Leaderboard
Popular Content
Showing content with the highest reputation on 03/09/25 in all areas
  1. For a street car I think the rails make sense. For a race car that has a cage perhaps not. For a similar amount of weight you can triangulate the cage with tubing on top of the floor that extends to the suspension pickup points.
    2 points
  2. Got some time on the car today, everything is prepped and ready to pull the motor/transmission. Will be a few weeks before I can get back on it though. Pulling out the shifter I discovered a lot of wiring wire there touching the drive shaft, smh. Good thing I’m re-wiring this thing from scratch. Did a mock pull, hooking up to hoist, found out I need some thinner shackles, couldn’t get chains on. Looked at the frame rails too, only a little rust on one spot, but they are banged up a bit. I think I’ll cut out the rusted section, about 8”-10” or so and get the bull dog rails. I’ll order that after I pull the motor.
    1 point
  3. yeah, Bad Dogs I hear are good, and that you can put them over the factory ones, but if the factory ones are rusty, then they need to be repaired/patched first or removed and replaced with these. I I think they way blok did his with thick heavy steel is probably the ultimate (the youtube link I posted earlier).
    1 point
