Everything posted by Kali
	Looked up the map sharing plenty of options prob going to go through and trouble shoot with what i can
	THanks for the info going to look that up right away. the Z32 maf was part of another setup and then my ECU shorted out so right now its still on.
	Block: * F54 L28et turbo block * JE Forged Pistons and rings 89mm * Mechart A-Beam Investment casted Stainless Steel rods * ARP Rod Bolts * Diesel Maxima Crank shaft Knife edged lightened and Zero balanced * Nismo Main cap bolts * Genuine Nissan factory Main and rod berings * Nismo oil pump * ARP Head studs * SCE 2mm Solid Copper head gasket with sealing rings * Brand new Front timing cover * New water pump * New Oil pump drive spindle and crank gear * Nismo single groove dampener w/ Nismo front crank bolt * 83 280zx turbo oil pan * all nissan seals and gaskets Head: * P90 Head off 83 ZX turbo * Schnider Cam Lift(In/Ex): .460/.460. Duration(In/Ex): 270/280. * Schnider matching dual valve springs, retainers, lash pads, and rocker arms * Ported polished * 5 angle valve job *New vale seals * Resurfaced and decked combustion chamber and intake/exhaust side * N42 non-egr intake manifold *420cc injectors *JSK Fuel rail w/ Autometer pressure gauge * T3/T4 Turbo Off 82zx 280zx 800 miles since rebuild * 82 280zx turbo outlet without power steering and a 83 280zx turbo outlet with power steering * 2.5" exhaust mid pipe * Oil pressure T-fitting w/ Hard style oil to turbo * zx turbo valve cover * MS Engine wire harness * Z32 MAF * 83 280zx electronic distributor * MSD boost dependent Spark retard Box * 2.5" thick innercooler Borg Warner T-5 zero balanced flywheel and clutch 3 core MSA radiator Walbro 255lph fuel pump MS1 V2.2 Relay board and Wideband O2 kit
	Well i just bought the MS1 2.2 witn relay board and Wideband O2 kit from DIYautotune.com Looking to upgrade later to MS2 and 3.0 board, but i want to get more familiar with MS1 and work from there.
	SRT-4 intercooler ebay piping
	New wishlist: Powertrain: ITB set up, with custom IM ZCC rocker arms KAMEARI Springs, Chain, Twin Idler Gear, Adjustable Timing Chain Tensioner, and Fully Adjustable Campulley MS-II EMS 750cc injectors S30 REINFORCED ENGINE MOUNTS Drivetrain: Z32 tranny swap R200 with Kameari R200 Differential GearSet Quaife ATB Helical LSD differential This rest is still kind of fuzzy for the moment but im working on what i want. Going to be moving to Japan... So i hope i can get some of the parts a tad bit cheaper.
	I like Neverdone's idea a little risky... but ah F**k IT!
	Same out here in Western WA i remember in 08-09 and 09-10 winter seasons was freakin wicked. Didnt have to take off to many days cause we were given snow days. Now there has barely been any snow out here all winter.
	Really like the valve cover color. Going with something simliar down the road.
	Love the color
	I say if your just looking to go fast in a straight line go with the chevy. Yes RB's can be expensive, UP garage, in Tacoma quoted me 13k just for the swap. First id look at the body and the chassis, see if you dont have to much rust all over the body too. Then when you find out that the car is rotted from the inside out on the passenger side mostly, go grab a beer at Redhook. Honestly i like my L28ET build, and yes trying to find some of the parts can be a hassel but its kinda fun. Its kinda a downer when most of the guys on here are like "SEARCH!!" But if you take the time and i dont mean just a little hear and there, I mean this is mostly what i do. I research when im at work. I do more reseach when i get home, the only time im not doing reseach is when im with my girl, or im eating, cause i dont want to get greese all over the keyboard. I do have a question for you though, If you want around 500+hp go with the chevy. Your in WA though so traction is gonna be kinda hard. You want to over pay for a japanese motor go with the RB. But also know you can go 2JZ, SR, a massive amounts of swaps. Ive seen a lot topics on RB26 head with a L28 block. Like i said take the time and do the reseach youll change your mind a thousand times before the car is done. Oh and take a look at my swap still in progress... http://forums.hybridz.org/index.php/topic/97614-l31et/page__pid__920660#entry920660 Hope you find out what you want to complete and post some pics!
	So picked up Z32 MAF on friday. Couldnt find pic from seller, so i found one on google. Anyways one more step towards build. Hopefully ill have some pics loaded when i can either one afford a new camera, or 2 borrow someones elses.
	Eh you didnt miss much of a game anyways. Oh but did you hear how so many people got gypped out of there seats today?
	Nice build!!! I have a similar front bumper always wanted to know what it would look like without the side skirts and rear pumper. Thanks
	So currently ive made a few changes. Right now there is a new downpipe from MSA, and BOV. Changed the ECU to Z31 ECU with wiring harness, and tomarrow im picking up a MAF from a Z32 with plug. Next to work on is the Fuel lines, and fittings. Right now im getting the parts together for a E85 conversion which wont take place until a year from now so that im in an area that can supply me with fuel. More pics to come, might even try to work on the body a bit myself. I know a lot of people have been giving me compliments on the paint, so if you want i can get the color code. But im probably going to go with a flat black and clear coat(not rattle can).
	Beautiful color, and I like the wheels too. What kind of seats do you have in there though?
	I got the new Downpipe and BOV today!!!!!!
	1 I DONT UNDERSTAND WHY YOU GUYS DONT LIKE CAPS. 2 Ive seen the TT setup just not on a carb before! Ok i kinda understand the CAPS thing, reminds me of a episode of "Raising Hope" "DOES THIS SEEEM MORE INTERESTING?!?!?!"
	Thanks TimZ, looked into the fuel pump you posted, and Red Kote, it seems really promising.
	Nice post Q&A, can you guys post a link with the possible rules for your region?
	THanks guy for the links it really helps. THanks TimZ too, wanted to PM you earlier just didnt want to seem like i hadnt done any of the research. Glad the build has lasted this long though, just proves that she will hold up.
