Leaderboard
Popular Content
Showing content with the highest reputation on 03/14/24 in all areas
  1. Life has been kicking my ass lately! Between my job changing significantly, being super sick, and some significant medical issues with my daughter I haven’t made the progress on shipping orders that I have wanted to. Post here if you’re really itching to get yours and I’ll move it to the top of my list. Otherwise I’m moving along as ordered. I’d like to get these wrapped up so I can transfer the remaining funds over to Dan.
    1 point
  2. We’re going on track this Sunday at Willow springs Will set-up the car tomorrow at a friends shop since they have a flat-level garage floor (which I do not). Also in the middle of adapting the front brakes to 280zx rotor and caliper per EP spec-line. Caliper mounting on the strut assembly will require some welding and drilling, so it will have to wait till after this weekend. Greg Ira was nice enough to ship me some race pads he has that fit the OEM calipers.
    1 point
  3. I think you're mixing metric and English units. Nissan spec is .008" and .010" (inches) cold. So you need to make the clearance smaller thus raising the post.
    1 point
  4. @NewZed if one were to avoid using a surge tank in the engine bay, I agree. You would have to solve your slosh/starvation issues at the tank. Even a momentary vapor bubble pulled into your fuel line will cause a problem with EFI, if the ~40psi doesn’t cause it to collapse. SU’s, you would be OK to a point, since the fuel dumps into an atmospheric reservoir anyways (float chamber). I am a big fan of the quart surge tank though. S30 has a ton of space up front to choose from, but it would be a struggle to fit Z31+. That’s a heck of a lot of fuel to run-through, and the shape means you will use it all before you pull Vapor into your EFI pump. To be specific, this is my experience with the L28et street Z I have (@16psi). Have not raced yet… I’m just an Engineer that comes-off as a know-it-all, and humbly accept criticism as a result. I don’t mean to be condescending, but I recognize i can be. John and Ben are real racers though cars almost running! Should be hitting the track by Feb (thanks to my California mortgage payment). good luck to the OP! PS: same problem to consider with oil starvation, but it would take significantly more lateral G’s than what it takes to suck Vapor in your tank when <1/3 tank.
    1 point
