Homemade headers installed on the 383
  • Please log in to reply
37 replies to this topic
#1 blueovalz
blueovalz
    HybridZ Supporter
  • Donating Members
  • PipPipPipPipPipPipPip
  • 3291 posts
  • LocationLittle Rock, Arkansas
Posted 03 February 2008 - 03:14 PM
The jig I built to fabricate these headers out of the car worked right-on. The headers went in (very tight, so that part was not easy, nor was it expected to be) fine, and surprisingly, all clearances were exactly as was on the jig.
The driver's side header
Posted Image
Passenger side header
Posted Image
Posted Image
#2 Corzette
Corzette
    HybridZ Supporter
  • Donating Members
  • PipPipPipPipPip
  • 814 posts
  • LocationJAPAN
Posted 03 February 2008 - 03:32 PM
Posted Image
Posted Image
Posted Image
Very nice TErry, is there anything you dont do yourself?:-)
Terry
http://www.picturetrail.com/corzette 10.97 @ 122.78 150 SHOT SBC 357 AFR190s HR RETROFIT
1973 240Z V8 SBC 1975 280Z V8 BBC 1971 Hakosuka 2001 C5 Corvette Convertible 13.06 at 106.38 with intake bolt ons
#3 rudypoochris
rudypoochris
    Member
  • Members
  • 1339 posts
  • LocationOakland, CA
Posted 03 February 2008 - 03:33 PM
That looks great!
1972 240z - Ford 302... Barely Running
#4 tfreer85
tfreer85
    Member
  • Members
  • PipPipPipPipPip
  • 618 posts
  • LocationBakersfield, CA
Posted 03 February 2008 - 03:34 PM
Any pictures of the jig and build stage? Those look awesome!!! Also how are you doing the steering column? Am I just not seeing it htere?
Tyson
Tyson
#5 Six_Shooter
Six_Shooter
    Member
  • Members
  • 1467 posts
  • LocationOntario, Canada
Posted 03 February 2008 - 04:03 PM
Did you just not set the date or are these pics 4 years old?
Looks like there's lots of clearance for the steering shaft to pass the lower part of the driver side header.
Z: 152391 Project Thread
Typhony: Project Thread
My rear view mirror doesn't have a zoom feature.
#6 blueovalz
blueovalz
    HybridZ Supporter
  • Donating Members
  • 3291 posts
Posted 03 February 2008 - 04:22 PM
I'm too lazy to reset the date on the camera after replacing the battery, but you're not the only one to bring that up. I guess it's time update it.
The jig was two 2x4s bolted to the crossmember, and to the rear plate as the engine sat on the engine stand. I used some thinwall conduit as the steering rod on the jig. On the below photo, you barely see the conduit angled up as it goes rearward over the top of the 2x4.
Posted Image
Posted Image
#7 Evan Purple240zt
Evan Purple240zt
    Member
  • Members
  • 1598 posts
  • LocationMadison area, WI
Posted 03 February 2008 - 04:58 PM
Killer fit man, you should be proud.
I am finishing my downpipe right now, I can't IMAGINE doing headers!!
Evan
1995 240sx....
1972 240z RIP
#8 Careless
Careless
    Member
  • Members
  • 3809 posts
  • LocationMaple, Ontario, Canada
Posted 03 February 2008 - 05:01 PM
amazing, thanks for sharing. :D
#9 Six_Shooter
Six_Shooter
    Member
  • Members
  • 1467 posts
Posted 03 February 2008 - 05:39 PM
I like the jig, very creative.
#10 wrenchtech
wrenchtech
    Member
  • Members
  • PipPip
  • 44 posts
  • Locationsoutheastern, Wisconsin, USA
Posted 03 February 2008 - 07:02 PM
I'm going to try to build up my first exhaust system (from the header back). I am going to use mandrel bends. Looking at your work I am wondering how to keep the sections square as I cut them to size. I want to cut several sections out of U and J bends that I am buying to get !5, 22.5, 30 and 45 degree bend sections. Thanks. -- Matt
See my 280YZ Dream Car Here
ShopKulture Blog -- A blog for Homebrewed Engineers, Gearheads and Metalworking Enthusiasts
#11 Evan Purple240zt
Evan Purple240zt
    Member
  • Members
  • 1598 posts
Posted 03 February 2008 - 07:05 PM
Matt, I have had good luck putting a hose clamp around the pipe and then tracing it with a sharpie. I think I got that from Austin Hoke if memory serves.
