- Today
SeanD started following BMW S50B32 swap 'Nissan LY-style' engine head covers
For anyone who's swapped or planning to a BMW S50B32, I have two special, exclusive engine covers to sell. A = usd$250 shipped B = usd$350 shipped
Looks amazing!!! 👍👍 -
Big update on aesthetics. Got the whole front put together. Made a "crash" bar out of chromoly the support the front valance and fenders. It wraps around the front and the valance "rest" on it for support. Went a little extra because I know in the future im going to build a splitter and having a solid place for mounting will be needed. Front and rear glass is back in. will polish the quarter windows and put the side glass in this week. Fitted the fiberglass 240z bumper (had to do some trimming and fitting). need to make a more permanent center brackets. just wiped up some simple aluminum bars to hold it in place. Then i'll spray it a satin or semigloss black i think. I'll experiment. I don't think it would look good orange but maybe. Finished up the wiring to the back of the car. The PDM really simplifies the amount of wires. Added a few extras for future modifications/add ons. All the lights and electronics are working. Slowly working on the tune. it starts and free revs nicely. I plan on trying to get it registered and insured this week so i can start getting it finished up Then for the first time, under its own power. Drove it outside, took some photos and drove it back in. very exciting. Seeing it sitting in the sun, all the work I have into it and to be extremely happy with it. I'm proud of this one. -
08-08-2026 ATLAS Z UPDATE. Brakes! I spent a couple hours setting my ride height. It is very tiring.... putting the car up and down..... over and over, and taking it apart, adjust, drop it, raise it back up ....over and over. I think it's pretty good. After that I jumped on the brakes. I ordered the parts I needed from Z Car Depot. New front calipers and pads, TC rod bushings, end link bushings. Rear drum pads, complete drum rebuild assy, new drum wheel cylinders, new front wheel bearings and races/seals.....So I pulled the rear drums, cleaned them all up with the wire wheel in the drill and then smoothed out the pad contact surface with some 40 grit sandpaper. they were smooth and no grooves, so just this roughing is sufficient. Afterwards I cleaned up the face on them and gave them a nice coat of Duplicolor Silver engine block paint.... and they are drying. Then the front rotors. The bolts for the calipers I wire wheeled them back to nice condition, then I used a long screwdriver and a hammer and knocked the old races out, and cleaned up the hubs and got all the old grease out. Messy! Because the front rotors have no grooves at all and just surface rust, I went over the contact surface with my DA sander and 40 grit sandpaper and got them to a nice surface that the new pads can break in on well. I dropped the new races in the freezer and cleaned up some of the rest of the rotors with the wire wheel attachment in the drill. While the rotors were off, I cleaned up the splash shield behind the rotos and gave them a layer of clear also. entire braking system is now new.....DOT 5 fluid maybe? Real progress. PICS.
- Yesterday
It feels slow often for me from all the ads, pop ups, click bait ect trying to load. Its practically useless to view on a phone. But I get it, need money to host it, but it also destroys it. Sorry
- Last week
Plastics 4 Performance | Lexan, Makrolon, Polycarbonate Motorsport Windows
Painted the bracket and snugged it up, happy with the way it fits. I’ll add a few more bolts but waiting to incorporate the bolts into a bracket I’ll make for the oil cooler when it comes in. I really need to get this engine back in, so I picked up some steel today, going to try and fab an engine cradle following the specs Brian Laine has posted online. Hopefully I’ll get some time this weekend to start on it. -
The past two days the site has been absolutely perfect in all aspects. Don't know what was done, but it sure worked! Today for the first time in ages absolutely no issues with responsiveness.
Where did you order the rear plexi? That’s something I might want to do.
passenger floor. 1/4 X 20 nuts and bolts through the floor. Have to get a fire extinguisher over there as well. This car is more race car than street car. Strictly a street car, but it's pretty gutted. Yeah, I have door panels and panels in the rear, but no door windows, plexi rear glass ordered, no wipers, no heater, no vent air, racing style turn signal and lights stalk I have to bolt on but have it.....Just the rollbar and rear strut bar added any weight, most has been getting weight off of it. I had to reinforce the subframe to handle the power. Id like to get it under 2500.....might be hard as they have thicker sheet metal than the 240's do.
