motoman Posted October 8, 2009 Share Posted October 8, 2009 So when i have my doors open they will not lock. But as soon as they are closed they lock no problem at all. Is this something that has happend to a lot of people. Was the z built this way or what? I wouldn't think so. If anyone has ever had this problem and overcame it please tell me what you did. Motoman Quote Link to comment Share on other sites More sharing options...
boostiswhatsfordinner Posted October 8, 2009 Share Posted October 8, 2009 Not sure if it works cause i havent tried it, but try pulling the handle and then lock it. It works on hondas. Quote Link to comment Share on other sites More sharing options...
rturbo 930 Posted October 8, 2009 Share Posted October 8, 2009 It won't lock when they're OPEN? Well, first, I'm not surprised. My mom's Jetta won't lock when open. Second, why are you trying to lock them when open? Great way to accidentally lock yourself out of your car. None of my Z's have working locks though, so I can't confirm if this is how they work or not. Quote Link to comment Share on other sites More sharing options...
neotech84 Posted October 8, 2009 Share Posted October 8, 2009 rturbo 930 said: ... None of my Z's have working locks though, so I can't confirm if this is how they work or not. +1 to that! Sorry can't help. Can you just use the key to lock it?? Quote Link to comment Share on other sites More sharing options...
stravi757 Posted October 8, 2009 Share Posted October 8, 2009 rturbo 930 said: It won't lock when they're OPEN? Well, first, I'm not surprised. My mom's Jetta won't lock when open. Second, why are you trying to lock them when open? Great way to accidentally lock yourself out of your car. None of my Z's have working locks though, so I can't confirm if this is how they work or not. when you close the door if it was locked it will just unlock unless you hold the handle up while shutting it. Ive Never had this problem before, maybe try spraying a bunch of Wd-40 on it. Or just lock it once you close it from now on. Quote Link to comment Share on other sites More sharing options...
giorgio61 Posted October 8, 2009 Share Posted October 8, 2009 Try to lube the back of the latch, the lock rod lever is probably sticking or worn and and only moves when you close the door and the latching action forces it up all the way. Quote Link to comment Share on other sites More sharing options...
Lone_Star Posted October 8, 2009 Share Posted October 8, 2009 My understanding is that the pre '77 cars are that way. You have to lock them from inside once the door is closed (typically the passenger door), or lock with the key from outside. The '77-78 cars have a different mechanism and latch that allow you to lock the door, then close it while holding the outside handle up to lock it. The '78 I had worked that way, and my son's '74 has to be locked with the key from outside. Quote Link to comment Share on other sites More sharing options...
Midnight-280Z Posted October 8, 2009 Share Posted October 8, 2009 Lone_Star said: My understanding is that the pre '77 cars are that way. You have to lock them from inside once the door is closed (typically the passenger door), or lock with the key from outside. The '77-78 cars have a different mechanism and latch that allow you to lock the door, then close it while holding the outside handle up to lock it. The '78 I had worked that way, and my son's '74 has to be locked with the key from outside. Exactly what I was told and shown as well from my friend...I thought my door locks were broken too when I first bought the car because I couldn't lock them when they're open. Found out that the factory set them up like that...So, our doors aren't broken it's just the way they were designed. We're spoiled from newer cars with power everything and locks. Quote Link to comment Share on other sites More sharing options...
motoman Posted October 8, 2009 Author Share Posted October 8, 2009 Ok so its just the way the door was made. Dang thats going to be a P.I.T.A. Quote Link to comment Share on other sites More sharing options...
ncfisher Posted October 13, 2009 Share Posted October 13, 2009 never once locked my keys in my 240z thought they where all that way till my wife lock the passenger door on my 280z awhile back. Quote Link to comment Share on other sites More sharing options...
