    33295
    5167
    Btz white z
    Btz white z
  1. Yesterday
  2. EXHAUST SYSTEM REPAIRS- My 240Z Exhaust Pipes were damaged from scrapping them on Speed Bumps. I found a cracked at one welded joint and a few exhaust leaks. Since repair required their removal, I decided to raise the pipes higher as the same time. I designed this exhaust system so that whole system consists of three major sections. First -Front Section goes from Hooker Exhaust Manifold to the X-Crossover pipe. Second Section runs from X-Pipe to the Rear Right Angle Exhaust Pipes. The Last Section finishes at the Two Turbo Mufflers. So this repair and raising the pipes only required the Intermediate Pipe. Also, since I used Evil Energy V-Band Clamps to connect the pipes, it was a simple job. The Intermediate Pipe Mount consist of 1/2" Steel Rods bent at 90 degrees and bolted to the Differential Housing. To Raise the exhaust pipes, only the Mating 1/2" Mounting 90 degree Rods had to be shorten. Pic of Mounting Rods cut off and rewelded Pic of Mounts Powder Coated and out of Oven Pic of Fully Assembled Exhaust Mount Evil Energy 2 1/4" Lap Joint Clamps( Amazon $20 a pair) Rubber Exhaust Pipe Hangers(Amazon-$6 a pair) and 1/2" Steel Rod-Bent to (90 Degrees-Home Depot) Right Side Pipe Mount Left Side Pipe Mount The Exhaust Pipes were raised about 1 1/2". The job can be accomplished in one days if materials were at hand.
  3. Last week
  4. bummer about the bolt. pretty common SBF flaw. Engine looks good. TKX will be great addition. They fit the tunnel pretty well. I have one behind my 1jz
  5. Sorry, I misunderstood the question. It's a much easier proposition if you're just looking to flip it, IMHO....particularly if you can attract out-of-state buyers. Every state has their own unique requirements for titling and registration, and prospective buyers will (should) know that going into the deal. You will typically have to sell it "below" market value without a title, so be sure to factor that into your decision on how to proceed.
  6. Just looking to sell it, can I sell it without the title in place for someone's project car or do I need to obtain title for a transfer (is the main question). Thanks!
  7. Ugh...broken bolts in the block. What a pain. At least the motor was already out of the car! 👍 Making great progress -- keep the updates coming!!
  8. Part 8-The Roll Cage is now installed so the Roof Area is being prepared for the Gull Wing Door Build. A Major Obstacle that I foresee the Transmission Tunnel and Firewall may have to cut open because of the Huge Mercedes Motor and Transmission. But if they are willing to Eliminating the Tunnel and Widening the Firewall Opening, they should not be a Big Problem.
  9. 03-16-2026 ATLAS Z UPDATE: My welder showed up today and welded up my cross bracing and a few spots on the trans tunnel where it touches the firewall. While here, he pushed on the outside of the windshield as I pulled the rope and got the windshield in. Tried to get the hatch window in, but it wasn't wanting to do it. So, I will have someone help me with that rear one later. I went ahead and installed my mesh cover for the turbo.....I had to go down a size to clear the engine. I got started on putting the door frames back in and getting the windows working right, more to do on that. PICS:
  10. Got timing cover painted. Spent almost half the day dealing with a bolt on the timing cover/water pump that had broken off in the block. Tried all types of extractors, ended up having to drill it out and re-tap it a size bigger. Got the oil pan off and installed new pump and pick up for the new baffled oil pan. Got the main seal on, set the timing cover on and called it a day.
  11. Congrats...that shell looks pretty dang straight! As much as I hate to admit this, you'll probably get quicker/more responses to that particular question via Social Media. I can recommend some pretty good Z-car pages on FB, if you like. I wouldn't usually recommend FB for technical questions/discussions....but for an administrative question on a re-title, it might yield some good results for you. Again, welcome to the forum; and please keep the updates coming as your project progresses. What are your plans/goals for the car?
  12. I can do App for Replacement or Transfer of Title with a new registration, looking for other experiences without a bill of sale, plate, registration etc. before walking in there. I did confirm not stolen or salvaged.
  13. I'd probably start asking questions at the DOL/DMV. Maybe see if you can figure out who was the last registered owner, or if there is a process to get a lost title/registration.
  14. Hello, new user here, I’ve got a 1972 240z barn find, VIN: HLS30-69341, no registration or plates, looking for any interest or suggestions on reregistering non op at the DMV without being the clear owner…will add pics
  15. That has got to be the best balance of Form and Function of a Datsun that i have EVER Seen!! Absolutely amazing!!
  16. Dang, that looks so tight, turned out amazing! So they printed the part but then used that to make a mold I'm guessing? That's not the actual 3D printed part?
  17. if anyone's still tracking this build I have what might be a last update since the car is mostly done (lol is it ever done?). I finally cad-designed the front fenders and then had a local shop 3D print the parts, then took that to a bodyshop to integrate into the existing fender part and paint it. After that I overlayed the inside walls of it with carbon fiber for added stiffness and protection. I also cut the lower part of the rear fenders and put in a horizontal cf winglet to better extract air. Overall I think it looks great and the resulting new parts helps downforce a ton by extracting air from the wheel wells.