1995 240sx....
1972 240z RIP
#12 Six_Shooter
Six_Shooter
    Member
  • Members
  • 1467 posts
Posted 03 February 2008 - 07:08 PM
I have used hose clamps clamped onto the primary tubes, to be a guide for a line or saw blade.
I have also used a large tube cutter where I could, to get a square cut.
Even if you have a ragged or not so square cut, you can use a belt sander (preferably a vertical) to square up the cut, before fitting it to the next piece.
#13 heavy85
heavy85
    Member
  • Members
  • 1150 posts
  • LocationIllinois
Posted 03 February 2008 - 07:24 PM
Is that MIG or TIG?
Thanks
Cameron
#14 Six_Shooter
Six_Shooter
    Member
  • Members
  • 1467 posts
Posted 03 February 2008 - 07:55 PM
Looks like TIG to me.
BOZ, do you have any pics of other views, I just realized they are all from above the "frame rails". I'd be interested to see how the primaries below the frame rail are routed and merge into the collectors.
#15 wrenchtech
wrenchtech
    Member
  • Members
  • PipPip
  • 44 posts
Posted 03 February 2008 - 08:37 PM
What a great idea! Now I remember that pipe fitters use a flexible metal belt to do the same thing, but I have only seen them use it on straight sections of large flue pipes. Thanks -- Matt
#16 blueovalz
blueovalz
    HybridZ Supporter
  • Donating Members
  • 3291 posts
Posted 04 February 2008 - 04:57 AM
To add to the "hose clamp" discussion, I also used hose clamps to hold the various bends together after cutting them. If tightened well, I could hold 3 separate joints together using hose clamps placed directly over the tubing joints. The larger the bend radius, the better this worked. The short-radius bends caused a little problem with this (e.g up next to the flange stubs), but still held the tubes together. This way I was able to have all four primary tubes adjustable as I built the header. The use of the clamps then allowed me to tweak, correct, rotate, and shift the tubes around a small amount to perfect the close fit.
Then I drilled two 1/4" holes in the hose clamps and used that hole as a "port" for tacking the tube sections together. Once the tacking was done, I removed the clamp and TIG'd the rest of the weld.
Posted Image
#17 katman
katman
    Member
  • Members
  • PipPipPipPipPip
  • 605 posts
  • LocationAcworth GA USA
Posted 04 February 2008 - 01:29 PM
Having built L6 headers myself all I can say is great job!
#18 Evan Purple240zt
Evan Purple240zt
    Member
  • Members
  • 1598 posts
Posted 04 February 2008 - 02:04 PM
Posted Image
Terry, thats exactly how I did my downpipe. I held it together with hose clamps. It worked pretty well, but I ended up with too much weight so the damn thing kept falling apart! lol.
Excellent idea on the hole for tack welding though!
Evan
1995 240sx....
1972 240z RIP
#19 Six_Shooter
Six_Shooter
    Member
  • Members
  • 1467 posts
Posted 04 February 2008 - 03:26 PM
I had one hose clamp, that I have no idea where it came from, that was actually two hose clamps with a short piece of metal attached between, that I would use to hold the tubes together. I've been contemplating making some out of different sized hose clamps to hold an entire primary (or 6) together, before any tacking.
BOZ; did you get some wide hose clamps? The ones I can find are pretty narrow and don't allow for drilling a hole like that, tried it, only worked marginally.
#20 blueovalz
blueovalz
    HybridZ Supporter
  • Donating Members
  • 3291 posts
Posted 04 February 2008 - 04:42 PM
The ones I used were 1/2" wide. They were old, so I don't know if its just because they are old, or that the new ones are more narrow.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
