naviathan
Everything posted by naviathan
  1. Expensive! If you can even find someone to do it. Your average "Joe Garage Mechanic" wouldn't take on a task like that. You'd have to find a specialty shop that's willing to do it. They're around, but I've never seen one myself. That's all a matter of oppinion. There are many ECU manufacturers out there. Electromotive, Mega Squirt, Haltec, etc... Google can render hundreds of manufacturers and all of them have their pros and cons. I went with Electromotive and their TEC3 unit because it's well known, has an extensive track record in performance, has a simple but extensive interface software and it's capable of doing everything I want it to. And it came with a package I bought from Top End Performance. It is very expensive though. Weigh your options and look at what you want to do with the car then look at the money you're willing to spend. Good luck!
  2. Ok we'll look at the actual question and make a decisive and basic answer. Given the subject of the thread being fuel the answer is multiport EFI with an aftermarket engine management system. Carb - Pros - Simple design that gets the job done. It can be used on many applications with little to no knowlege of the engine functions. - Cons - Doesn't self adjust for conditions and isn't precise in fuel metering. TB Injection - Pros - Again, simple design, but allows for more control than a carb as it can be controlled and the fuel can be mapped. - Cons - Reliant on manifold for even distribution to the cylinders. Little more complcated than a carb setup. Multiport Injection - Pros - Fully adjustable, can adjust individual cylinders, computer controlled to adapt to the enviroment, can be used in any application. - Cons - Difficult to setup, lots of wiring, expensive, and requires a laptop or computer connection to properly tune it (not sure why this is a con, but someone on here thinks it is). There now both questions in the original post have bee answered as simply as they can be.
  3. I don't know anything about it, but from the pictures it looks decent. My concern is the frame rails that he said were rust free. The Frame rails don't look right. They look thin and weak for something with that much power.
  4. I think you're right. I guess all the above manufactures should donate their products to me for testing....lol
  5. Riiiiigggghhhhhttttt..... Sure there's more to it than fuel metering, but in order to properly use what ever else you've done you need proper fuel metering. Throttle Body injection can cool the intake just as well as a carb and at the same time meter fuel better. With the proper sensors and a decent knowlege of engines and how they work you can setup an EFI system easily and more precisely than a carb ever could. Lets put it this way, if you're smart enough to install and wire it up, then you can do the programming with minimal issues. Carburation has long since been obsolete and unnecessary. It's often used now because it's cheap and you can find almost anyone to set it up with nothing more than screw driver for tuning. Multiport is more involved, but it's more precise. You get fuel injected at the valve instead of at the intake. Your intake can be smaller and formed many different ways. Runner style intake are great for multiport as the runners can cool the air while the fuel is injected toward the end given time to atomize and properly mix into the cylinder. He didn't ask which was simpler to setup, he asked for pros and cons and which was best. Multiport EFI is the best for metering fuel accurately. It's difficult to wire up, but easy to tune as you pull up a laptop and plug it in. Everything else is as simple adjusting and watching sensor readouts. How do you adjust a carb? Oh yeah, turn a screw, run it. Pull the plugs, check the color, turn the screw, run it, check the plugs, turn a screw....etc....Not to mention in order to properly tune a carb how many sets of plugs do you go through? Once they're flooded or burnt they're not reliable sources to read anymore. Color Tune helps a great deal, so what happens when it get cold outside? A carb doesn't know it's cold. it dumps the same amount of fuel. What about when you drive through the mountains? A carb doesn't know the alititude has changed... Guess what....EFI does. It senses the changes in the exhaust and the intake and adjusts accordingly. Which would you really rather have?
  6. Although I'm not a 300ZX guy, the popular Engine Management for the classics is Mega Squirt n' Spark. It's cheap and well thought out. it can be wired into an existing harness or you can create your own. There's A LOT of custom aftermarket ECUs out there. Search around for engine management or fuel management and you'll find a lot. I bought an Electromotive TEC3 system while I was Iraq because I had the money, but it's an extremely pricey setup. Read up on the systems and make sure they'll do what you want. Consider the level of tuning you want to do. Multiport injection or Throttle Body? Do you want syncronous injection or batch fire injection? Do you want a wide band O2 for fine tuning? Do you want a single unit to control fuel and spark? Do you want coil packs and crank trigger or distributer and single coil? MAP Sensor or Mass Air Flow Sensor? There's a lot of things to consider and make sure that what you want is supported by the ECU you're buying. After market systems a fully programmable so there is no need for a chip or performance anything, you make it do what you want it to. Weigh your options carefully and consider where you might go in the future too. If you buy an ECU now based on limited funds and later decide you want to do more and can't, you end up spending more money than if you just bought what you needed to start with and added on later.
  7. lol, sarcasm is a necessity in life. It can entertain you whether everyone else gets it or not...
  8. Oh sorry about that, I thought hit the quote in reply. I meant mikes comment on keeping the water pump running as well. Probably not, but I wasn't sure. No offense taken either way. Just wanted to clarify that I didn't mean the fan should run constantly, only until it cools off the engine.
