Beginner 240z 2jz
PA240
  • Replies 62
Where is your location in PA?
Lansdale. About 45min outside of philly
guys lets stay on topic....
Nice build so far keep it up and keep it updated. Yah I have to agree thats very little rust but we know how it is "while Iam at it"
I have found new presents. photo update this weekend sorry i have been slacking since i started school.
UPDATE-
Before i could start working I needed to clean the shop. I hate working in a mess.
Before:
DSC_0001-1.jpg?t=1255825391
After:
DSC_0083.jpg?t=1255825505
Now it was time to do work.
Started with fixing some holes
Drivers side:Its not totally done. The triangle in the right corner needs to be filled and it needs some more grinding. I think it came out ok for our first time doing body work and it will be covered by the fender.
DSC_0009-1.jpg?t=1255825630
Passengers Side: This side was not as bad. The patch was much easier the 2nd time.
DSC_0048.jpg?t=1255825959
Next up was some undercoating removal. Started using a propane torch and stiff putty knife for this. It works much better than a heat gun. After the thick stuff is removed it cleans up nicely with a wire wheel and some lacquer thinner.
DSC_0010-2.jpg?t=1255826104
Soon got tired of that so i decided to see what was behind the bondo on the driver side quarter.
The bondo was about a 1/4-1/2 in thick in the worst parts. It looks like the quarter rusted so they pushed it back and tacked this up.
DSC_0014-2.jpg?t=1255828998
The inner
DSC_0061.jpg?t=1255829621
DSC_0059.jpg?t=1255829519
More cover up
lol
DSC_0022-1.jpg?t=1255829774
Thought i would check the other side
DSC_0050.jpg?t=1255830136
This was just covered up
DSC_0052.jpg?t=1255830161
DSC_0056.jpg?t=1255830200
And the inner
DSC_0062.jpg?t=1255830341
Filled some holes
Some things i wana sell:
L24, E88 head, 66,000 miles when pulled, old style su's, I have the 5speed
someone could use this
I have a full factory ac system including the manual
man, everytime i look at your pics above, it gives me nightmares. i hate doing body work but managed to get 90% done this year by myself in my garage. im also going 2jz. and will be doing cage and ross member soon. check it out.
http://forums.hybridz.org/showthread.php?t=151616
Yeah it gives me nightmares to. I think im gonna get a lot of the body work started and let a professional finish it up. Your build looks nice. Cant wait to see it progress.
Update:
Went home this weekend and finished up the rotisserie. Putting the car on was a bit of a trick but we got it with 3 guys. Wouldn't want to do it alone. Amazingly the car didn't fall on the ground. Success fells good. I ran out of time to take good phots but i did snap some on my cell.
1101091757.jpg?t=1257131915
1101091756.jpg?t=1257131938
Guest stdgrabbag
the rust under your battery tray wasnt as bad as mine, and m car was a california car. then seeing those corners, i wonder what mine will be like.
I am in South Philly. I've just gone thru my frame restoration. Just a few more minor clean up and ready for re-undercoat and paint. We have to hook up sometimes. Please PM me your number and I will give you a call. I play poker up your way every Friday or Sat.
V.
how did you build your car rotisserie i see you used 2 harbor freight engine stands. cant wait to see how it works out for you. what kinda of rear end do you plain to use with ur 2jz?
There are a few threads on this froum on how to build the rotisserie.
We are planing on putting the stock diff (r160?) and universals back in and just run it till it breaks. Than most likely an r200/cv setup will be swapped in.
we have been getting some things done.
cell phone pics
1107091518.jpg?t=1258947411
1107092133.jpg?t=1258947442
1122091632.jpg?t=1258947476
1122091646.jpg?t=1258947504
  • 1 month later...
Z-Gad,
I've been searching quite some time to find a local engine shop to build up a mild performance NA 10:1 engine for my 240 from a pair of engines I've accumulated over time. I'm located near Lancaster. Any help would be greatly appreciated. Thanks.
With your power goals, I would have to agree with grtiz that going with the 1jz might be a bit more cost effective. At SupraStore.com, there are more parts for the 1jz, and they are less expensive than their 2jz counterparts.
Not to mention that the 1jz internals are good up to (according to some other posts on Hybrid Z) 500hp. But if you're set on a 2jz, more power to you, its a great build. :mrgreen:
