RTz
Administrators
    23
Everything posted by RTz
  1. Dang Bo, no grass growing under your feet. Looks very nice!
  2. Jon, I agree with you regarding the anti's. The connection I was trying to make (in my quoted post) was the relationship between ride quality and stiffness. Normally, a Z that holds itself up well, doesn't ride so well. I'm guessing the improvement that I felt had more to do with the dampers than geometry.
  3. Wowzers!!!!! Very relieved to hear he is okay!
  4. Thanks for starting a build thread! I have a couple concerns about your driveshaft... 1) U-joints, when run at anything other than 0 degrees, accelerate and decelerate as they spin. Typically they are used in pairs and 'timed' to each other to cancel or balance each other out. If you use only one, it may prove tough to get control of vibrations. 2) When driveshaft parts are assembled, such as a trunnion for example, they are pressed in and welded. The press fit contributes GREATLY to the strength of the assembly. If you only 'slip' it together and rely on a simple weld, there's some likelihood of failure. 3) In every shaft I've ever encountered there has always been some method to allow the shaft to run at varying lengths. In other words, the motor and trans are normally allowed to move longitudinally under acceleration and braking, independently of the differential. It looks like your arrangement would bind them together. Not entirely certain of the consequences, but if you haven't given it some thought, you probably should
  5. Rags, How about an electric pump? I believe it was the second gen. MR2's that came with them. They can be pulsewidth modulated for pressure, too.
  6. You can't make a race car out of a pig, but you sure can make a damn fast pig.
  7. I'd be interested in seeing that too. Back to the front bridge... Would there be any benefit in taking it higher up on the strut? Would that help stiffen the strut tube, or would it be dead weight?...
  8. I'm not sure you're taking this project serious enough Congrats on the start up!
  9. For my autocrossing, I try to run as little rear bar as possible. Not because it reduces understeer (opposite actually), but because it helps with corner exit bite. S30's are not great at putting power down on corner exit... running a V8 in lower gears exaggerates the problem. For what it's worth, I've been pretty successful in my region running a stock rear bar. Our local courses are typically pretty tight. The only time I've been able to do well with no rear bar is on faster courses. Are you running stock length struts? Ditto that.
  10. I believe Mortensen has a picture to share with you...
  11. Congrats. That'll be a hoot! Be careful of those. A local friend used them and one of the plastic connectors let go and dumped fuel. No one knows for sure if maybe he didn't get it snapped all the way on, but obviously he thought it was. I used the same part, but threw the plastic in the garbage and machined a cotter pin hole.
  12. RTz
    SDS and temp gauge
    Won't work.
  13. Doesn't matter... they are batch fired.
  14. The GPS speedo has a built in 0-60 timer. Don't know how accurate it is, but I thought I'd give it a try. I only made one run and botched the launch a little. 4.48 seconds... I can't make it in 2nd gear, gotta use 3rd for the last few MPH. That never helps. I think wrapping up the tune and a little better launch, I should be able to get pretty close to 4 seconds flat. Not too shabby for a little NA motor that also makes useful torque @ 1200 RPM.
  15. I'm not yet committed. Hughdogz gave me a set of half-shafts last weekend, so I'm good for a while. On my wish list is CV's and taller gearing, so I'm just daydreaming right now. But, I'd be happy to lend you a hand with yours.
  16. If I've got my facts straight, the stateside E36 M3 uses a 188mm ring gear, the Euro diff is a 210mm ring. BRAAP and I went to the JY tonight. I found this 1995 M3 diff (3.15:1)... Flange to flange is about 11.5"... about 2.5" wider overall than my R180. Yes, it would take some creativity to adapt, but I see nothing scary... yet. The axles would probably be the biggest expense/effort. In the States, R200 CLSD's cost far more than Bimmer CLSD's. The diff pictured above has 80K miles on it and I can pick it up for $300 (about 1/2 the price of a comparable R200). It's not the large case diff, but I see no need for it in our cars unless you plan on boost and slicks.
  17. I've been seriously considering just that. Taller butt gears, very tunable LSD, VSS, CV half-shafts... and no need to machine a diff adapter.
  18. If you have a 74-77 tach, there is some chance the BMW ECU will drive it. It won't hurt to give it a try. I had exactly the same thoughts, early on. I think a Honeywell 1GT101DC Hall Effect would do well, mated to an aftermarket speedo. That was my original plan, since I had intentions of using an aftermarket ECU. However, it may be troublesome with the BMW ECU. In my M3, there are a couple of obvious speed related 'things' going on... speed sensitive stereo, speed sensitive wipers, and gear based rev limiter (which uses info from the VSS). Obviously the first two are irrelevant, but the third item would be affected if the pulse count was off by much. Also, I can only guess at all the EFI related variables BMW may influence with the VSS. It's not something I've researched and it may be nothing to care about, but I would look into it before pushing the ignore button.
  19. Have a look at some small block Chev's. I believe you'll find the LT1, LT4, and L98 run a 5/16" supply and 3/8" return. I'm betting you could find a few more GM vehicles with that scenario. That should allow for a smaller return line.
  20. The Wolf ECU drives the tach. It's typical for aftermarket tach's to play nice with aftermarket ECU's.
  21. Said through squinted eye's and fake accent... "yoo funy maaan".
  22. Sorry Pete, I should have been a little more clear. I'm talking specifically about engine vibrations. Car parked, in neutral and rev'd through the range. My stock M3 with it's factory marshmallow mounts still transmits a minor amount of tingle. You really have to look for it to notice. However, with the Z and the poly mounts I was using, it's more noticeable, particularly in the rpm range where I spend the most amount of time with the car (cruise conditions). Wasn't bad, but I wanted better. The rubber did address that specific rev range pretty well (better than expected, actually), both while in neutral and while driving. If I never intended to 'commute' with this car, I would have left the poly, no question. RE: Exhaust; I'm with you... the low rpm/light load drone is what takes all the enjoyment out of it. The resonator should help you. I got a huge improvement with the homebrew muffler, but I would like even more refinement. Kicking around idea's but I'm nowhere close to acting on any of them.
