* * * * * 1 votes
RB Rebuild
  • Please log in to reply
69 replies to this topic
#61 redlinevo7
redlinevo7
    Junior Member
  • Members
  • PipPipPip
  • 90 posts
  • LocationBarbados, Caribbean
Posted 24 July 2013 - 04:58 PM
Thanks. Was that a two part paint, a spray can or brush on in a can?
#62 RB26powered74zcar
RB26powered74zcar
    XXXXXX
  • Super Moderators
  • 4471 posts
  • LocationLake Charles, Louisiana, 70605
Posted 24 July 2013 - 08:13 PM
Single stage spray paint. You are talking about the outside of the block, correct?
RB26dettZ pics
th_April_2012006.jpg ®
#63 redlinevo7
redlinevo7
    Junior Member
  • Members
  • PipPipPip
  • 90 posts
Posted 25 July 2013 - 06:09 AM
Yes. Thanks.
#64 cheftrd
cheftrd
    Member
  • Members
  • PipPipPipPip
  • 399 posts
  • LocationOkinawa
Posted 03 August 2013 - 08:46 PM
Standard polyurethane car paint works, as well. A bit more involved,as you have to mix it and should use some flex to keep it less brittle, but it's pretty impervious to solvents, gasoline, oil, and what not.
Anything in a spray can will work, but my be more suseptible to chemicals, rust, etc.
Matt Hutchens
MJR Performance
Japan
#65 ZT-R
ZT-R
    Totally Addicted
  • Members
  • PipPipPipPipPipPip
  • 1670 posts
  • LocationBeaufort, SC
Posted 10 September 2013 - 11:22 AM
What are you guys doing to clean out the oil galleys? can you knock the plugs out and tap them for NPT?
<p>72 240z R.I.P.S. Forged RB30/26DET, BW 9174EFR, Series 2 AEM EMS , Endyn Pro Head, R.I.P.S. Intake Manifold & 90mm TB, R230 Rear End, T3 Suspension, ect...My Build Thread
#66 stony
stony
    RB Moderator
  • Super Moderators
  • 4286 posts
  • LocationSyracuse Utah
Posted 17 September 2013 - 09:43 PM
When mine ate the number one bearing and collapsed the filter, it sent bearing material throughout my motor.  I used a bunch of brake cleaner cans and hi pressure air. Just sprayed thru all the galleys in as many directions as I could find till nothing but clean brake cleaner came out then pushed 80PSI air thru everything. I think I went thru 2 cases of brake cleaner doing it this way. After that I had the block and head cleaned in one of those big ass engine block washer that was heated. came out spotless, and oil looked brand new after initial break-in.
5.3 truck motor, BTR stage 2 cam, BWs480, custom intercooler, AEM Infinity, 2 speed powerglide, Fully built Ford 8.8, 4:56 gears/spool, 4 link suspension.
#67 Scrufffy
Scrufffy
    Newbie
  • Donating Members
  • Pip
  • 9 posts
  • LocationTehachapi
Posted 27 January 2015 - 01:48 PM
I loved reading through this thread, I know it's old but I wish the pictures were still working... Oh well, still very informative! I was absolutely sure I was going the ls route with my z until I found the RB section here... Now I think plans have changed, in part because of this thread and stony's "so you want to swap an rb" sticky.
Confused in Cali...
#68 stony
stony
    RB Moderator
  • Super Moderators
  • 4286 posts
Posted 08 February 2015 - 12:54 AM
Here is a link to where the article is hosted
http://www.skylife4e...w-to-build.html
#69 cheftrd
cheftrd
    Member
  • Members
  • PipPipPipPip
  • 399 posts
  • LocationOkinawa
Posted 08 February 2015 - 04:48 AM
Pix working again... ^_^
I let my hosting package lapse, and always forget that the pictures are hosted there...
Matt Hutchens
MJR Performance
Japan
#70 Scrufffy
Scrufffy
    Newbie
  • Donating Members
  • Pip
  • 9 posts
  • LocationTehachapi
Posted 20 February 2015 - 10:31 AM
Thank you guys so much for the link and fixing the pics! After exhaustive searching I've found the original post a few different times.
Short thread highjack:
I'm very stoked on an RB swap, and it seems like there's more JDM engine's available here stateside than in the past... Stony and cheftrd, what would be your opinions on a JDM engine with a compression test and startup warranty from the importer, as opposed to an expensive with almost price prohibitive rebuilt engine shipped form over seas for my Z? The idea would be to keep it mostly stock and just enjoy it for a time. Then do a rebuild, ecm, turbos and supporting equipment for some respectable but not ridiculous horsepower.
The problem I'm having is finding a shop near me that seems knowledgable, I know why that is, but it's a major hurtle for me.
Any advise if you guys have time either here or pm would be very greatly appreciated!
Threadjack over.
Edited by dub23, 20 February 2015 - 10:34 AM.
Confused in Cali...
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
