Thanks guys! @clarkspeed Daytona sounds like a real trick with the speed differential. Can you opt for a main shaft that you can just barely get rolling off the line, but allows the top speed? I keep thinking about a Winters style quick change, so I don't have to rebuild a couple of rear ends around my diff. I think my ratios are good for my power, and I just need to modify top speed with final drive.
Looking at west coast tracks, I think a top speed in the 150's is ideal. much faster you need tons more power, and a 5 or 6 speed to keep the ratios reasonable.
I took your note and the Maximum Motorsport design to heart, so when I needed to build my own, I opted for .250" plate. It ended up being a problem, since I had to bend it with a torch and vice! Really needed a hydraulic press to go with the torch haha.
Tire size was a big driver of this full conversion. All the new tires coming out share the 315/30r18 common size, and most race series include some form of a 12x25.5r18. The benefit of top speed gearing is an added bonus!
A quick link to the gear calculator I've been using: https://www.blocklayer.com/rpm-gear.aspx You can tie this together with a dyno plot of the car, and make sure that you maintain good powerband. It also lets you play with all the variables, so you can plan changes!
