Ont240 Posted December 4, 2010 Share Posted December 4, 2010 Looking to put a 4spd automatic on a 2.8 turbo. What options are there? Quote Link to comment Share on other sites More sharing options...
Kash Posted December 4, 2010 Share Posted December 4, 2010 Niaasn Maxima, I believe 82 thru 1984... Quote Link to comment Share on other sites More sharing options...
Tony D Posted December 5, 2010 Share Posted December 5, 2010 Or better, maxima bellhousing, and Mitsubishi Starion Transmission (more clutch packs for a dedicated turbo-application along with modulator set for pressure, etc...just like the ZXT Three Speed, only with the o.d.) Same tranny, different bellhousing/torque converter and can't recall but maybe output spline on the the tailshaft... all easy enough to swap. The transmission unit itself beefier though. Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted December 5, 2010 Administrators Share Posted December 5, 2010 My father used the 4 speed auto trans out of a Z31 behind his L28ET in his '82 ZX-T. I'll report back with more info when I hear back from him, hopefully tonight. Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted December 5, 2010 Administrators Share Posted December 5, 2010 Ok, just got off the phone with my father. He used a Z31 Turbo 4 speed auto trans behind the L28ET in his '82 ZX. To get the Z31 V6 auto trans to bolt up to the L6, all he did was use the bellhousing from the L6 auto trans, that's it. He put several thousand miles on it, autcrossing etc. He also said something about the torque converter from the Turbo Z-31 is beefier unit than the N/A versions and feels it is necessary if producing above stock levels of Boosted performance. He wasn't sure if the trans internals themselves were any different but was adamant that the torque converter was different. Hope that helps, Paul Quote Link to comment Share on other sites More sharing options...
Tony D Posted December 5, 2010 Share Posted December 5, 2010 Do you know if that applies equally to the Z31T Tranny as well? That would indeed have the same internal beffier components like the L28ET (FSM can check I guess, extra clutch disc in low, higher line pressures, different modulator...) I may have found something worthwhile in a Z31 Automatic! I got two of the Maxima Trannies, but if I can go with the Z31T by just changing the bellhousing and torque converter to the one from the Maxima (or the Z31 Torque converter) that's cool by me! Would make the conversion of the 510 Wagon easier... Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted December 5, 2010 Administrators Share Posted December 5, 2010 On 12/5/2010 at 9:57 AM, Tony D said: Do you know if that applies equally to the Z31T Tranny as well? ... On 12/5/2010 at 2:37 AM, BRAAP said: He used a Z31 Turbo 4 speed auto trans behind the L28ET in his '82 ZX. ... He said it was from an early Z31T, don't know what or if any changes were made to the Z31 trans through its production run. Quote Link to comment Share on other sites More sharing options...
madkaw Posted December 5, 2010 Share Posted December 5, 2010 From what I have researched on this subject the differences are the modulator. If you get an very early(84) turbo trans, it has a vaccuum controlled modulator like the previous years. I think after 84 shifting is controlled electronically which would put you into buying an electronic controller-another 700$ Quote Link to comment Share on other sites More sharing options...
Tony D Posted December 8, 2010 Share Posted December 8, 2010 The three speed had different pressures, modulator, and extra clutch elements/wider bands to handle the torque. Looking at the SDS in the Nissan manual would tell you. I think I have one, I'll have to look. Quote Link to comment Share on other sites More sharing options...
19762802+2 Posted December 8, 2010 Share Posted December 8, 2010 I have a L6 Auto Bellhousing sitting around if anyone is interested. Thanks for that Info Braap, If that works out that would be a nice alternative to the other Auto trans swaps for the L6 motor and if it didn't require machining that would be even more awesome. Quote Link to comment Share on other sites More sharing options...
hoov100 Posted December 8, 2010 Share Posted December 8, 2010 I wonder if it's the same bolt pattern as a z32TT/q45 trans. Quote Link to comment Share on other sites More sharing options...
AtlantaZ Posted December 13, 2010 Share Posted December 13, 2010 Along the same lines... I wonder how hard it would be to mate an L460e to the L28? My goal being to build a manumatic/tiptronic (I know, groan, boo, etc...) that me AND my wife can enjoy. The more she enjoys the car, the more likely I am to secure funds for future upgrades without bringing down her wrath Quote Link to comment Share on other sites More sharing options...
Bernardd Posted December 13, 2010 Share Posted December 13, 2010 (edited) On 12/13/2010 at 5:21 PM, AtlantaZ said: Along the same lines... I wonder how hard it would be to mate an L460e to the L28? My goal being to build a manumatic/tiptronic (I know, groan, boo, etc...) that me AND my wife can enjoy. The more she enjoys the car, the more likely I am to secure funds for future upgrades without bringing down her wrath If you're going to tiptronic anyway just use the 240sx auto. It should bolt up pretty easily and is miles stronger than either the 3n and the 4n71 tranmissions. Edited December 13, 2010 by Bernardd Quote Link to comment Share on other sites More sharing options...
AtlantaZ Posted December 13, 2010 Share Posted December 13, 2010 Good to know! Have a good recommendation for a paddle shift kit for it? Or better yet - a source with a KA auto/shifter package? Quote Link to comment Share on other sites More sharing options...
AtlantaZ Posted December 14, 2010 Share Posted December 14, 2010 Would that be the RE4R01A variant of the 240sx tranny? The same model used in the Z32 N/A 300zx? Quote Link to comment Share on other sites More sharing options...
Bernardd Posted December 14, 2010 Share Posted December 14, 2010 Yes that's the one. The ka trans will have the right bellhousing. Quote Link to comment Share on other sites More sharing options...
AtlantaZ Posted December 14, 2010 Share Posted December 14, 2010 It can't be that easy... What is the secret $500 part that I'm not thinking of? Quote Link to comment Share on other sites More sharing options...
AtlantaZ Posted December 14, 2010 Share Posted December 14, 2010 (edited) I'll be running ~300hp/300ft-lbs at the wheels, and I'm concerned that the 240sx auto tranny won't hold up. Maybe the Z32TT auto tranny (RE4R03A)? (---Deleted to save myself from the Tool Shed!---) Edited December 14, 2010 by AtlantaZ Quote Link to comment Share on other sites More sharing options...
Bernardd Posted December 14, 2010 Share Posted December 14, 2010 I would at the very least buy a shift kit to increase the line pressures and to get firmer/quicker upshifts. The internals will hold it with no problems, it's the valve body settings that will hurt the trans. You can also buy a full manual valve body for that trans or the twin turbo auto. If the ka bell housing fits the twinturbo trans it should be fairly simple. You might have to drill a drive plate for the converter. I've done research but I have not had either trans apart to look at them. Quote Link to comment Share on other sites More sharing options...
DAW Posted December 16, 2010 Share Posted December 16, 2010 I'm thinking there's a difference between the turbo car Z31 A/T and the Non-turbo car. I believe the turbo car may not have a locking torque convertor but the na car does. I could be wrong...but IIRC the turbo trans has beefier internals re clutch packs, etc. Quote Link to comment Share on other sites More sharing options...
