Splitter idea
  • Please log in to reply
87 replies to this topic
#81 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • PipPipPipPipPipPipPipPipPipPip
  • 12439 posts
  • LocationSeattle area, WA
Posted 29 June 2015 - 03:50 AM
I pretty much post about every project I do, so there are tons of pics here, but I tend to neglect my build thread. Here's a couple more.
Jon Mortensen, owner/operator www.petdoorstore.com
#82 AZGhost623
AZGhost623
    Always Here
  • Members
  • PipPipPipPip
  • 425 posts
  • LocationGoodyear,AZ
Posted 05 July 2015 - 02:49 PM
really like the looks of it, very cool with the side pipes.
I was looking at this universal splitter. Used on quite a few cars from the sounds of it. Someone was posting that they even got banned from using it. Looks like it could work with some minor modifications. I like the channels that are built into it similar to how @Heavy85 had his in page 3.
Edited by AZGhost623, 05 July 2015 - 07:54 PM.
  • JSM likes this
'76 280Z "Banzai Runner" GNOSE Custom Widebody
Stroked Rebello 3.0L, P90 Big Port Rebello Head, 279/487 Rebello Camshaft, Kameari Intake manifold, Triple DCOE 45's, Electromotive XDI, Headers / 2.5 Exhaust, 3.9 LSD R200
https://www.instagram.com/azghost623/
#83 JSM
JSM
    Giggigty Giggity Giggity
  • Members
  • 1431 posts
  • LocationOrlando, FL
Posted 05 July 2015 - 03:54 PM
Where's the link to purchase that?
1971 240z
1980 280zx
1988 300zxt
#84 AZGhost623
AZGhost623
    Always Here
  • Members
  • PipPipPipPip
  • 425 posts
Posted 05 July 2015 - 07:48 PM
http://rt-performance.co.uk/
Guy said its 235 euros, shipping would be about the same I suppose. Im still waiting on shipping, as he said it was only 35 euros locally (London). May hit up Ztrix and see if they can make something similar.
#85 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • 12439 posts
Posted 05 July 2015 - 09:12 PM
Yes, that would be good if it fit, but the diffusers would make it illegal for lots of different racing categories, including mine (X Prepared). Another option is the NASCAR COT splitters. I bought one and it was too narrow for my car, but essentially it is just the front lip and a little more, probably 10 or 12" deep, then you could do your own diffusers on the backside if you wanted, or just run it back to the x member.
Just to update on my splitter, I found that the turnbuckles were too long even at the shortest setting, so now I'm thinking I'll make different length supports so that I can move the splitter down in 1/2" increments. Thinking of just pinching the ends of some -8 fuel line that I have and screwing that to the splitter and the dam.
#86 RebekahsZ
RebekahsZ
    Life Member
  • Donating Members
  • 5388 posts
  • LocationFlorence, Alabama
Posted 06 July 2015 - 02:51 AM
I've built (only in my head) an airdam that is mounted on drawer glides, with travel stops at the bottom, that would allow it to rise and fall as it skimmed along the ground. With maybe replaceable white plastic skid pads on the bottom.
The problem with my splitter was that, even dropping straight down off the front of the hood, and racing on a fairly smooth and level track, it kissed the ground several times. I think it has to do with the distance that the leading edge is in front of the wheels. Starting 3" off the ground, I never would have dreamed that it would kiss the ground, but it did. And it wasn't from downforce: when I cut the splitter/lip off, it STILL kissed the ground. And loading it on the trailer with it installed was a no-go. The 3" splitter I built was fine without supports to the airdam (the paint and resin showed no sign of flexing). I'm confident the scraping was due to suspension bump travel (possibly) aggravated by downforce. For next season I am doubling spring rate, putting the splitter back on, and trying again.
Edited by RebekahsZ, 06 July 2015 - 03:03 AM.
1972 240z, purchased in 1991 for $900. Bone stock LS2/T56/DBW from 2006 GTO, swap completed in 2011. 400rwhp/435 rwtq. 2400# minus driver. JCI swap, Mantic ER2 clutch kit, JTR headers, single exhaust, Borla muffler, MGW shifter, M2 Differentials shortened Z31 CV axles, Z31 CLSD R200, Chequered Flag Racing billet stubs and companion flanges. MSD 2-step, Hurst roll control, both operated from switches on clutch pedal. 9" Hoosier drag slicks on Weld Draglites, 245/45/16 Hoosier A6/R6 on 16X8+10 Rota RBR. 225/250 sectioned coilovers, Koni 8610-1437RACE shocks, DP and EMI camber plates, MM shortened rear control arms, TTT front control arms, poly and aluminum bushings. Top speeds: Ohio Mile 174mph, C/GMS class record holder, best 1/8 mile 6.96 at 100mph, best 1/4-mile 11.0 at 126mph, best 60' 1.43, best 1/2-mile 148mph at GA 1/2-mile. Home Track-Jake's Dragway, Moulton, AL. SCCA autocross club - TVR, Huntsville, AL. Lets race!
#87 JMortensen
JMortensen
    Retired Admin.
  • Donating Members
  • 12439 posts
Posted 06 July 2015 - 07:04 AM
I think the sliding air dam is a potentially dangerous idea. If it's doing its job and making a bunch of downforce and then it loses contact, or if it hits a bump in the road and fails (on one side even), you're going to have a real issue. I know it's apples and oranges, but as I recall one of the main reasons that ground effects was banned in F1 was their sliding fences which maintained contact with the ground failed, causing a sudden lack of downforce and big crashes. Still, if you're going 170 mph, your risk tolerance should be adjusted to match the new conditions.
#88 RebekahsZ
RebekahsZ
    Life Member
  • Donating Members
  • 5388 posts
Posted 06 July 2015 - 10:06 AM
Thanks man! You saved me a project-and maybe my life!
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