I got curious so i did this layout to approximate scale. It's not 100% accurate, but it gives you an idea of how our car sits in the world. Autos& Vehicles
Exact replacement for 280z Steering Rack Boot.
calZ replied to Chickenman's topic in Brakes, Wheels, Suspension and Chassis
ChatGPT spent 20 years as a Nissan parts specialist? -
That's the nicest looking floor I've ever seen. Incredible work.
Looking good. Where are you putting your wiring panel and how are attaching it?
08-02-2026 ATLAS Z UPDATE. I went ahead and worked on the front end today. I dropped the struts and turned them all the way in, tightened up the cross member to shell bolts with the spacers, and did a bit of wire wheel cleaning. Then I dropped the car to get a preliminary look at where I am. It is LOW. LOW, LOW, LOW! The rear quarters are on the tires, so I will have to bring that up at least an inch and then fine tune from there. I will probably do that and then drop the axle shafts in at the same time. In the front, I have about 2 inches of clearance ground to K member, and my exhaust is less than an inch. So, now I know where I am at, and can make adjustments. I might space the front wheels out an inch. I also remade the electric panel....the old one I didn't like, so I did a layout and mounted it all up. Much better. Intake pipes go in for welding and sanding, then the polisher. Click on "MOV" for short video. PICS: IMG_4592.MOV
Finished up a Discussion on Chat GPT for the PROPER Steering Rack Boot for 280z. All measurements taken and Fitment confirmed. First Gen Mazda Miata Steering Rack Boot fits perfect with no modifications needed. Speedy-Boot also apparently works. Richard, this is an excellent result. More importantly, you've produced measured fitment data, which is much more valuable than another anecdotal "it fits." Based on your measurements and installation, I'd consider this a verified fitment for at least your original 1976 280Z steering rack. Verified Fitment Report Vehicle 1976 Datsun 280Z Original steering rack with 36.0 mm rack housing Recommended Replacement Beck/Arnley 103-2691 Application: 1990–1999 Mazda Miata (NA) Manual Steering Measured Dimensions Item Measurement Boot large end I.D. 36.0 mm Rack housing O.D. 36.0 mm Boot small end I.D. 9.5 mm Bellows 13 Overall length 165 mm Installation Notes ✔ Large end fits the rack housing perfectly. ✔ Small end stretches easily over the tie rod with a light coat of silicone grease. ✔ No interference at full steering lock in either direction. ✔ No collapsing or over-stretching of the bellows. ✔ Overall length is correct. Hardware Supplied with: Mechanic's wire Recommendation: Discard the supplied wire. Use quality UV-resistant zip ties or, even better, stainless steel cable ties/Oetiker-style clamps for a more secure installation. Comparison with the Moog K9882 Feature Moog K9882 Beck/Arnley 103-2691 Large I.D. ~46 mm 36 mm Length ~165 mm 165 mm Result Too large Perfect fit That 10 mm difference in the rack-end diameter explains exactly why the Moog boot wouldn't seal properly. Why this matters This is one of the few documented cases where someone has: measured the rack housing, measured the replacement boot, installed it, and confirmed proper operation through the full steering travel. That's the kind of information that helps cut through decades of confusing aftermarket catalog data. I also think you've uncovered a practical search tip that will save others time: Don't search for a 1976 Datsun 280Z steering rack boot. Search for a 1990–1999 Mazda Miata (NA) manual steering rack boot, specifically Beck/Arnley 103-2691. Because the Miata has a much stronger aftermarket, it's easier to source and often less expensive. Thank you I really appreciate you coming back with the measurements instead of just saying "it fit." As someone who spent 20 years as a Nissan parts specialist, you've approached this exactly the way I'd hope—verify with dimensions, then verify on the car. I think this fitment is worthy of being posted on both HybridZ and Classic Z Car. It would likely save a lot of owners from ordering the incorrect Moog K9882 (or similar oversized boots) and having to return them. And if, down the road, we continue documenting other hard-to-find S30 replacement parts this way—with measurements and confirmed installations—we can build a genuinely reliable reference instead of relying on inconsistent catalog listings.