  9. I'll start with your temp issues. Could be the thermostat or it could be a malfunctioning sending unit. I would replace the both of them at once as they are both cheap items. Typically if the gauge goes bad it won't read high, it'll drop low. The high idle won't be due to temps as if it's actually running that hot the fuel will start to vapor lock and it will run rough and low idle. I would suggest checking for vacuum leaks around the intake. More than likely it's the intake/exhaust manifold gasket that leaking. Also check the rubber boot that connects the AFM to the throttle body. it should seal tight around the ends and not have any holes in it. Stretch the rubber out as you're checking it and look for pin holes from the rubber dry rotting. For clearing out the emissions junk, it won't really increase the power any, but a lot of people like the clean look better. You can remove and cap off the egr valve on the right side, the auxilary air regulator (only used for cold starts), the cold start valve, and the high idle diaphram if you don't use/have the AC. If it gets cold you may want to keep these systems as they do help a lot when starting your car in the morning.
  10. Holy crap! You could hit a bus with that car and keep going when you're done!
  11. Not sure if that was meant to be sarcastic or not, but I just noticed an error in my wording. Connect the controller to a constant hot so it stays running until the engine cools down.
  12. "The Master Handbook of 1001 Functional Circuits" is the full title IIRC. It was given to me by an old friend when I was in the Army. I believe you can still get the on amazon used, but not new anymore.
  13. Carb - Easy to install, does the job. - Poor metering and difficult to tune. Throttle Body - Injection - Single nozzle spray, atomizes fuel well, simple wiring. - Hard to get precise fuel in each cylinder and relies heavily on intake design. Fuel Injection - Multiport - Awesome control ability, easy to manage and tune. - Difficult to wire up. Overall multiport fuel injection is the best so long as you get proper sensors and a good ECU to control it.
  14. Hmmm, yeah that would be cool. A timer with a switched and hot lead that triggers when the switched is dropped and it starts it's countdown then kills the output. That would be pretty cool. To keep the circuit simple and not pull a lot of power through it you could use a relay to make the connection to the fan, but trigger it with the timer. I could come up with something like that. Wouldn't be hard, other than figuring the timer circuit, but I think my Master Handbook or 1001 circuits has a design for that.
  15. It had two fan leads for operating dual fans and a 60A rated fuse so I would assume so.
  16. IMO you should connect the fan to a constant hot off the battery. When you shut the engine down it's good to keep the fan running to help the water cool better and keep the convection currents flowing. Otherwise when you shutdown (yes I realize the stock system is like this) the engine continues to heat the water until it reaches a certant point then cools down. This has actually caused a problem for me when I was traveling. The engine would get too hot when I would stop for gas and it wouldn't restart when I got back in until it cooled down some. Just a thought. If your battery is good it should be able to take the fan running for a few minutes after shutdown.
  17. You can get that controller much cheaper at an autoparts store. The one I bought was identical to that one except it was branded Flow-Tech and it was on $69 in a kit with all wiring and the through radiator pull ties.
  18. Search for electric fans and the ninth post down is title "what are you using to control your electric fan?" There's even more under that.
  19. Arizona Z Car... Z Race Products... (Sorry Dave) Which one looks better to you? I'd go with zraceproducts. Much cleaner and more professional looking.
  20. Ok, Flexalite controllers work good as do Flow Tech which is an Auto Zone brand and the fans that are commonly used are from a Ford Taurus. Please get rid of the tilda (~) marks in the title of your first post. Things like that make the search function useless when someone else is looking for this information. Also, this has been covered before so you might want to try it as well.
  21. http://www.jcwhitney.com/webapp/wcs/stores/servlet/Product?storeId=10101&Pr=p_Product.CATENTRY_ID%3A2002923&TID=100&TID=100&productId=2002923&catalogId=10101
  22. Just one taillight? That's odd. Are you sure the other light isn't blown and it's the brake light switch? There's a little plastic plug in the brake pedal that pushes the brake light switch to turn off the lights. I just had to replace that on my ZX a couple weeks ago because it cracked and fell apart. It's a basic replacement item in the help section of most autoparts stores.
  23. The pistons are definetely aftermarket, but they could be standard replacements. The cross hatching in the cylinders looks good, but doesn't look like it was machine bored. It reminds me of a quick hone job with a drill attachment. The white stuff is usually caused by coolant getting into the cylinders. My bet would be the engine blew a head gasket and the PO (one of them) rebuilt it himself using autozone parts and just did a crappy hone job to smooth the cylinders out. he probably slapped cheap rings in it and then ran the piss out of it before the rings had time to seat giving you all the nasty oil build up. The dings in the cylinders are definetely from the valves. It appears he caught it in time to keep from damaging anything though. Doesn't look like anything special. If it was over bored the pistons would have a metric number indicating the amount over sized they were on the top and I don't see anything like that. Sorry to burst your bubble, but they're not anything special and I would recommend rebuilding it as who ever did it last time probably had no clue what they were doing and used cheap parts.
  24. Cool, I got it. I'm not on my computer so I didn't know it wasn't installed. Nice work.
