Leaderboard
Popular Content
Showing content with the highest reputation on 04/29/26 in all areas
Just from those photos, I'd say you've got an R180. The 200 has a much more "bulbous" carrier case and rear cover. This video does an quick and dirty job illustrating the differences and distinctions: https://www.google.com/search?q=identifying+r200+vs+r180+with+pictures&client=firefox-b-1-d&sca_esv=b960a84cc5c43ab2&ei=haU1afOCFb_m5NoPmuGuoAY&ved=0ahUKEwiz2Zen7auRAxU_M1kFHZqwC2QQ4dUDCBE&uact=5&oq=identifying+r200+vs+r180+with+pictures&gs_lp=Egxnd3Mtd2l6LXNlcnAiJmlkZW50aWZ5aW5nIHIyMDAgdnMgcjE4MCB3aXRoIHBpY3R1cmVzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigATIFECEYoAEyBRAhGKsCSOYbUNoGWOUZcAF4AJABAJgBdKAB5wqqAQQxMS40uAEDyAEA-AEBmAIPoAKQC8ICChAAGLADGNYEGEfCAgUQIRifBZgDAIgGAZAGApIHAzcuOKAH0zGyBwM2Lji4B4ELwgcIMC4yLjEyLjHIBz2ACAA&sclient=gws-wiz-serp#fpstate=ive&vld=cid:1284de3c,vid:s3egG-klPBg,st:1151 For a more detailed and in-depth discussion of the technical differences between differentials, see this Pinned post here: Just as an FYI -- you have posted in the "FAQs" section, which is typically reserved for posts of an informational/educational nature. Kind of like a repository, or library, of technical information. I would suggest moving this thread to the "Drivetrain" section down below: https://forums.hybridz.org/forum/11-drivetrain/. These sub-forums are intended for open and freeflowing discussions. You can move the thread yourself; or I can do it for you, if you prefer. Your choice. LMK if you need any help. Hope this answers your question. Cheers.1 point
3 years later... took ages to find a good painter willing to take on the project. These days insurance jobs with small panel fixes seem to be more profitable. Luckily I found someone willing to do it in the summer months of this year while the insurance workload is reduced. Prepping... Overall quite happy with the result. Couldn't contain myself and started puzzling together the undercarriage the first chance I got. Pulled lines in the trans tunnel and assembled the suspension component. On the wheel first the first time since 2017!1 point
It has been a while... no real excuses more than waiting for the body to be completed. The car was recently taken off the table and put into the lift to fix the remaining structural items. This is mainly the rear of the floor and the floor supports with extensions back to the rear axle. Rockers + inner / outer wheel wells replaced + rear beaver panel (think that is what it is called). Same exercise on the right hand side. Rust had found its way into the quarters at the hatch close area (both sides). This was cut out and replaced. Floors have also been replaced extending up a bit on the foot well firewall - there were small rust damages, almost like Morse code, along the transition edge. I decided to replace the frame rails (completely shot) and the radiator support. Floor supports remain to be installed together with the frame rail reinforcements. The car had a or some front ding(s) at some point in its life - evident by the massaged areas on both right and left side shown earlier in the thread (sand blasting section). The right side was worse though, but decided to get the package to replace it all at once. In terms of body repairs and improvements the list is slowly coming to an end and the expectation is that the car is back in my garage early this summer. In the meantime I worked a bit on the engine and gearbox situation. I have two five speed gearboxes that came with the car. One has been in storage for a very long time and has damage at the end seal area towards the drive shaft. The one that was installed in the car cannot keep 5th gear and pops out under load (allegedly). Through some research I'm inclined to believe the bolt that holds the 5th gear in place has come loose (if someone has another idea let me know). Anyway, my plan is to install a 240SX gearbox in the car to get a bit more up to date equipment in this respect. I managed to source a used rather low mileage FS5W71C gearbox from a salvage yard - from my car I have 2 old FS5C/W71B gearboxes from which I can use the bell housing. I intend to follow the instruction posted by Steve Heimsoth on zhome.com. I also need to source a new early 240z driveshaft - anyone have a spare one laying around or know someone that does? Should be the early FS5C/W71A style driveshaft which is about 5cm shorter than the later FS5C/W71B gearboxes. FS5W71C as it arrived. After a bit of soda blasting. The 71B bell housing which will be machined to fit the 71C gearbox. That's it for now - it has been a dormant period now for quite some years. I'm hoping that I can pick up the pace as the car returns home.1 point
So... Another session of holiday and car tinkering is almost over.. Oh well, I tried to be productive. I've been trying to sort out someone willing to do the body metal repair work, but the availability in South of Sweden seems to be very scarce! Best offer I got so far is to start working on the car earliest this Autumn. Worst case I'll have to extend the search a bit farther, but I'd like to keep it close buy and with people known in the area. Luckily I can spend the time sorting out other stuff not directly related to the body. To be productive I decided to work a bit on the seating solution. In the end I have chosen to keep the Cobra seats (Paddy Hopkirk) that came with the car rather than buying new seats. Probably I would come off a bit cheaper buying new ones, but I really like the idea of having them specially made buy the local guy in Town. He has pretty free reins but will take inspiration from the original seats. Quite excited to see what he comes up with! In addition I worked on collecting and prepping all items that I want going to blasting and powder coat. I've broken down all of it to its basic Components and sealed off any sensitive areas like e.g. the bearing housings in the struts. Hopefully it can go out to the shop within a few weeks. This is the latest Picture I have, but since this was taken everything has been further stripped down. Found the front differential mount is cracked in the one of the plates.. Not sure if it was hit somehow because it looks like it has got a dent close to the source of the crack. Is this weld repair worthy, or a must scrap and replace? I was pondering whether to send the complete differential for blasting and powder coat as well. In the end I decided against it due to risk of sand entering the seals. I'm also not keen on breaking the diff into pieces and I'd rather have it assembled as I don't think there is any issues with it. Instead I went at it with a wire Wheel and a can of paint. With the car I got two differentials, one R180 installed and a loose R200. I had no idea what the ratios were so Before choosing which diff to use in the car I opened them up. - R180 - R200 - R180 - 3.9 - R200 - 3.54 Plan is to go with the R200 as I like the aspect of reducing crusing rpm slightly. Previous owner stated the RPM at 90 km/h is 3000 which he thought was a bit too high (I have a euro spec 5 speed) and I tend to agree with him. After a few hours of wire wheel work it went from this to this After first coat of paint (hammerite). Until next time.1 point
