    33211
    5167
    Wasteland280
    Wasteland280
  1. Yesterday
  2. I replaced the stock 370Z diff cover with a Nismo one, and got it bolted and torqued to the subframe.
  3. So is the fuel tank recessed below, and that is an access panel for filling? I’ll look into the black box as I’ll be running a fuel return as well. Hadn’t thought of offsetting the tank for balance, thanks.
  4. I have the ATL 12 gallon cell in mine. I also use the ATL Black Box sump with pump. The fuel return dumps into the top of the Black Box. I can use pretty much every drop of fuel in the cell without fear of starvation. My cell is below the rear deck and offset to the right for weight distribution reasons. You can just see the bottom of the cell in this picture:
  5. 11-28-2025. I started today by sanding out and using some filler glaze on the left headlight bucket, and then sanded down both front fenders. Then I finished scribing out the hole on the hood and cut it. After that, I went ahead and primed and painted the front fenders and the one headlight bucket I currently have. There are 5-6 spots I will have to fix / paint correct, but progress is made. Pics:
  6. Last week
  7. Area27 in Canada is only 400m above sea level, so I'm not sure that accounts for the lack of nice airflow. I'll def take some stuff off the motor, and see what I can figure out. I'm still very new to the LS platform, so there's lots of learning to be had!
  8. Decided to go with the ATL 12 gallon, just ordered it. It’s 10”. Will need to build a frame for it, should be good little project to practice some more welding.
  9. Yea Max is still arguing the problems with my doors was due to the amount of bodywork on my car. Yet he always goes silent when I post pictures of the holes being in the wrong place for the latch and pictures of the top ledge being too wide to let the door panel fit over it. Really weird situation but based on how successful his business seems to be doing I would say it's the correct business model to have in these modern times. I'm old and have this quaint idea that you should stand behind your product if you want to have a successful business. He's starting to push back on me posting my well documented problems with his doors and his lack of standing behind his product but based on the fact that the doors are unusable I'm going to get my pound of flesh
  10. Got my proofs back from speedhut with the Z in there.
  11. I can't tell from the tape what you're doing. Cutting a hole in the center of the hood for clearance? Making the hood into a donut or a U?
  12. Happy Thanksgiving! I started the layout on my new hood before going in for the holiday. 13 1/4" from the front hood corners. this should allow for the radiator support to see seen, AND because some of the center bulge remains, those bends in the steel will help with keep the sheet metal rigid. I wanted to keep some the center bulge anyway, as it helps set the tone for how the bodies lines go back visually. the side will be cut to cover the tops of the struts, yet, show the tops of the frame rails and how there are no exposed brake lines. With the hood being black but the engine compartment blue, it will also set off the edges around the polished engine sticking up. At least in my mind.
  13. I did a 14 gallon radium cell in mine because i plan on possibly running e85 and we have some 30-35 minute sessions with some clubs. I have it raised like an inch and a half out of the floor to make the bottom height where I was visually happy. My cell is advertised at 11.7" tall so if the ATL 10 or 12 is shorter then flush with the floor should be perfect.
  14. Thanks. That’s the fuel cell that came with the car, it’s too big (20 gal) and I don’t like it mounted on top of hatch floor. Going to explore Black Friday deals, thinking of going with an ATL because of the bladder and other safety features and I’ll recess it down as far as I can, hopefully it’ll sit flush. Trying to decide if I should go with 10 gal or 12 gal, 12 gal is a little cheaper for whatever reason. I should burn approx 5 gal a session at Sebring, the track I’ll frequent most.
  15. I just found this site as i started building my Z, and will be following along as you finish up this project. We are on somewhat similar paths so this will be fun to watch it come together.
  16. Wow, great progress! I love the cantilever design on the rear suspension. A few guys here have previously designed their own custom cantilevers; but AE is the only vendor that I'm aware of that has ever "mass produced" a system like this. Really interested to hear your feedback on how the whole TA package works once installed. Is that the final resting place for the fuel cell? If so, are you going to have a way to isolate it from the rest of the driver's compartment?
  17. Lower than 100kpa at WOT could be elevation too, if this log happen to be somewhere higher than your used to logging take that into consideration aswell. Id think where you have the filter should be a good spot for air. unless the aero is really creating a negative pressure spot for some reason. If thats not the case id think your on the right track with looking at valve train stuff. But don't rule out the sensor itself or the hose feeding it.
  18. Waiting on a few parts, but worked on the rear suspension. I cut out a rear strut bar that was welded in and started prepping to install the rear shocks. Also test fitted the rear differential, almost ready to bolt up.
