Dan_Austin
Overlooked 5-lug option?
I've read every major and likely most of of the minor threads here
concerning 5-lug swaps and brake upgrades. There are a handful
from a few years back exploring alternate hubs, and they seemed
to close out without success or a lot of effort.
I found a single post that mentioned a car with Conquest/Starion
hubs. The owner had purchased it that way and had no further
info.
An online parts store that has the decency to post full specs
of their parts helped confirm that the 87-89 Conquest/Starion
use the same inner and outer wheel bearings as our beloved Z.
Interest peaked, I found that a near by Pick-N-Pull had-
1. A 87 Starion on the lot (less than 2 weeks)
2. A 73 240Z
3. Several Toyota pickup/4Runners
All within a couple rows.
The Starion had no front wheels, so the hubs were easy pickings.
The 240z also had one wheel removed and the hub was on the ground
in no time. The Starion hub fits quite nice, so off to the Toyotas
I went to grab a couple calipers.
The Starion rotor is also 278MM, but with a 26mm friction surface
and a hat height of 66mm. A S13W caliper is 1~3mm too far outboard
if it is mounted to the outside of the strut lugs. A S12W does
not fit over the Starion rotor.
Like a twit, I forgot to bring any form of measuing device, so I grabbed
the hubs and the S13W calipers and went for the door. (I know the S13W
are not ideal, but it gave me a starting point)
Brembo has an oline Flash catalogue for rotors, and it can be searched
by dimension. I found a small number of rotors that would work with
no machining on the rotor and either no machining on the caliper, or
only minor tweaks for clearance.
I suspect there must be a gotchya somewhere in here, or this swap
would be in more than one post among the tens of thousands on the
board.
Since this is for my daily driver, I won't be moving much further
along until I can get my hands on a spare strut to mock up the
final assembly.
Edited by Dan_Austin
Share this post
Link to post
could you take some pictures as you put it together?
That is my plan. I believe the rotor I will end up using is
from an 86 Lincoln Mark VII. It has a ~95mm total hat height.
If my math and measurements are correct it will be centered
in the S13W calipers when they are mounted in the stock location.
Which means zero machining other than triming or removing the
dust sheild.
Next up is to buy the rotors, pads and source some decent 5 lug wheels.
I also plan to put an 81 ZX master cylinder on at the same time.
Share this post
Link to post
dust sheild.
Do you know the offset of this hub? I'm assuming it is a 5 x 4.5 bolt pattern?
Share this post
Link to post
just a thought, use 87+ factory 300zx turbo rotors, and 18-19mm(whatever the outboard difference is) spacers, and the apprpriate longer bolts..... sounds like it might work, but that would be a bit of stresser on the bolts being spaced that far....
Share this post
Link to post
I am still looking for a trashed strut to use for mock-up
and measurements.
In the mean time I has spent close to 10 hours using
a Brembo flash catalog to review rotors in .1mm hat
height increments, and then looking up the any potential
donor vehicles on r1concepts. The Brembo app is handy,
but cannot search by ranges, and care must be taken to
use the app back button and not the browser back button.
That method eventually eliminated the 86 Lincoln rotor,
since is has a built in hub (never seen one of those).
A 1995 Crown Vic rotor might work IF the S12W install
has close to 5mm of gap between the caliper and rotor
edge (doubt it)(hub/lug centric spacers may be required).
A 1994 Mazda MPV rotor has close to ideal hub and lug
hole sizes, is nice and wide, close to perfect hat height
but only 10.85" (also readily available and cheap)
I have a set of S13WB that I grab for reference and may
use them. I would prefer to find a mythical set of S13W
which internet rumor lists as using the same 43.5 pistons
as the the S12W, but has 9mm taller lugs, which would
make the Crown Vic rotor work and might be enough to
stretch to a 2002 Ford Ranger 12" (hub/lug centric spacers
may be required)
Keep in mind my goal(s) are-
Easy access to replacement rotors/pads (otherwise Wilwood
calipers and two piece rotors would be the solution)
Easier maintenance. No pulling hubs to replace rotors.
