gvincent
Everything posted by gvincent
  1. tfree85, I had forgot about this post, I have ton's of Z pictures that change randomly for my desktop screen while working but do not know how to make them into a screen saver. I have the latest OSX release and run a G5 iMac and a 933 G4 Quicksilver. I just thought it would be cool to show off all the Z cars on my screen when I wasn't there as well. I would love the instructions. Thanks, Greg
  2. I searched and found this thread in the L6 forum http://forums.hybridz.org/showthread.php?t=111179 I posted some questions and pictures to this thread but figured my questions are probably going to be better answered in the Chevy V8Z forum. I am just starting to prepare my 76 280Z for the SBC engine swap and wanted to get my wiring in order as I went along. I just pulled out the FI harness and am not sure what connections to the ignition plug I need to re-wire. The pictures I posted in the thread show the plug connectors and I listed all the wire info that I could find in my crappy Haynes and Chilton manuals. Terry Steenhagen was nice enough to offer to send me a CD of the shop manual but it is not here yet so I have to use what I have for now. With the FI relays now also out of the picture will my fuel pump still work or do I need to rewire that as well? I am going to start un-taping the wiring harness on the passenger side this weekend and pull out what is not needed there as well so I am sure I will have more questions to add to this thread. I will post pictures as I go along so maybe other people can use them as well. I will draw up the wiring once it is all figured out and post it as well. Oh, I am still looking for a motor, it will be an LT1, or old school 383 stroker or 400SBC so right now I am keeping worst case scenario wiring wise so I am guessing the LT1. I have been posting pics as I go in my Gallery and Project car forum. Thanks, Greg
  3. Why are all the good deals out west??? I'm looking for a T56/LT1 383 stroker, or 400SBC combo and have never seen any deals like that in the Northeast! Hoping someday, the sooner the better. Greg
  4. Here are the pics, the first three pictures shows the Ignition connector from various angles. The White/Red wire mated to the Blue #73 wire from the FI harness The Black/Yellow wire mated to the White #76 wire from the FI harness The Black/White wire mated to the White #71 wire from the FI harness The Blue/Green wire mated to the Blue #74 wire from the FI harness The 4th and 5th picture show the single connector from the FI harness with the White #1 wire mating to a Blue wire. My 78 and 77 wiring diagrams don't match these colors up, I can't read the 76 diagram too well as it is too small. The 280Z is a 76 model. I got a feeling I am going to need to make some connectins to these two plugs but can't tell what is what. I don't need the FI relays anymore correct? What I can tell is that the Black/White wire was + power to one of the relay coils? the other ones I am not sure, do I need to run power from the battery to these conectors? I suppose I can re-hook the battery up and see if I have any voltage present. Do I need to run a wire to the fuel pump now that the FI relay is gone?
  5. Removing the FI harness, Yes proved my Pre-School teacher wrong again. I was able to stuff square objects through a round hole! Now to search and try to start to figure out this wiring stuff!! Radiator, hoses next!
  6. Inside view of FI harness hole
  7. gvincent
    Empty Harness hole
    Well, Glad to see that I once again proved my Pre-School teacher wrong..Yes you can fit a square object through a round hole!!!
  8. Finally was able to pull the harness out through the hole, had to strip some of the tape off to allow me to get the connectors through the hole one at a time.
  9. This is the mate to the single white wire, It is a Blue wire. I will have to research this one as well.
  10. This is a single connector with a White wire fron the FI harness
  11. gvincent
    ignition plug?-3
    Front view of the ignition plug/connector
  12. gvincent
    ignition plug?-2
    this is the other side of the ignition plug, showing the Blue/Green and Black/White wires.
  13. gvincent
    ignition plug?
    I think this is the ignition plug showing the white/red wire and the Black/Yellow wire.
