RTz
Administrators
    23
Everything posted by RTz
  1. In my opinion, it doesn't matter. The stock ECU is not adept to compensating for any torque curve changes. I'm not saying you can't make it run... I'm saying it will never be 'ideal'. By the way, you mention LSA at 108 & 111. It can only be one number. Which is it?
  2. All aftermarket cams are 'too big' for the stock ECU. You may be able to ban-aid it into being drivable, but it will always be compromised.
  3. Jeff Hartman's "How to Tune and Modify Engine Management Systems" will keep you busy for a while. You're not trying to size an injector spot on... you should always have some headroom. Here is a good calculator... http://www.rceng.com/technical.aspx?UserID=1647677&SessionID=B4uMm8ML2rvePEkeHHmJ
  4. Without dissasembly, there is no way to be absoulty certain, but you can get an idea by looking at the block stamp. See red circle below... It should say L28 if it came from a 280Z/ZX Also, the blue circle is the head casting. Might say N42, P90, etc. Use our search function to learn more about that specific head.
  5. Why don't blonde's make Koolaid? They can't figure out how to get 4 quarts of water into that little package.
  6. For what purpose does the propeller serve on an airplane? It keeps the pilot cool. Proof, you say?... If it stops, the pilot WILL sweat.
  7. That ad. has been posted here recently, and I'm reasonably certain the owner is a HBZ member.
  8. Doesn't matter. They're batch fired.
  9. You really ought to stop drinking the local water
  10. Why did Captain Kirk pee on the ceiling? He wanted to go where no man had gone before.
  11. Why was Tigger looking in the toilet? He was looking for Pooh.
  12. Cary, wouldn't the swaybar and its attachment method be a factor? A big burly bar, mounted to the control arm would be trying to pop the monoball from the socket, whereas a strut mounted bar wouldn't. Or is this load insignificant in the bigger picture?
  13. I'll think about it. Okay, I'm done thinking.
  14. You're question was indirectly answered in post 3 (& 4 ). Several of us have used the optical CAS as a trigger. FYI, if there is enough information to support sequential ignition, there is enough to support sequential injection.
  15. D80. I did some googleing and it looks like the D80 is ho-hum... not bad, not good. I priced out an R72 for my 18-200 VR... $286. Ouch. For my 50mm, $43. For $43, I may give it a whirl. Thanks!
  16. Boobala, I've long since been a sucker for IR photography. Nice job I wasn't aware you could get so close with a DSLR and a filter. My Xmas list just got a little longer
  17. True. One rule of thumb is the table... specifically its condition. I've found the condition of the table often coincides with the care/treatment the rest of the machine has seen. A machinist that doesn't care about the table 'prolly doesn't care much for anything else. That said, my table is absolutely pristine.... and I treat the rest of the machine with the same respect.
