Leaderboard
Popular Content
Showing content with the highest reputation on 03/23/25 in all areas
  1. Buy this book first There are a lot of details about the 240Z V8 auto to manual conversion you need to know before you start the project. Purchase and read the JTR V8 conversion manual. You can buy it here: https://jagsthatrun.com/collections/jtr-v8-conversion-manuals/products/copy-of-v-8-conversion-manual-for-volvo-200-series
    1 point
  2. 1989 Camaro T5 mated to SBC 350 Basics 1. T5 transmission: The 1989 WC T5 transmission is tilted 15 degrees towards the driver. The 15 deg tilt is absolutely no problem, I have done two just cut away the trans tunnel as in the picture below. The tilt is not noticeable once center console is installed. Unless you want to make a special transmission mount, you will need an 89 Camaro T5 bell housing, driveshaft, flywheel, clutch pressure plate/disk, throw out arm, throw out bearing, clutch slave and a 7/8" clutch MC. Note that there is a V8 and a V6 version of the T5 transmission. They have different spline counts. You will need the V8 version. 2. Bell Housing: 1989 -90 bell housing for V8. Verify that the pivot ball is in place as that part is NLA. 3. Flywheel: 158 tooth flywheel: https://www.summitracing.com/parts/zzz-50-6516 4. Clutch Kit: Zoom High Performance Clutch Kits HP1675-1A https://www.summitracing.com/parts/zzz-hp1675-1a/applications/ 5. Clutch Hydraulic Components: Camaro Clutch Slave: Napa sells the Camaro clutch slave. https://www.napaonline.com/p/NCF73110 Clutch Master Cylinder: Both Tilton and Wilwood make 7/8in. clutch master cylinders. The Wilwood unit is more compact allowing use of a larger brake booster. Tilton 74-875U: https://www.summitracing.com/parts/til-74-875u Wilwood 260-10374: https://www.summitracing.com/parts/wil-260-10374 6. Clutch Hose and Fittings: Hose: -3 A/N SS hose. Length TBD Roll pin to A/N SS line adaptor Russell 640281 (connects -3 A/N SS line to the Camaro slave): https://www.summitracing.com/parts/rus-640281 MC A/N SS -3 A/N line to 1/8in NPT adaptor Earls 961603ERL (connects -3 line to the MC): https://www.summitracing.com/parts/ear-961603erl 6. Starter: Hitachi gear reduction starter or similar unit. 7. Complete 240z brake and clutch peddle assembly swap. 8 MSA/JTR transmission mount See my post of 12 June 18 second post down lots of pictures
    1 point
  3. Outstanding job of documenting your work with numerous photos and written descriptions! I wish I had taken a lot more photos of my ZX project. John
    1 point
  4. And there we have it! A full quarter century old! Old enough, to run for the US House of Representatives!
    1 point
