Pharaohabq Posted July 23, 2009 Share Posted July 23, 2009 So, I've read the the interlock system can be defeated on a 260Z, but I can't seem to find how to do this. I did SEARCH here, and didn't find out how, so if you know, could you run us through it? thanks Phar Quote Link to comment Share on other sites More sharing options...
jeffer949 Posted July 23, 2009 Share Posted July 23, 2009 All of mine was just taken off when i got my car. I havent found any evidence that anything has to be rewired or modified to get it to work they just have to be unplugged i believe. Your talking about the seat switches and stuff right? Quote Link to comment Share on other sites More sharing options...
at-jefft Posted July 23, 2009 Share Posted July 23, 2009 ya mine was taken care of when I got the car. I know the connections under the seat have been disconnected. I would try that and if that doesn't work, my guess is that you could just wire the connection closed. Quote Link to comment Share on other sites More sharing options...
AkumaNoZeta Posted July 23, 2009 Share Posted July 23, 2009 Is this refering to the seat belt being stuck? My 260's seatbelt has been stuck ever since I got it therefore making it unwearable Quote Link to comment Share on other sites More sharing options...
at-jefft Posted July 23, 2009 Share Posted July 23, 2009 Grim said: Is this refering to the seat belt being stuck? My 260's seatbelt has been stuck ever since I got it therefore making it unwearable No, we are talking about the system that requires the seat belt to be latched in order to start the car. Quote Link to comment Share on other sites More sharing options...
zcarnut Posted July 23, 2009 Share Posted July 23, 2009 There is more than one way to defeat the interlock system on the 260Z. Here’s one: Unplug the two six-pin connectors going to the interlock module. The interlock module is located behind the relay bracket above the passenger side kick panel. You must keep the interlock relay (located next to the plastic-covered fused links on the engine firewall) plugged into its harness. You can unplug and remove the emergency re-set switch, if you want to. The re-set switch is located on the right side of the engine compartment and has the red push-button on it. Quote Link to comment Share on other sites More sharing options...
Pharaohabq Posted July 23, 2009 Author Share Posted July 23, 2009 great, thanks for the quick answers. we'll try that and see if it'll let it start. This car's been sitting a long time, (16 years) but it's got like 0 rust. So hopefully we'll make it go. Phar Quote Link to comment Share on other sites More sharing options...
ArizonaZ Posted July 24, 2009 Share Posted July 24, 2009 The procedure is outlined in the back of the "How to restore your Datsun Z Car" book. I had to do the same thing when on my 260. Here are the instructions: 1. Cut both the red/green stripe and red/yellow stripe wires about 3 inches from the emergency switch. 2. Join the connector ends of the loose wires. 3. Insulate the connected ends and remaining loose ends on the switch side. I followed these directions and the interlock has worked great for me. No more pushing the red button everytime I start the car. Brad Quote Link to comment Share on other sites More sharing options...
HLS30-08077 Posted July 28, 2009 Share Posted July 28, 2009 Are they refering to the red push button switch on the passenger side fender with all the relays and crap? Thanks for posting this, Dave Quote Link to comment Share on other sites More sharing options...
zcarnut Posted July 28, 2009 Share Posted July 28, 2009 HLS30-08077 said: Are they refering to the red push button switch on the passenger side fender with all the relays and crap? Yes. Red push button switch = emergency (reset) switch. Quote Link to comment Share on other sites More sharing options...
HLS30-08077 Posted July 28, 2009 Share Posted July 28, 2009 Thank you. I need all the help and clarity I can get. Dave Quote Link to comment Share on other sites More sharing options...
motoman Posted July 28, 2009 Share Posted July 28, 2009 So this was posted for my cay. And all i did was unplug the wires from under the seat and it worked. Quote Link to comment Share on other sites More sharing options...
zcarnut Posted July 29, 2009 Share Posted July 29, 2009 motoman said: So this was posted for my cay. And all i did was unplug the wires from under the seat and it worked. Yes, that will work. But, it’s not a foolproof solution. Even when you do that the interlock relay is being controlled by the interlock unit and still subject to possible nuisance “no-start†issues. The preferred method is the technique described in post #8 which is what Nissan recommended in a TSB, which was copied in the "How To Restore" book. This method shorts out the interlock relay so that the relay and the interlock control unit are no longer part of the starter circuit. Quote Link to comment Share on other sites More sharing options...
Spooler Posted July 30, 2009 Share Posted July 30, 2009 I have this intermittent no start on my 1975 280z. Anybody have the wire colors to check. My red pushbutton switch is gone, hence the screwdriver in the car...LOL I think i see where it used to go on the passenger fenderwell, I am just not sure. Link to the book would be great. Quote Link to comment Share on other sites More sharing options...
motoman Posted July 30, 2009 Share Posted July 30, 2009 Yah thats where it is located. Quote Link to comment Share on other sites More sharing options...
ArizonaZ Posted July 30, 2009 Share Posted July 30, 2009 I dont think that the 280's came with the seatbelt interlock, from what I remember it was put on the 260's and then dropped when the 280Z came out, but they may have continued it into '75, im not sure. Quote Link to comment Share on other sites More sharing options...
Spooler Posted July 30, 2009 Share Posted July 30, 2009 Yes I have one. I see the relay in passenger side kickpannel. I am almost sure mine has been disabled. The problem is I get a low voltage at the starter trigger wire (10.5 volts) hence the no start. If they make the relay stay on all the time I may have a bad contact on the relay. I really need a Datsun wiring diagram. The place that I worked as a tech (Nissan dealer) threw there old Datsun manuals away cause someone deceided to clean up.... go figure.... Even my older fellow Tech's couldn't believe it. Quote Link to comment Share on other sites More sharing options...
ArizonaZ Posted July 31, 2009 Share Posted July 31, 2009 you can try looking in the factory service manual here, I recommend downloading it first before you try to open it. -Brad Quote Link to comment Share on other sites More sharing options...
Spooler Posted July 31, 2009 Share Posted July 31, 2009 Cool, Thanks. Quote Link to comment Share on other sites More sharing options...
sqweekykneecap Posted November 23, 2009 Share Posted November 23, 2009 hard wire a push button to starter. and or the start portion of igniton to the starter. easy. push button on mine. its realy cool actually! Quote Link to comment Share on other sites More sharing options...