  14. Harness disconnected inside, have to research the ignition plug, I think I need some connections there?
  15. OOPS....Your right, my Bad, I have wiring on the brain right now. Greg
  16. I was under the impression that the Datsun FI harness (Drivers side harness from ECU/Relay, Resistors, engine, injectors, coil, and lines to battery and fuseable links) and ECU were not needed for a swap. See:http://forums.hybridz.org/showthread.php?t=111179 I am sure I need to run some additional wires to where it plugged into the ignition harness under the drivers side dash, and figure out how to make the fuel pump relay work. I will post my pics later today. Greg
  17. Well I did have to slice the tape down by the FI relay connectors because I couldn't feed them through the hole intact. Once I sliced about 6" of tape off and seperated the two relay plugs I was able to feed them through the hole one at a time and everything pulled through easily. My questions on the Ignition plug still stand if anybody knows. I will post some more pics and more details on the wiring including wire #'s later today whe I get a chance. I didn't realize that the power feed from the battery through the fuseable links to the ECU ran through this harness as well. What starts out as 2 large red wires for Battery + and - become a big splice within the harness to smaller gauge blue wires feeding the ECU and the FI relays. I am sure I am going to have to run new wires from the Ignition plug to the battery and figure out what and where I connect the fuel pump relay to, which I am assuming at this time is under the passenger seat? Thanks, Greg
  18. Jon, No Oak Park did not exist, In fact Agoura high was only 4 or 5 years old when I was there. It was the only high school for all of Las Virginnes County, Bussed kids from as far as Liberty Canyon in Woodland Hills, Hidden Hills, Malibu Lake, Calabasas, Lake Lindero etc. in fact everything up to the county line/Westlake Blvd. My best frien was a guy named Jon Kern, his dad was the Senior Film editor/Producer for paramount studios and did the Odd Couple, Happy Days, Laverne and Shirley etc. We would sneak his fathers 65 Corvette out and run it through the canyons. We both had speed runs from the Agoura HS parking lot to Zuma beach #7 in 17 minutes flat!, I had a 68 Camaro SS 396 lowered with 14" in the rear and 12" in the front, The motor was built by Ed Pink in Van Nuys (Pink Elephant Heads) Offy Hi rise, Twin 750DP etc. We would race all the TO guys on Lindero road and on Weds night head down to the Valley and cruise Van Nuys Blvd and hook up and race behind Westinghouse for $30 or just for fun, My friend had a 67 6 cylinder body Nova with a high screaming 327 that was a real sleeper until you looked inside and it was all aluminum and tubbed wicked light. My girl friend at the time was Susan Webb, her brother was Jimmy Webb the song writter and performer, he had a Real 427 AC Cobra in pearl white, I used to meet him on PCH up near county line after coming out of Decker canyon early at sunrise and we would run PCH together at some real scary speeds in and out of the lifting fog! it was crazy! Yeah Decker was my favorite too, lock to lock some of those turns, 1000' ft drop, exciting! Encinal you could go faster and drift through the turns much faster and smoother though, Decker made you work it hard. Parents divorced and sold the custom house on the Island around 1980, My family is still out there and I will be attending the 35th reunion this year! Lots of stories, Lots of fun!
  19. Hey 260POS and Jmortenson. I grew up in Westlake on the island and graduated from Agoura HS in 1972!!! I can tell some stories about old Agoura road, Encinal Canyon, Decker Canyon and all the great canyon racing we did back in the late 60's early 70"s when US101 was only 2 lanes in each direction from Malibu Canyon road at the end of the Calabasaa down grade all the way to Thousand Oaks Blvd/county line. old Agoura road ran all the way along side the freeway at that time. Racing behind the lake in Westlake before there where houses there. Heck half the island was not even built. There was nothing behind Agoura HS and Lindero Canyon road just dead ended about a 1/2 mile past the school turn off. This was our 1/4 mile dragstrip! I have now lived south of Boston MA for 25 years. I have ton's of racing stories from that era, and went though a few of my 9 lives as well Always a Kid! Greg
