chipo280z Posted October 14, 2009 Share Posted October 14, 2009 yesterday i did a compression test on my car.... it is a 77 280z with a 128et swap..the car runs good and it feels strong.... this is how it came up: 95 90 95 95 90 95 it looks really like a really low compression... I did the test with the j-pipe off and the throttle fully open, sparkplugs removed, and a good battery... what would you guys recommend as the next step... Quote Link to comment Share on other sites More sharing options...
S130Z Posted October 14, 2009 Share Posted October 14, 2009 The thing to really look at is how close the numbers are to each other. As long as they are close with one another, it doesnt matter too much on what your numbers are. The best thing to do if you are worried is do a leak down test. Quote Link to comment Share on other sites More sharing options...
woldson Posted October 15, 2009 Share Posted October 15, 2009 Search compression tests. WOT, when testing. Quote Link to comment Share on other sites More sharing options...
z-ya Posted October 15, 2009 Share Posted October 15, 2009 The numbers look a little low, but like S130Z said, it is more important that they are consistent across all cylinders. Was the engine at operating temperature? Pete Quote Link to comment Share on other sites More sharing options...
chipo280z Posted October 15, 2009 Author Share Posted October 15, 2009 z-ya said: The numbers look a little low, but like S130Z said, it is more important that they are consistent across all cylinders. Was the engine at operating temperature? Pete the engine was warm not at an operating temperature.... and yes it was at wot Quote Link to comment Share on other sites More sharing options...
Leon Posted October 16, 2009 Share Posted October 16, 2009 Have you checked your cam timing? A retarded cam can lead to low results across the board. However, I'd check with a different gauge first to rule out error there. Quote Link to comment Share on other sites More sharing options...
jc052685 Posted October 16, 2009 Share Posted October 16, 2009 I ran an 11.9 1/4 mile on pretty much the same numbers lol. Quote Link to comment Share on other sites More sharing options...
Daeron Posted October 21, 2009 Share Posted October 21, 2009 If the car runs good, and feels strong, I would look more at how close the numbers are to each other than to how "low" they are. They aren't THAT low, certainly not for a turbo engine. Was there any reason you ran the compression check, other than just a check-up? If not, I would not be concerned. Quote Link to comment Share on other sites More sharing options...
chipo280z Posted October 21, 2009 Author Share Posted October 21, 2009 Daeron said: If the car runs good, and feels strong, I would look more at how close the numbers are to each other than to how "low" they are. They aren't THAT low, certainly not for a turbo engine. Was there any reason you ran the compression check, other than just a check-up? If not, I would not be concerned. today i re did my wiring, soldering everything, fixing connectors... the cars pulls hard. alot more than my n/a setup. Right now im runnign the stock 7lbs iwth no intercooler and stock everything, even stock n/a njectors. I am jsut waiting to receive the injectors that i bought from s130z and it is ready to go to the track. Quote Link to comment Share on other sites More sharing options...
WizardBlack Posted October 22, 2009 Share Posted October 22, 2009 Do a leakdown... Quote Link to comment Share on other sites More sharing options...