Better braking than what I have.
Minimal to no machine work. Custom brackets to cope with
rotor offset is not going to happen with what I have for
tools. Hub or lug spacers may be doable.
The Starion hubs appear to have been used by another hybrid'r
and met most of my design goals. Sadly the member does not
appear to have been here in months, so the easy answer is not
happening either...
Share this post
Link to post
Not really. I'm still looking for a trashed strut to take
measurements and mock up possible combinations.
I did to a another protracted round ouf reviewing factory
rotors and I am disappointed with the options available
for a rotor with a 95 mm hat height. If the next round
of measurements confirm 95ish mm hat, then it might mean
a 2 piece hat/rotor.
Another option that may be possible is that while looking
at Wilwood rotors, I noted that they also make a range of
billet hubs using the same bearings as the Z, in a variety
of bearing depths, drilled for both 4.5 and 4.75 five bolt
patterns and setup. MSRP also has a pair at well under
$300.
I need to get off my duff and go find a strut to use for
testing.
Share this post
Link to post
There was another member here that used the
Conquest/Starion hubs, but they've gone silent.
The Camaro swap does not do into great detail
either (what rotor, caliper, brackets, etc).
The wilwood Camaro hub is drilled in both
5x4.5 and 5x4.75, and looks like a great option,
if measurements can be taken to identify possible
caliper and rotor pairings.
There is a trashed set of spindles available on
eBay that I may just have to buy to get this party
rolling...
Share this post
Link to post
Modern Motor Sports does have various collection of hubs in
billet aluminum. With either no additional offset or 19mm
additional offset. I suppose that the extra $200+ over the
Wilwood hubs would justified by having someone tell you exactly
what brake components can just be bolted on.
The Starion hub is steel and not aluminum, so durability should
not be a concern.
A lot of this comes down to a mental experiment. This is my
daily driver, so I cannot have it torn apart for testing.
A post on these forums got me looking at the Starion hubs for
the advantaged of-
5 lub steel hub
Salvage yard available
Reasonable additional offset
Minimal machining for caliper mounting (hopefully)
Searching this forum and other Z related forums has uncovered
no specifics, so I guess I need to pickup the spindles on eBay
and just get to the business of taking the measurements.
Share this post
Link to post
did the Conquest hubs work for you? I have had no luck getting a hold of Modern Motor spots at all. I need to find a hub that will work or use some custom made adapters. I found a company in So cal that can make them. they would be 35mm (1.4in) adapters. If using flares then there would no be too much of an issue. I would rather find another hub to replace with.
Share this post
Link to post
If you are looking at crown vic rotors, there are 2 different ones depending on year. The newer cars have a different offset. Also, you may be able to use the rear rotors, they are vented as well and pretty big. I used to do police maintance and always looked at the setup as viable if a hub was found. you can also get cross drilled rotors for race aplication, or heavy street. The crown vic calipers are dual piston and have a great large pad, just need mounts. They seem to be close to the right spacing for mounting as well. I like the floating rotor as well, quick to change and no messing with the bearing. My question, whats your rear hub solution to match?
Share this post
Link to post
I have a set of chopped up front struts on their way,
so I should be able to start the mock-up process.
I have not decided on the rear yet. I see three
options, each with its own set of drawbacks...
1. Redrill the stock and use a spacer to match up
with the new front offset. I do not like the idea
of using a spacer.
2. Try to adapt Z31 stub axles using info found in
old posts by zcarnut. Finding someone to attempt to
do the required machining of the strut housings is
likely to be a challenge.
3. Custom stub axles. Just to expensive.
Share this post
Link to post
The other option is the new rear leg setup that TTT (TechnoToyTuning) sells that allows the install of the Z32 type rear hubs = much stronger alxe setup too. But that does get up there on the cost too but you do have a CV conversion and rear disk conversion at the same time (install the whole Z32 rear back setup including internal handbrake drum)
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