  19. 11-26-2025. I got the rear tires mounted on the wheels and balanced, and I was able to attach one headlight bucket and then started painting several coats of filler primer for deep scratches. The bucket has deep scratches in the metal in the bottom of the scoop portion, so this will get a start on filling them, and then I will put some glaze on there and sand it smooth and sealer prime it before color and clear. The other headlight bucket, after sandblasting revealed a crease in it, and I don't have the moxie to want to fight and fix a crease and make it look good, so I ordered up a reproduction bucket. I then got a call from J&S Polishing, and ran down there and picked up my intake and valve cover. Pics heavy.
  20. Not super sure. At 100% throttle, the MAP sensor is really slow to respond and only climbs to 91.8kPa (atmospheric should be ~100). Here's a log at a good period of full throttle in 4th gear. Just pulling super lazily. This motor has always behaved like it's getting enough airflow. With 3rd gear sorted, I should be able to get it back out and do some testing. One theory is that with all the front end ducting, the motor is pulling a vacuum in the engine bay. Another is that the cam timing is off and needs to be tweaked. I think I might pull the front cover off and see what's up, and if there is anything obvious there before I get back out for next season. I've done cylinder temps, compression checks and leakdown and everything seems happy enough mechanically. Just something silly happening somewhere in the system.
  21. Oh, man....what a bummer! I guess the one good thing is that it happened at the end of the season. Any idea why the engine wasn't pulling hard? Is there a big elevation difference between there and home?
  22. Well, once again we are at the end of track season. Long story short, the car is broken, but I'm excited for what next year brings! Longer version; After a successful outing at the Ridge, I decided to join my Canadian amigos for a weekend at Area27 up in Oliver BC, for a members track weekend, some wine tasting, and a general good time. The tow up was smooth, it took about 8 hours to get there. I've brought the car into Canada before, and it's reasonably painless, but I got searched pretty thoroughly (thanks Random Searches!) on the Canadian side. I dropped the car off at the track on Thursday night, and got squared away for a fun Saturday ripping around the track. We got there early on Saturday, I put the car together, fueled up and suited up to go out for the first session. First problem was the car felt like it wasn't pulling at all on the straights. Area27 is a properly long track, with some serious straights, so I should have been making some inroads there, but the car refused to pull hard at the top end. Second problem came as I started my second tour of the track. I shifted down to 2nd gear for a hairpin, then went for third, with nothing there. No box of rocks, no grinding, just no third gear. Alarming to say the least, but more frustrating as there wasn't an obvious cause of failure. I pulled off, looked under the car, saw all the linkages were in the right place, and had to call it a weekend. Any issue was clearly internal, and not fixable track side. Ended up with about 20 hours of towing for 10 minutes of sorta driving around the track. Womp-womp. Cut to getting home, getting the car unloaded, getting the transmission out of the car and opened up. It became pretty clear pretty quick what the problem was: Immediately upon pulling off the cover plate, the 3rd gear dog ring was nowhere to be seen. Well, that's not true, there was a piece of it over here! Well that's not supposed to be there! You can also see a big gouge in the main drive gear on the right side of that photo. Great, more parts to replace. That was it though. A dog ring shattered, ping'd off the MDS pinion and that was that. I suspect some of the gnarly downshifts I had at The Ridge the month prior were the cause of this, and when I towed up to Area27, this was most of the way destroyed. Shifting out of 3rd, into 2nd, and then finding 3rd to be MIA sounds like it was holding on by a thread, and just abandoned ship all at once. Parts are here, I'll probably take some time today or tomorrow to stuff the transmission back in. There are a few little things I'm working through, but nothing serious or major. Mostly cleaning and refreshing safety gear.
  23. I was reminded earlier today about this thread and figured I'd post a quick update. Shell restoration has been moving along and I've been pinging the restoration shop for monthly updates. I just about finished reinforcement/welding on various suspension components so I'd like to get those powdercoated in a chassis/satin black. Fuel system has been completed and placed in storage. Waiting for some parts back from the machine shop for the oil system before I fabricate and weld on that. Busy with other projects too but several irons in the fire to restore my Z.
  24. These Aluminum Body Panels were introduced to the Public at the 2025 SEMA SHOW in Las Vegas. They were manufactured by Yahagi Industry Company located in Japan. The 240Z vehicle was in the Toyo Tire Booth at the Show. Front Head Light Bucket Front Hood Bottom Side of the Hood Right Front Fender Front Cowl Panel Front Aluminum Grille Right Front Fender Roof Right Rear Quarter Panel and Fuel Door Rea Hatch Pic Rear Panel left Rear Quarter Panel Flyer that describes Weigh Savings between Steel Panels and Aluminum Panels They would not give the price at the show but say it would be give out at the end of the year. I believe they are waiting till the Tokyo Auto Salon Show happening in Tokyo in January 2026. They were planning a production run of 100 of these Aluminum Panels. The well known Japanese Performance Company-Star Road is handling the sale of these 240Z panels. The panels have an excellent fit and well constructed. I would definitely recommend them.
  • Who's Online   0 Members, 0 Anonymous, 1706 Guests (See full list)
