Subaru WRX STi R180 Side Axles
johnc
Next week my machinist will be cutting one pair of side axles (stub axles) that will fit in the 27 spline 2004/2005 Subaru WRX STi R180 rear CLSDs and 2006 VLSD. The flange end of the these side shafts will bolt up to the stock 240Z halfshafts. This pair is the prototype and will be made from 4140, heat treated, etc.
What I need is someone who can test these for me starting in mid-June. That means you must have the Subaru diff in hand (or can get one quickly) and have a running, driving, reliable car that can put some street and track miles on it in a short time. That's a tall order but you'll get to keep these side axles if you follow through and send me feedback, pictures, and measurements.
Edited by johnc
deleted list
Just a thought, but you might try asking that guy that did the write up for the Subaru R180 conversion, since he would probably have most of those parts on hand, if not all of them.
John , i have got a Subaru 180 diff 4.44 ratio with a gear type ( no plates ) lsd specialist ?? told me that it should be a viscous but its definetly not .
I want to use inner CV from Subaru and i made new flanges for the outside to fit 110 diameter Lobro CV without any spacer , i bought the diff but i still not know of witch type and year Subaru it is ,
Regards Adrian , www.va-motorsport.com
I don't know what Subaru sold in Europe or Japan. Here in the US they used a CLSD in 2004 and 2005 and a VLSD in 2006 on the STi. The gear ratios are 3:54 and 3:90. Even then I might have those figures wrong.
Hi John, the 2006 STI should be CLSD also (like the 04' and 05').
3.54 ratios are in the 2006 and 2007 STI.
3.90 ratios are in the 2004, 2005, and 2008 STI.
Torsen LSDs came in the 2007 and 2008 STI.
John , i found out about the lsd , its a Torsen T2 , the 4.44 is right , you are right about they probably do not have it in the US ,
  • 3 weeks later...
  • 1 month later...