  18. Appreciate the suggestion. Will take a look there; although I have to say our "350Z" sub-forum hasn't really seen much activity in the last few years, unfortunately. 🙁
  19. 03-14-2026 ATLAS Z UPDATE: Since the intake was off, I went ahead and tackled the project I have been putting off. Modifying the Atlas Industries alternator bracket setup to work on my project. the mounting plate is 1/2" thick, and the alternator just wouldn't clear the frame rail, so after trying to cut the aluminum bracket down, I gave up and traced out the bracket on a piece of 1/4" thick steel and cut it out and drilled the holes out. I then used my Dremel to counter sink the holes so I could use the bolts and everything that came with the kit. I painted the steel bracket with silver engine block paint and the bottom bracket I had to trim 1/4" off of it. Then I was able to install he alternator (brand new AC Delco, nice unit), and then on to the fun part.....belt alignment. Using a straight edge, I had to keep working little by little shaving aluminum off the provided spacer and then lightly grinding the back of the nylon pulley and it turned out great! Then I went ahead and installed the fittings to use a 8AN line for the crankcase breather on the intake between cylinder runners 3 and 4, and I found that by leaving it black it is hidden and you cant see it, so that worked out better than I had planned. once the intake was tightened all down, it was time to finish the intercooler piping. The driver's side was VERY tight. I used two 90 degree sections and trial and error and cutting them down I was able to come up with a decent arrangement. so that piece, to be welded along with a frontal piece to weld a length on to eliminate some couplings were put together and I will take them to get them welded up then take all of the pipes to get powdercoated with the "polished aluminum" finish. I could get them polished.....but it would cost more......opinions? Lastly I put together the intake side, switching to a 4 inch coupling setup with the GM factory style MAF meter. it was 3.75 diameter, so I took some rubber strips that are adhesive on one side and ran a strip of it around the mating surface, and then I was able to tighten the hose perfect on it. I did have to use the 4 inch to 3 inch reducer on the end, as the engine has pieces sticking out that won't allow for 4" pe, etc. I have a 3" screen arriving soon which will be on the front and it should look pretty good. I will have to get inventive to add polished/chromed to it to get rid of too much black. maybe a very thin polished aluminum piece that wraps around it and can be fastened underneath? Anyway, here are some pics:
  20. 03-13-2026 ATLAS Z UPDATE. A week or two ago, I got with Joshua who runs JP fiber shop and advertises on most of the Z car pages a lot. He is located in the Dominican Republic and makes fiberglass and carbon fiber parts. He made my fiberglass smooth cowl piece. He began a project for me. To make a roof, partial quarters, doors and partial front fenders out of carbon fiber, but just a thin sin.....one that could be trimmed and bonded over existing steel. The idea I have is to make it look like a "Paneled" paint job. Since my 260Z is part american hot rod, part street rod, part sports car, and part Japanese classic, I have used ideas from each genre in this build. To achieve the paneled look, I have had John cut-in, 1 inch around the border of each panel, to include the front fender to door gap areas, and these outlines will be in the factory Nissan #305 light metallic blue, as the cut outs for the door handles and locks, parking lights on the front and rear corners, etc will also show the color "underneath". The body line is the cut off point for the side pieces. The front fenders will remain blue on the tops, with a black windshield frame and top, but a fiber panel is also going on the top. The job is almost completed and then he will mail it to me. I will bond it with the SEM 50 second panel bond epoxy. It is a love it or hate it deal. I fully expect most will hate it/think it looks stupid.....so there's no need to tell me, but I know you will. It is unique....the car becomes "art". here are some pics of the process of making hte panels and a few pics of random cars to show the paneled paint jobs that inspired this. I will be adding my gloss black flares OVER the carbon panels and a black roundel on each door with the number 7 cut out. Click below for video: Main Video 1.mp4
  21. Looking for info on a lt4 swap. Any info or pics, builds etc. I'm running apex touring suspension front and back. Will the dry sump oil pan clear etc? What kind of fab work to mount it etc. I've Google my heart out and can't find nothing other than a couple pics of the top view of the ones I've seen
  22. Earlier
  23. Check this out for chassis stiffening ideas. You're already ahead of the game, going with a full cage. https://imgur.com/a/chassis-stiffening-inspiration-R27sh
  24. Thanks for the reply! Occasional tracking at best, mostly weekend street use, hence saving money with the pro torturing suspension. Roll cage already installed, figured may as well benefit from the stability and a little more weight. Chassis reinforcement is one of my main concerns. Think I need to do a lot more. I’ll def check out VA Engineering, thanks!
  25. What will be the main purpose of the car for you? What do you want the car to be? Seeing as you will be installing a roll gage, iMSA widebody kit and an LS big block for I suspect power and torque, you will mainly track the car and won’t be driving on the road. I like your choice of Apex over T3 but that’s my personal preference. But why the Pro Touring and not the Track Attack kit? Also don’t forget the basics of the build like chassis reinforcement, safety features and fuel delivery. These chassis are over 50 years old so if you plan to track and abuse them make sure the basics are good, rust free and reinforced. A good roll cage will do a lot together with the frame sleeves and some bolt on parts but things like seem welding the chassis will also help a lot. VA Engineering over here in the Netherlands has some great pictures on their Instagram of their cages and seem welds. The transform the S30 Z’s into period correct rally cars and yes they do get used like a rally car should.
  26. THANK YOU Sir. I am really enjoying this car.
  27. Hi all! New to the forum. Early stages of my first Z build, hoping to get some feedback before my mistakes get too out of control 🤣. ‘73 240z powder coated chassis with roll cage. Has the frame rail sleeves. Will be doing more reinforcing. L76 6.0. Planning on replacing most everything but the crank. TR6060 and Ford 8.8. Full Apex Touring Pro front and rear. Apex steering rack and axles. Akebono brakes. BRP front sump oil pan. Leaning toward iMSA widebody kit. Corvette accessory setup, vintage A/C and electric steering assist. Want to be open to procharger in the future. Any advice on what I should be looking out for, or changes? Open to anything! Thanks in advance!
  • Who's Online   0 Members, 0 Anonymous, 719 Guests (See full list)
