383 240z
Everything posted by 383 240z
Spindle-Pin-Puller Loaner program
383 240z replied to Dave's topic in Brakes, Wheels, Suspension, and Chassis
PM sent. For everybody else, the tools I made are $70 shipped Priority Mail to a US address. They are made from 1018 tool steel with a pipe puller tube. I went with a larger 7/8 for the tool, the tool is double ended so IF you manage to strip it the other side of the tool is ready to use. Thank you everybody. Keith -
Thanks for the update, I've 2 more here waiting to be shipped. Also have enough material for 6 more to be made. Glad your happy with it Stock Car Mafia!! Thanks guys!! Keith -
I use Brendan at lt1swap.com $75 gets you a basic tune and return shipping. You can see the info at www.lt1swap.com/programming.htm
Thanks for posting the images Stock Car Mafia! I've had a report of a box being damaged while in shipping, I'll be working on this. I've 2 more that need to ship today. Thank you. 2 more finished tools that are ready to be shipped. Keith -
2 tools are gone. Ive 4 more finished ready to ship -
First batch of tools are done! I'm going to the post office for shipping supplies. They will be ready for shipment ASAP -
Shipping conformation shows the taps will be here tomorrow. Keith -
I wish you would have done this before I dropped a couple hundered bucks on material and tools, and spent a few hours of machine time -
I machined 6 of the tools today. I needed to order a box of taps. Sorry I thought I had some. Anyway, they should be here in 2-3 days. -
Material is ordered. I bought enough of the Acme rod, to make 12 tools. I'll be useing the 7/8-6 rod for a bit more wall thickness. Complete kits, will be made, with the draw tube. I will be shipping them the cheapest way I can. I only got emails from a few of you, PM me, I'll drop you my mobile number. I have a job I'm running now that uses an offset tailstock setting. So once that is off the lathe, I'll set it up for this job, provided the materials get here soon!! -
Sounds like enough ppl are wanting a tool. I'll start pricing materials I'll keep you all up to date as things progress. Do you guys want me to make just the thread and you get the black iron parts local, or do you want the complete tool? Keith -
LM7 vrs LQ4 Need help deciding
383 240z replied to 383 240z's topic in Gen III & IV Chevy V8Z Tech Board
What mounts are you guys using? -
May have a set. Send me an email tomorrow to remind me while I'm in the shop. I know I have a set of 260 doors. Redheadfabrication@yahoo.com I'll send you pics to make sure they are what you need
I was thinking that my goal was a bit out of reach, I have a line on a set of 317 heads for if/when I decide to go FI. Am I correct in my thinking that a +.400 crank and a flat flexplate will work with a TH700r4? Am I also correct that it will only work with pre-2001 4L60's? -
Subject: 1972 Datsun 240z Equipment already installed: TH-7004r built to race spec Dana 44m from '84 Corvette 1 ton half shafts LS1 fuel tank JTR kit with a Gen 1 SBC TPI injection Megasquirt fuel control LS1 fuel tank with Corvette FPR Goal: 450RWHP in a streetable package MAY add FI down the road if 450HP gets boring Must run on pump gas. Prefer to have TQ in the low end, and give up some HP at the upper RPM limits I've decided that the SBC in there just has to go. I've got 2 LS engines to choose from but I'm having a hard time deciding. What does the board think? First up: 2004 Chevy van 2500, 5.3l LM7 4l60, AWD rollover. Mileage unknown, oil looks good, radiator is full. It's drive by cable but missing PCM No body panels are sell-able, no oil on the trans dipstick, rear axle looks good Cant be started Whole van can be bought for $500 Craigslist deal no returns Second option: 2000 2500 Chevy truck 6.0l LQ4 with iron heads. 4l80 light front end hit, rad is fine, rusty truck. not sure why its in the yard no dipstick, I grabbed one from a SBC and put it in the dipstick tube, no oil. I looked in the filler cap, no sludge. They said I can pull the rocker covers and spin it over by hand. no starter to spin it up for a compression test. waterpump turns by hand, alternator has a little drag from corrosion, so it spins with a slight drag I have to pull the wiring and PCM, they will pull the engine. Only thing I see missing is the starter and dipstick. I can get the engine, wiring and PCM for $450 From a junkyard, no warranty as they cant start the truck to test the engine Thoughts on what would be better for my application and goals? Thanks for the help guys this will be my first LS swap Still putting together what works with what. The +.400 crank on the LQ4 has me concerned. From what I'm reading the 700 will bolt up if I slot the flexplate to fit my torque converter. Not worried about the wiring, more concerned with the fitment using my JTR kit, the ability to keep the 700.
Shoot me an email guys. Easier to keep track of. Redheadfabrication@yahoo.com I guess 5-6 tools would be enough to make it worth the set up time -
To the guys running LS1 intakes
How about your oil pan. Will a stock truck fit? Not for driving, but actually fit in the chassis? Just need to prove the fuel system and wiring -
Depends on how many guys need them. I can set my machines up to turn them out pretty quick, but not wanting to do the setup work to make 1 of them. Price will be very fair. parts+ a little labor Not wanting to make money on these, just to cover time and expenses. -
My plan is to get the engine and fuel system in place. Build the harness, get it running. Pull everything, add the other parts, re do engine bay, then re-install. Keith -
How much room to you have between the top of the intake and the hood. Also what mounts are you using? I've got a Gen 1 SBC in my 72 now using the Mike Knell (Jags that Run) mounts with LS adapters. Trying to figure if I can squeeze a shaved truck intake and factory oilpan, before I start buying parts that I don't HAVE to have. No a used LS1 intake isn't that expensive, neither is a used LS3 oil pan. But I have other things that need bought first. Engine in question is a LQ4. Keith
Thanks for the info John. Merry Christmas to you and yours everybody. If there is any interest in these. Post up. Get a few guys wanting them and I'll order material. Keith -
If anybody is willing to share dimensions on this tool, I'm a machinist by trade, I'm sure I could make a few sets for the guys needing them. -
Slow Build 240Z LS1/MN12 - Build Thread
383 240z replied to JoeK's topic in Gen III & IV Chevy V8Z Tech Board
Joe. What tank is that? Any pics of the install? -
OK Several years ago I started on my 1972 S-30, I took a majority of the rear suspension out and now that I have changed the plans 15 times I have lost count of what 'stach bar, forward mount combo I need. The plan is to put a 77-8 R-200 into my 1972 240Z. I have 2 different 'stach bars and a few forward mounts, and forward crossmembers. I however have NO idea what total package I need, I have been doing the whole eeny meeny miny mo where does this part go routine with no luck. does anybody have a photo with the orientation of the bars? Thank you Keith
