my 510 with Rb25det
510rb25det
my 510 with rb25det full built ..
here is some pic of the old setup ..
this car now have
Garrett t77
Greddy intake manifold
Apexi boost controller
SDS stand alone engine managment tuned by REVSPEED
86.5 8.1 Cp piston
Eagle rods
Arp head studs
Arp main studs
Acl rod race bearing
Cosworth main race bearing
Apexi head gasket 1.5 87mm
Head ported and polish
3 angle valve job
Tomei valve springs and retainers
All new nissan gasket
Nissan N1 water pump
Nissan N1 oil pump
injectors Precision Turbo 1200cc
Top Feed Fuel rail
custom clucth from father n son hold up too 750fpt
3 inch exhaust with medro bend
with no muffler
Full Roll Cage certified NHRA aprroved
Alot of suspension works done ..
now it has a R200 in
the new look with a roll cage
now the motor setup
alot more coming
now with big turbo, new injecter n fuel rail, n new custom exh manifold,
n sorry the engine bay is lil dirty ..
lol
i am not surprised that you've been hesitant to mash the throttle. just don't be alarmed if you hear news about Russia testing another launch of Sputnik on CNN the morning after you decide to put your foot all the way down.
that thing is going to fly if you manage to hook.
Right now it was tuned by REV-Speed making 612whp n 597 torque on 18psi on race gas.. so the car is scary.. with no traction ... i have not full throttled this car yet with all this power .. it scary .....
Wow... I had never heard of a high horsepower RB having HP and TQ numbers so close. Much less on a RB25.
And the swap is incredible!
Until the rear suspension is sorted out traction is going to be a serious issue, with the 510`s trailing arms toe and camber changes are going to happen as traction changes. Especially with the stock rubber 30+ year old rubber bushings in the crossmember and the moustash bar.
  • 3 months later...
