is $3500 a good price for a LS1 motor with transmission
I wouldn't drop that much money on something I couldn't see run first.
More importantly, though, you can't verify the mileage on the motor or tranny. Chances are everything is fine, but with the number of z parts I have laying around, I could put together a scrap tranny, scrap motor with decent enough compression to sell, and probably could find an ecu that I had to replace at one point, doll them up a bit and sell them as a rear clip.
Probably just some guy selling his camaro that got rear ended though.
$3500 is a little steep to begin with, depending on what he means by "accessories".
  • Administrators
How hard was it hit in the back?
If hit hard enough to affect the rear axle or tear the motor/trans mounts, the driveshaft could’ve bottomed out in the trans damaging the trans internally.
Most likely the engine is still OK, so long as it was maintained throughout its life, i.e. oil changes with decent oil at reasonable intervals, quality fuel used, etc...
Edited by BRAAP
  • Administrators
If hit hard enough to affect the rear axle or tear the motor/trans mounts' date=' the driveshaft could’ve bottomed out in the trans damaging the trans internally.
[/quote']
My guess is that the case would be damaged long before the internals. If true, it should be easy enough to spot.
