha? This is my current set up on my old motor: http://s254.photobucket.com/albums/hh81/flatblack280/Shaved%20Intake/?action=view¤t=100_2475.jpg Quote Link to comment Share on other sites More sharing options...
Mobious5 Posted April 3, 2009 Author Share Posted April 3, 2009 Nice FlatBlack! funny thing is im leaving this afternoon for arkansas to canoe down the buffaloe for about for days. i hope around this time the water isnt to cold! Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted April 3, 2009 Administrators Share Posted April 3, 2009 Mobius5, Here is an intake swap with a 60mm TB conversion I just completed yesterday for a local customer. Some of the details may be of help in your project. Local customer located a non-EGR N-42 intake, 60mm TB, Pallnet fuel rail and TB spacer kit then dropped the car off and wanted it installed and tidied up similar to what we have done for many others, including rerouting the EFI harness along the firewall and under the fuel rail instead of over the middle of the plenum. Fired the car up yesterday, runs great, just as it did when it came in, other than the deleted air flow regulator as described below, other than that, no differnet! This is a bone stock L-28 EFI. Items deleted; 1) EGR, (This is a ’75 car registered outside of CA) 2) Air Flow Regulator (for a cold idle speed that the engine will idle on its own without holding the gas pedal, a "warm" idle speed has to be approx 1000-1200 RPM on a properly tuned L-28. If a warm idle speed of 650-800 is desired, then you’ll have to hold the gas pedal to keep the car running when cold till the car warms up, or reinstall the Air Flow Regulator.) 3) Coolant by pass that ran under the Air Flow Regulator. 4) Cold start injector and Thermo time switch. Tapped the cold start injector hole for 1/8" NPT, brass pipe plug installed. (left the Thermo-time switch in the thermostat housing, just deleted the wiring.) 5) A/C equipment in the engine bay. Items rearranged; but still functioning as OE! 1) Carbon Canister vacuum line has new port drilled and tapped into the back of the plenum and vacuum line rerouted along passenger frame rail and across the lower firewall. 2) Fuel Pressure regulator relocated to the firewall, fuel rail plumbed in a pseudo dead head style arrangement, (before anyone jumps on the “dead end EFI fuel systems cant be done†bandwagon, SEARCH! It can, has, and is still being successfully done, by the OE and tuners such as myself with NO ill effects NO vapor lock etc). Vacuum port of the FPR also has its own new dedicated vacuum port added to the back of the plenum next to the canister port. 3) PCV is now drawing fresh air, K&N filter on valve cover. (This caused the engine to ingest "false air" as the air being drawn in through the PCV system is no longer being measured by the AFM, yet the engine is breathing that air, i.e. “false airâ€), as such I will be fine tuning the part throttle tune with a combination of the water temp resistance and AFM adjustments, todays project. For those new to the stock EFI or EFI in general, just leave the valve cover breather plumbed to any port between the Throttle body-butterfly and the AFM and you’ll be just fine! 4) Removed the EFI harness and removed the outer sheathing from the harness that resides in the engine bay. Deleted the Thermo-time switching wiring back to the splice, also deleted the cold start injector wiring. (Just leave the wires cut, but protected from grounding/shorting. The computer doesn’t know the difference nor does the engine.) Separated the injector wires and the water temp sensor wires of the AFM and TPS wires into two separate runs. Retaped those as 2 runs. Reinstalled harness, routed the injector and water temp wires along firewall and then under the fuel rail, (can’t even really see them in this photo below, but they are there) and routed the AFM and TPS wires back in the stock location. Customer wasn’t ready to for a shaved intake, so this one was just painted and installed. Original fuel pressure regulator port plugged as well as a couple other deleted vacuum ports. Here is the picture, below that is a diagram of the dead-head fuel rail system. Boot between TB and AFM is not secured in picture, it needs to be secured! Hope this helps, Paul Quote Link to comment Share on other sites More sharing options...
Challenger Posted April 3, 2009 Share Posted April 3, 2009 Wow, thats great information brapp! That will definitely help me and many other when it comes to the point of adressing the engine. Quote Link to comment Share on other sites More sharing options...
svr240 Posted April 3, 2009 Share Posted April 3, 2009 Thank You brapp from me as well! I must have 20+ bookmarks on this process alone and you summarized it quite nicely. Challenger said: Wow, thats great information brapp! That will definitely help me and many other when it comes to the point of adressing the engine. Quote Link to comment Share on other sites More sharing options...
Mobious5 Posted April 12, 2009 Author Share Posted April 12, 2009 Thanks BRAAP and everyone this helps out a lot! Quote Link to comment Share on other sites More sharing options...
Mobious5 Posted April 19, 2009 Author Share Posted April 19, 2009 Hey guys i lost my key so i ended up getting a new ignition switch before i could start the car again.. After i poped that in i made a couple corrections. i grounded everything... then i plugged the two holes on top of the afm-tb connecting tube. Then i attempted to start the car and it did the same thing, it wouldnt stay on un less i held the gas. while doing this i heard a whistleing sound. it turnd out the be the pipe on the bottom of the TB thats supposed to go into the idle control valve. this now ive tried serveral things like plugging it, running it back into the intake,leaving it open... etc nothing works. but this is why i think this is my problem is because when i hook this up... this is the only way i can get it to idle, and at that, it on idles at 300 rmp just bearly on... how do i control the idle or am i missing something, because the car will start but it wont hold unless im on the gas. thanks hybrid Quote Link to comment Share on other sites More sharing options...
hughdogz Posted April 19, 2009 Share Posted April 19, 2009 I believe that is the idle adjustment screw. Back it out to see if it raises the idle to ~850 RPM. Quote Link to comment Share on other sites More sharing options...