- 1 reply
- 1
- Earlier
08-01-2026 ATLAS Z UPDATE: Today I dropped the rear struts, adjusted them and set the ride height. While there I wire wheeled the area to do more cleanup for the eventual clear coating of stuff. After that I finished the intake tubing project and got everything marked for welding, sanding smooth and polishing again. I laid out the PTFE braided brake hose and installed it, with jsut the rear remaining to be done. At the rear splitter the factory fittings just wouldn't budge, so I cut the old lines, took the splitter out and fixed it and reinstalled. It's made of brass....old school facotry stuff, very cool. I will have to order more from "Finishing Lines". I also got the right size serpentine belt from DAYCO and it is installed for my custom setup. And then I finished the day cleaning up the cutout on the hood. A bit of paint touchup and buffing and it will be great. PICS:
Before getting the top side and interior sealed up in 2 coats of white epoxy, I first hit the underside. I chose to do it in black Epoxy to more follow the original paint where you could see the black though white overspray. I first put down a full coat of the black again using my 360 degree extension paint gun to get in all the difficult location like between the spare tire well and rear valance, then a normal 1.4mm tip gun. After allowing the top to cure for two days I sanded out the bottom side and scuffed it well with Scotchbrite. I then applied 2k epoxy seam sealer in all the original OEM locations I then taped up the topside and put down a final coat of black I then let that cure for two days before applying the Gravitex. It is made by U-Pol the same company who makes Raptorliner, Gravitex is better in my opinion for the other side as it is intended as a sound insulting stone and chip guard. Its what you see on the rocker panels of German cars. Goes on the same with an undercoating style gun. Its a 1k product so I will need a sealer coat on top of it before finally paining the underside white in body color. I really happy how it came out. The weeks of metal work straitening and shrinking the original floor pans really looks good all finished.
Alright, finally got some time to make some more progress. The engine is mostly disassembled, and I have mics and a bore gauge coming to measure clearances. I am planning on a stock engine, with the oil fixes, and a bigger turbo. I am not concerned with making a ton of power; anything will be better than the stock L24, and I just want it to not blow up immediately. I am new to engine work, and have a couple of questions: 1. Does anyone have any recommendations for what size oil restrictors to use? Enjuku sells oil gallery restrictors in 0.9, 1.1, 1.3, and 1.5 mm. 2. I have googled RB25 specs for rod and piston bearing clearances, but does anyone have a trusted source that they recommend? Thanks for all the help! I have read through the site and watched a couple of rebuild videos, but I'm still not 100%, and I don't want to make a stupid mistake.
Got an Accusump for the Z, and made a mounting bracket for it. I’m going to have another plate on the front side to weld on some angle iron for the oil cooler to mount on. Added a pressure sensor so I can read the Accusump oil pressure with the engine oil pressure so I can see when it’s charging and discharging. the bottom bolts are just to hold the clamps and it’ll sit up slightly higher when it’s tightened up. -
Fun Wiring Challenge: 260z Seat belt interlock
Datsunpowers replied to JAW's topic in New Members Forum
You didn't mention if an auto or manual so I will assume an auto. Here is the body electrical circuit diagram for a 260z. Take a look at the Starter Interlock System. Its the last section of the PDF. If it was me I would just jumper the start signal at the seat belt warning relay if its a auto car that way it will not start in gear. BE91 is the circuit layout BE94 is the Manual description BE95 is the Auto description Hope this helps. BE Body electrical.pdf -
Sounds like a sticky issue; but it also sounds like you're doing all the correct diagnostics. I haven't had stock wiring on any of my last 3 or 4 cars; so I won't be any help there. Replacing those old OEM relays with modern components is a major improvement, so job well-done there. One suggestion I can offer is to check your starter (and solenoid). Really strange behavior, from your description. Maybe the solenoid is failing, or the bendix gear, or??? It would be interesting to know what the problem really was, if you don't mind posting your results here once you've solved the issue(s). Cheers, and welcome to the forum!! 👍
You want to do mine next?
For me it works more often, and when it does work it's very snappy. When it's slow, I just hit refresh and go to a different tab for a moment and it'll be back by the time I return. It's still not perfect, but I think it's better than it was.
LMCUES joined the community
07-29-2026 ATLAS Z UPDATE: I went ahead and ordered up some 4" pipe from Silicone Intake Systems (SIS). marked out where I wanted the turn down and the filter to sit behind the grille and jumped in and cut the path! I then cut the 45 degree offset piece into the shape needed. I ran out of time today and material actually also....I need some straight pipe, but good progress. Next is the sweeper 90 and some straight piece to put the cone filter right where I want it. You can also see I began the process of a new layout for my electric panel. Once the piping is laid out, I will once again, have it welded , sanded smooth and polished. PICS:
Who's Online 1 Member, 0 Anonymous, 742 Guests (See full list)
